08-20-2014, 11:52 AM | #23 | |
Rep 2,342
It's a known fact that CCB's need MORE thermal management than steel. Yes, they are lighter, and are more fade resistant. Braking is just energy transfer from kinetic to thermal. CCB's has higher threshold than steel, but at that point you are talking about a significant increase in heat. Without proper ventilation and cooling the rotors will oxidize and lose mass. CCB rotors do not show normal wear like steel rotors and must be weighed. There's plenty of information about this out there. While it may be "new" to BMW it's not new to P cars, F Cars, and the ZR1 - all which have a lot of cooling and diverting to keep the brakes cool. There's been instances during the ZR1's development where the brakes actually caught fire. CCB's giving you greater performance potential, but you're still limited by the pads. The car as it is when you drive off the lot does not have special duty pads where you can just jump on the track. The Journalist opinions you covet had already made complaints that they were surprised about the brakes fading in the M5/M6. Granted those cars are significantly heavier, but BMW ships the cars with "OK" pads that suit street performance. Brake pads can decide initial bite, feel, and all those other things we talk about with brakes - but they're also thermal tools. If you go out with street pads sure they may perform fine for a few 20 minutes sessions (when's the last time a journo has tracked a road car the same duration as you do for a DE?) but then they will wear more rapidly then a proper CCB "Track" Pad that can take higher amounts of heat. You still need to find a decent track composition for track duty. Endless W007 and W006 are popular for CCB rotors. And "Numerous laps" is what? At a large circuit going balls out 20 minutes could be 7-8 laps. Journalists track review of a press vehicle on a press day isn't the same as a person taking their car out to a DE where regular people go out with only the car they drove in on hoping the brake fluid and pads last all day. Journalists get one session before moving along to Q&A and cocktails. Maybe one more if You're Chris Harris. If you've ever been to a BMW Media day they bring pallets of Michelin tires, technicians, and yup - brake pads for the journalists and VIPS. So their experience will be far different from yours. |
08-22-2014, 07:44 PM | #25 | |
Rep 894
Drives: 2011 Toyota 4Runner Trail
How are you able to determine that the CCB's on the M4 lack sufficient cooling? Do you have track experience with that car and that brake setup? Should we assume that every single review of the M4 with CCB option is a staged performance by BMW with (non-standard pads and fluids)? |
08-22-2014, 08:27 PM | #26 |
Rep 1,840
Drives: '14 M5 CP Dinan Stage 2
M5 distances have been the same on independent test but the feel and confidence on the track is a noticeable difference + almost no brake dust =). I would not trade mine.
08-23-2014, 04:35 AM | #27 | ||
Rep 20,742
Drives: 2021 911 turbo
I don't think that the E9X is in dire need for a BBK. I have driven quite a few very fast tracks (135+mph) with heavy brakng, and never had an issue. While the need for a BBK on the E9X may be track dependent, it most certainly is very driver dependent. I see a lot of intermediate/advanced students overwork their brakes. Just recently, I saw an advanced student fry the front pads of his Brembo BBK on his E92. On the same day, I had no issues with my stock setup with PF08s, yet I lap 4 seconds faster than he does. Further, tracking with DSC or MDM activated will definitely kill your brakes. Last edited by CanAutM3; 08-23-2014 at 08:53 PM.. |
08-23-2014, 05:02 PM | #28 |
///M Uber Alles
333
Rep 1,601
It would be nice if one of the many auto rags trolling the internet picked up on this as a comparo idea. They could test the BMW, Porsche (and others) CCB's vs their stock offerings.
We are long on opinions and short on facts here. |
08-23-2014, 08:25 PM | #29 | ||
Rep 20,742
08-23-2014, 11:05 PM | #30 | |
///M Uber Alles
333
Rep 1,601
08-24-2014, 05:50 AM | #31 | |
Rep 20,742
It will be interesting to see a comparo between the M3/4 brake systems. However, I doubt that we will see one with the iron rotors paired with track pads. That is the one that really matters to me. The article does discuss pedal feel, travel and force, but really what else is there to discuss in terms of a brake system performance besides distance and fade ? |
08-24-2014, 09:56 AM | #32 | |
///M Uber Alles
333
Rep 1,601
The comparison would be between ceramics vs. stock as that is what would be of maximum relevance to buyers pondering the option. I mentioned Porsche because they offer the option. But they aren't the only ones. We also can't conclude that the same delta (or lack of one) exists between the Porsche systems and BMW's. Areas that could be measured/compared are: 1. Stopping distance/fade; 2. Consistency; 3. Wear; 4. Cost (with long term considerations); 5. Acceleration; 6. Lap times; and 7. Driving impressions/pedal feel. |
08-24-2014, 10:04 AM | #33 | |
Rep 20,742
Folks who only drive their M3/4 on the street will most likely never reach the limit of the stock iron rotor setup, so the CCB option is an overkill anyway (from a braking performance point of view). |
08-24-2014, 01:17 PM | #35 | |
Rep 894
The whole point of CCB is increased resistance to heat buildup and fade. The pedal may lose its sharpness after repeated lapping (several journalists have noted just that), but the stopping power has remained consistent. That is important to many buyers, especially if they are considering use the car for track days. The whole issue with comparing stock brakes with upgraded track pads applies to CCB setup as well...what's more relevant is a comparison of stock iron rotors w/ brakes vs CCB's in terms of brake fade and heat resistance. |
08-24-2014, 03:01 PM | #36 | ||
Rep 20,742
Karussel's experience indicates that the iron rotors, even with the stock pads, performed very well for track duty. But I agree, stock for stock, the CCB will likely have a better resistance to fade. However, for the track junkies such as myself, the cost of the CCB is just prohibitive for frequent track use. Based on my experience with my E92, I am convinced that the iron rotors with track pads will perform perfectly at the track. The huge cost of the CCB is simply not worth it TO ME. For that cost, I am willing to take the extra 30 minutes to swap pads. |
08-24-2014, 03:37 PM | #37 |
///M Uber Alles
333
Rep 1,601
Not that this proves anything, just thought it was cool to see.(190,000 km for fronts):
die Welt ist meine Auster 2015 M4, MW, Black Full Merino, DCT, CCB, Adaptive M Suspension, Premium, Executive. Technology, ConnectedDrive, CF Trim, Convenience Telephony, European Delivery |
08-24-2014, 03:41 PM | #38 |
Rep 5,678
Man, what did you do to the front pads to wear an extra 60,000km off them already
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery 2016 M2 | Long Beach Blue | 6MT 2015 M4 | Austin Yellow | DCT 2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3 |
08-24-2014, 07:42 PM | #39 | ||
Rep 894
Also, we are not discussing the Porsche's PCCB option, we are discussing the M4's CCB option. And while I'm sure there are similarities between the 2 setups's, I would like to see some actual testing of the M4's CCB's rather than transpose the Porsche's performance to the BMW's capability sheet. Quote:
I get that you don't want/like the CCB option, but you seem to be jumping to conclusions and doing everything in your power to discredit their performance and advantages. Just let the reviewers do their work and we'll see their true performance, or lack thereof. Last edited by Dalko43; 08-24-2014 at 07:51 PM.. |
08-24-2014, 07:49 PM | #40 | |
Rep 894
08-24-2014, 09:14 PM | #41 | |
///M Uber Alles
333
Rep 1,601
www.caranddriver.com/features/the-power-to-stop |
08-24-2014, 09:21 PM | #42 |
///M Uber Alles
333
Rep 1,601
I think CanAutM3 will argue that he stopped on his position after careful consideration and has not faded from it since.
08-24-2014, 09:45 PM | #43 |
Rep 20,742
08-25-2014, 07:57 PM | #44 | |
Rep 20,742
If you read my many posts in the various threads on the topic, I have always recognized the benefits of the CCB. However, it is important to be realistic on what those benefits are. I have always argued that those benefits are not worth the cost TO ME. I have discussed all aspects of brake performance here. Starting with braking distances, resistance to fade and then feel and consistency. I was only responding to your arguments trying to justify the CCB. I had to make my decision to opt or not for the CCB before any tests were available. So I had to make my analysis with what facts and information was at hand. For instance, the experience from Porsche owners on the PCCB is a good reference. I came to the conclusion that the benefits of the CCB were not worth the cost to me. I might be proven wrong when actual test results come out, but I seriously doubt so. If they are worth it to you, get them. As I said many times before, options are a very personal thing, there are no right or wrong answers. I got the LED headlights just because I find they look good. |
