02-13-2017, 10:17 AM | #46751 |
Lofty
3509
Rep 849
///M Power-Belgium74292.00 |
02-13-2017, 10:25 AM | #46753 | |
is probably out riding.
![]() 6064
Rep 2,292
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
02-13-2017, 10:38 AM | #46755 |
![]() ![]() ![]() ![]() ![]() 74292
Rep 27,363
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
02-13-2017, 10:42 AM | #46756 | |
![]() 4208
Rep 216
Nothing can go wrong unless you allow it you. |
02-13-2017, 11:43 AM | #46757 |
![]() ![]() ![]() 7789
Rep 12,091
Drives: MY24 G01 AW Msport
02-13-2017, 01:29 PM | #46758 |
![]() 18691
Rep 9,445
So Excel peeps: how do I make the contents of a column that contains the name of the exported file actually be the link to the file so I (or the judge) can pull up the images of the checks direct from each line? It has to somehow include ".\" so it can travel as a folder across thumb drives.
02-13-2017, 01:33 PM | #46759 | |
![]() ![]() ![]() 2786
Rep 421
02-13-2017, 01:39 PM | #46760 | |
![]() 18691
Rep 9,445
The .\ is "current folder" so I don't end up selecting "C:\my user profile\documents\subfolder\subfolder\filename" which the judge may not have on his computer. |
02-13-2017, 01:39 PM | #46761 | |
Rep 421
02-13-2017, 02:14 PM | #46763 | |
Rep 1,923
I'm not certain you can do what you want to do, to be honest. Someone more talented than me perhaps will know. The only thing I could think of would be to save the images to the USB key first and then create the file links to the USB key images. But I'm not even sure that would work, because depending on what USB devices are used on the computer it is going to, it could rename the USB key used from say E:\ to F:\ and I'm not sure if the links would still be valid then. Sorry - only idea I could come up with. |
02-13-2017, 02:45 PM | #46764 | |
Baby-faced Assassin
![]() 1207
Rep 152
Drives: when car isn't broke.
Code:
Sub hyperlink() ' ' hyperlink Macro ' ' Keyboard Shortcut: Ctrl+h ' Dim cl As Range Dim s As String Dim wede As String wede = "fugitive" For Each cl In Selection cl.Select s = cl.Value ActiveCell.Offset(0, 1).Hyperlinks.Add Anchor:=ActiveCell.Offset(0, 1), Address:=s, TextToDisplay:=s Next cl wede = "Acquitted" End Sub Paste this into your macro module In your spreadsheet, select the list of paths that you want to make hyperlinks. Press ctrl + h *Notes - DON'T use column select, pretty sure that will make an infinite loop. This is untested and you get what you pay for. - This is going to overwrite the column one to the RIGHT of your path list. Make sure it's blank or you gon' lose data. |
02-13-2017, 03:57 PM | #46765 | |
Rep 421
02-13-2017, 04:06 PM | #46766 |
![]() 6064
Rep 2,292
02-13-2017, 04:07 PM | #46767 |
Rep 421
02-13-2017, 04:10 PM | #46768 |
![]() 6064
Rep 2,292
02-13-2017, 04:11 PM | #46769 |
Libertarian
![]() 71760
Rep 4,035
02-13-2017, 04:12 PM | #46770 |
Rep 421
My blood has rushed to my penis, and it's gonna be real awkward if I have to stand up.
02-13-2017, 04:13 PM | #46771 | |
![]() 6064
Rep 2,292
(hope i got this one right...)
02-13-2017, 05:05 PM | #46772 |
Libertarian
![]() 71760
Rep 4,035
