BIMMERPOST Universal Forums Site Related Announcements - Suggestions - Feedback - Questions Bimmerpost App 5.x WIP for Android
      05-22-2022, 02:53 PM   #463
apptest
all I do is test!
4616
Drives: I lost count of how many
Originally Posted by MadBimmeRad View Post
I think I know why it happens, and yes, it's still happening.
Sometimes, when I tap on the three dots on top RHS for drop down list (top of list it says edit this message etc), instead of normal font, the list font is red and double yellow underline
When this happens, the message doesn't scroll when typing
I’ve released version 5.2.29 with an attempt to solve the problem when editing posts
Test 23456rt
      05-22-2022, 06:27 PM   #464
MadBimmeRad
MadBimmeRad's Avatar
Australia
7153
Drives: M235i, 420i, and now the M2 CS
Ok so its only happening when you edit a post?
No, not just when editing. I was mentioning it happens at that point as well
M2CS,
The second coming of ///M!
apptest4615.50
      05-22-2022, 07:20 PM   #465
apptest
all I do is test!
4616
Ok got it— could you let me know if you see it happen with .29?
Test 23456rt
      05-22-2022, 07:22 PM   #466
MadBimmeRad
Australia
7153
I'll do my best
M2CS,
apptest4615.50
      05-22-2022, 07:23 PM   #467
MadBimmeRad
Australia
7153
Yep, still happening
See images
M2CS,
apptest4615.50
      05-22-2022, 09:11 PM   #468
apptest
all I do is test!
4616
See images
Ok thanks, I think I have a better understanding of it, I just pushed out version .30 which I hope takes care of the red and yellow at the least, but potentially the entire problem.
Let me know
Test 23456rt
      05-23-2022, 03:34 AM   #469
MadBimmeRad
Australia
7153
See images
Let me know
Will do; so far, so good 🤞
M2CS,
apptest4615.50
      05-24-2022, 08:21 AM   #470
zcp312
///M
zcp312's Avatar
Drives: 2011 E90 M3 ZCP
Hi I’ve just released version 5.2.23 which I believe fixes this issue. If you notice more problems could you let me know?
Thanks!
Doesn't seem to be happening any longer over the last few days and a few different versions since 23. If I notice it again I'll let you know.
apptest4615.50
      05-25-2022, 04:55 AM   #471
titomi
titomi's Avatar
Drives: X3 G01 30i xDrive
2018 X3 G01  [0.00]
Looks like the performance went down with the latest updates. The app is slower, when I owned after some time. It takes longer to load forums list, forum threads, news, etc. I'm on the latest version and wifi connection, using Samsung device with Anddiid 11.
'18 G01 X3 xDrive 30i xLine, Sophisto grey, Vernasca Mocha, Adaptive
      05-25-2022, 06:21 AM   #472
apptest
all I do is test!
4616
We didn’t change anything in those areas for a while.
Might be some random intermittent connection issue? I would say, keep an eye on it
Test 23456rt
      05-25-2022, 06:35 AM   #473
MadBimmeRad
Australia
7153
Everything seems stable on my end so far
On the news page, I no longer see any images associated with new threads
Is that meant to be?
Edit: edit send to be behaving also
M2CS,
apptest4615.50
      05-25-2022, 07:03 AM   #474
apptest
all I do is test!
4616
That’s awesome to hear. We might have finally cracked that one then 😂
From the last screen shots you sent, it looks like you have “boss mode” enabled. That mode is designed to purposely remove all images from the interface. It’s still a work in progress and is about 75% done.
But you can just turn it off to get all the images back.
Goto setting -> app interface settings and switch it off and all those images should come back 👍
Test 23456rt
      05-26-2022, 07:05 AM   #475
apptest
all I do is test!
4616
Any better today?
Test 23456rt
      05-27-2022, 02:50 AM   #476
MadBimmeRad
Australia
7153
Sadly my friend, it is happening again
M2CS,
apptest4615.50
      05-27-2022, 05:36 AM   #477
MadBimmeRad
Australia
7153
Also
Can we please have a feature in the messageboard where we can simply choose to DELETE ALL when the inbox is full. Atmo, I have to delete messages one by one to clear room in my inbox. With a maximum of 220 messages, it takes a long time to delete them.
Cheers
MBR
M2CS,
apptest4615.50
      05-27-2022, 07:16 AM   #478
apptest
all I do is test!
4616
Thanks. It will take more time but we will solve this 😂
From which section of the app were you reading that thread? Ie. news, forums, my forums, new posts, subscriptions, notifications, etc…
Is there any pattern of events you notice where you can force that to happen?
Test 23456rt
      05-27-2022, 07:42 AM   #479
titomi
titomi's Avatar
2018 X3 G01  [0.00]
Any better today?
No. I might try to do a ideo capture of the screen. Maybe it is working as it should be, and it's just slow for me.
apptest4615.50
      05-27-2022, 07:44 AM   #480
titomi
titomi's Avatar
2018 X3 G01  [0.00]
Can't see the user name in the notifications in dark mode. It's visible in the light mode.
apptest4615.50
      05-27-2022, 07:46 AM   #481
MadBimmeRad
Australia
7153
It was from SUBSCRIPTIONS section
FWIW, I'm running v33
As for forcing it to misbehave, not really, it happens at random. It often happens when I'm replying to a post (where the page doesn't scroll up which means I can't see what I'm typing).
Then I check my reply and often Google has done an autocorrect on me which means I have to edit, and correct my reply.
The red font with yellow underline appears at this stage. I've had the red font on other occasions but it's not frequent.
So it goes like this, if the screen doesn't scroll, then edit will go red font, guaranteed. But, getting a red font doesn't just happen with the window not scrolling.
M2CS,
apptest4615.50
      05-27-2022, 07:47 AM   #482
MadBimmeRad
Australia
7153
Ditto
M2CS,
      05-27-2022, 10:28 AM   #483
apptest
all I do is test!
4616
That would be great to show what you’re seeing
Test 23456rt
      05-27-2022, 10:31 AM   #484
apptest
all I do is test!
4616
Nice catch, this is fixed in the next release coming today or tomorrow 👍
Test 23456rt
