05-10-2022, 08:36 PM | #4951 |
Comfortably Numb
941
Rep 657
Drives: '18 x1/'13 X3/'06 330i
When your optometrist says it is time for cataract surgery.
Been struggling with the night time driving, headlight glare is just miserable and the long distance vision is blurry. The glasses just aren't cutting it anymore even with new prescription.
06 e90 330i/Alpine White/Terra Dakota
13 F25 X3 xDrive 35i/Black Sapphire Metallic/Oyster Nevada 18 F48 X1 xDrive 28i/Black Sapphire Metallic/Black SensaTec |
05-10-2022, 09:49 PM | #4953 | |
Comfortably Numb
941
Rep 657
Doctor indicated there are a couple of different procedures that can be done. Sounds like one is a hybrid lense that can correct the vision. Also heard it's a bit expensive and not always covered by insurance or in my case, Medicare.
Esteban56931.50 |
05-10-2022, 10:06 PM | #4954 | |
Rep 7,241
I've worn glasses since I was 15. Now my vision is 20/25 and I hardly wear glasses. They have new lenses these days and I hear they work really well. The OP here, cmyx6go, had it done not too long ago. Maybe she'll chime in. Hope it's covered by your insurance. Good luck and let us know how it goes. PS - wearing glasses doesn't really bother me either but I like hardly needing them these days. |
SpeedBuggy940.50 |
05-11-2022, 07:17 AM | #4955 | ||
Rep 2,092
Drives: 2022 X6///M Comp
I have worn contact lenses for 30+ years for distance. As I got older, my close up vision started to go so my prescription got complicated. As they adjusted the close up vision, the distance suffered. I could have opted for glasses instead of lenses but the shallow bitch in me preferred contacts. Eventually I also needed readers. Anyway, I chose the surgery with the multifocal lens replacement. It cost me about $8K total for both eyes. Insurance only covered the surgery and the anesthesia. They did not cover the lenses. I can't find the breakout of what they actually paid. It must be home and not in my file here at work where it belongs. Results - The good - I no longer feel like I'm living in a grey world. There is more light getting into my eyes. The vision correction worked well. No more contacts and I only need readers if I'm reading something ridiculously small. The bad - Although the glare has reduced, I now see halos around lights at night. If I am approaching a traffic light, I see the green but it now has a green circle around the light. Same thing with headlights. The doctor said it would wear off after my brain adjusted to the change when I went for my first follow up visit. It has not. I just had a visit last week. Doctor said I was the first person ever to have this issue. My luck I guess. It's not debilitating, just annoying. If I had to do it all over again knowing the results, I'd probably still do it. I hope this helps. I will see if I can find how much insurance paid but obviously your plan will vary. I believe they pay for basic lenses but not the multifocal ones I chose.
I thought I was a good person but the way I react when people drive slowly in the left lane would suggest otherwise
05-11-2022, 01:39 PM | #4956 | |
18603
Rep 9,436
I need her to be able to see and bark if any neighbors come out while I'm ditching her poo in their cans. She was a bit confused when I called her last night at the gas station. The covfefe was cold, and I didn't want the diesel truck to take it out on her that I had sat there for 10 minutes in front of the pump while she was checking out the greenery around the station.
05-11-2022, 02:38 PM | #4957 |
Rep 2,092
Do they still require you to use hand signals when taking a road test?
vreihen1622107.50 |
05-11-2022, 02:52 PM | #4958 |
Rep 7,241
05-11-2022, 02:54 PM | #4959 | |
Rep 2,092
vreihen1622107.50 |
05-11-2022, 02:57 PM | #4960 | |
Rep 7,241
TBH, I don't know if they teach that anymore. |
05-11-2022, 06:39 PM | #4962 | |
Rep 1,030
https://dmv.ny.gov/about-dmv/chapter...-turns#mke-trn I have no idea if they still test on them as part of the road test, but suspect that the only hand signal known by kids today involves their middle finger and words that for some reason cause flashbacks to what soap tastes like.....
05-11-2022, 07:02 PM | #4963 |
18603
Rep 9,436
People driving behind me while on two wheels certainly have no idea what hand signals are
Which leads me to using finger signals
05-11-2022, 07:41 PM | #4964 | |
Rep 2,013
Horn broken, watch for finger.
2024 Mercedes Benz GLC300 Expert ultracrepidarian |
05-11-2022, 09:16 PM | #4965 | |
Comfortably Numb
941
Rep 657
Not sure about the multifocal lenses though. I haven't done much research or heard much in regards to that particular procedure. I do understand that the lenses are expensive and may not be covered by the insurance or in my case Medicare. Not to concerned about continuing to wear glasses, pretty comfortable with them. Actually just got a new pair of John Lennon frames that I really like and still have a previous pair of JL frames that I do want to get transition lenses in both pairs. Thanks again
05-11-2022, 09:35 PM | #4966 |
Rep 7,241
Got this out of the California DMV Driver Handbook.
https://www.dmv.ca.gov/portal/handbo...ing-practices/ |
cmyx6go16967.00 |
05-12-2022, 07:12 AM | #4967 | |
Rep 2,092
As far as the lenses go, the multifocals correct both distance and close sight in the same lens. There is another option that has the distance correction in one eye and the close in the other and then there is the option without vision correction.
Esteban56931.50 |
05-12-2022, 11:27 AM | #4968 | |
Rep 7,241
I got the second option that you mentioned where you can see for distance in one eye and the other eye is for close up. The brain takes over depending on what you're looking at. It's not for everyone but it works for me. |
cmyx6go16967.00 |
05-20-2022, 03:45 PM | #4970 | |
Rep 7,241
I heard someone say once that if people lived long enough we'd all get some kind of cancer. Doesn't always mean a death sentence these days but I still worry about it. Probably just feeling guilty for smoking all those years. lol |
05-20-2022, 04:32 PM | #4971 |
18603
Rep 9,436
A pack or two would probably relieve that anxiety . . .
05-20-2022, 04:40 PM | #4972 | |
Rep 7,241
I've had dreams where I smoked and woke up being so sad because I thought I still smoked and then came to my senses and realized I didn't and was very happy. And relieved. Quitting was one of the hardest things I've ever done. Literally took me years to quit. Would never go back to it. |
DrFerry7230.00 |
