BIMMERPOST Universal Forums Classic BMW (Pre-2005 Models) Does anyone watch M539 Restorations?
      01-20-2024, 05:52 PM   #529
Tambohamilton
Drives: E91 330d
Those meyle track rods he takes out - 100% the non-M version. Doesn't really matter, to be fair. They have heaps of thread engagement anyhow. I have M3 wishbones with non-M track rods on my car, and it's not an issue at all.
Does anyone else feel like the stance of the car is a bit off - too high in the rear, I think? Somehow the car doesn't look level to me. The e9x normally have smaller tyre-fender gap in the rear than the front, and it doesn't look to be that way on this car (yet).
      01-20-2024, 07:33 PM   #530
LOW4LYF
LOW4LYF's Avatar
2216
Drives: E92 M3 & F85 X5M
Because he is running a square winter tire setup.
Jbrown74032908.00
      01-21-2024, 03:07 AM   #531
Tambohamilton
Drives: E91 330d
How does that simultaneously make the back of the car too high, and with too much gap to the fender?
      01-21-2024, 08:39 AM   #532
M-technik-3
Drives: E30 M3, E36 M3, 328iT, 335i
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
Smaller tire is not going to fill the wheel well. It's still going to have the same ride height. Also Streten mentioned the suspension is junk so if the fronts are ridding on more spring then the rears it will make it look like a 70's muscle car on rear air shocks that was all the rage when I attended high school in the early 80's.
Never understood this as a teenager.
F32Fleet3923.00
      01-21-2024, 11:43 AM   #533
LOW4LYF
LOW4LYF's Avatar
2216
Because with the OEM staggered setup, the rear tire is taller and gives you less gap in the rear.
245/40ZR18
265/40ZR18
      01-21-2024, 03:53 PM   #534
Tambohamilton
Drives: E91 330d
Yeah, but right now it also looks to me like the rear is higher off the ground...
Anyhow, never mind. I'm sure he'll get it sorted when he does the suspension.
      01-23-2024, 11:29 AM   #535
toxik
toxik's Avatar
Drives: 2017 340i xDrive 6MT
anyone have any more info on the comment about Lemforder and TRW? I was planning on getting Lemforder control/thrust arms to replace my OEMs, but now I'm having 2nd thoughts. A quick google search did confirm that BMW no longer has Lemforder as an OE supplier due to quality issues.
      01-23-2024, 11:54 AM   #536
Tambohamilton
Drives: E91 330d
Basically lem and trw have moved production of some items to Malaysia, and the quality doesn't seem to be up to par any more...though I haven't actually heard of anyone having a Malaysian component fail prematurely etc - all the reports I've read are just saying that the items don't look well finished etc (which certainly isn't a good start!)
https://www.e90post.com/forums/showthread.php?t=2043241
      01-23-2024, 01:02 PM   #537
toxik
toxik's Avatar
thanks for the link, one of the posts on the first page is actually point out premature wear:
Ball joints in Malaysian tension struts are made of chocolate cake, or french fries. I have installed them in may 2022 and I had to replace them after year of searching what is knocking in suspension. I replaced them in may 2023, and after two months new arms are knocking once again
arms are annoying to swap out on such a short interval, would be worth going OEM if that's the case. but man it's so hard paying almost double the cost of what Lem wants compared to OEM.
      01-23-2024, 01:09 PM   #538
Tambohamilton
Drives: E91 330d
Good point!
To be fair, that's been the case for (German made) lemforder front sway links for many years
toxik2934.00
      01-23-2024, 02:18 PM   #539
toxik
toxik's Avatar
Good point!
sounds like I may need to just buy OEM
      01-23-2024, 04:58 PM   #540
Tambohamilton
Drives: E91 330d
Does anyone else make them? Febi?
      01-23-2024, 05:43 PM   #541
toxik
toxik's Avatar
yeah Febi does make them, but no US retailers carry them, I'd need to do an international order... which would still be cheaper than OEM I guess. Is Febi a recommended OE brand? Any others?
the only OE brands I see sold in the US have been TRW (no longer) and Lemforder which are still always in stock.
      01-23-2024, 06:45 PM   #542
Tambohamilton
Drives: E91 330d
Febi are oe for giubos, and they're my go-to for 'best of the rest'...but that doesn't promise much, tbh!
toxik2934.00
Mani5916244.00
      01-30-2024, 12:52 PM   #543
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Both are a subsidiary of ZF btw.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      01-30-2024, 01:06 PM   #544
toxik
toxik's Avatar
yeah do you know if there's any significance to that? from everything I saw the individual companies still operate independently, from what I understand manufacturing plants aren't producing TRW and Lem in the same space. if ZF's goal is cost cutting then both would be heading in the same direction overall, but other than that, I wasn't sure if their common ownership under ZF meant the products are the same.
      01-30-2024, 01:28 PM   #545
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Just figured I'd point that out. Thankfully somes parts houses in the US will disclose country of origin.
      01-30-2024, 01:31 PM   #546
toxik
toxik's Avatar
do you know which sites specifically? I'm not doing my arms just yet and this is why I started the question to begin with, my assumption is that the Germany stock will run out and all new batches will come from Malaysia, I want to be ready to make my decision correctly when time comes to buy the arms.
      01-31-2024, 01:20 PM   #547
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
FCP
toxik2934.00
      02-09-2024, 12:22 PM   #548
sergbaja5t
sergbaja5t's Avatar
81
Drives: 2011 E92-M3 Comp, 2021 X3M
@Sreten Thank you for videos and your content. I'm glad I'm a paetron member.
Now a days you cant please everyone. Cant wait for your videos!
"Coming up"
Mani5916244.00
B58 parts562.50
M3_Legend413.00
      02-10-2024, 11:06 AM   #549
Mani59
The next episode of Project Marseille (E31 850i) is now up!
Visit my (mainly) BMW gallery http://jetone.co.uk and BMW miniature model collection http://bmw-miniatures.co.uk
Jbrown74032908.00
B58 parts562.50
DrFerry7143.00
      02-10-2024, 03:18 PM   #550
Jbrown7403
Jbrown7403's Avatar
Drives: 2016 BMW M4
Really interesting episode and a nice way to spend a rainy Saturday afternoon!
