Seat Creak
01-15-2008, 11:39 AM | #45 |
Techie Geek
37
Rep 681
All now fixed. Car is as comfortable as I remember it being
330d M-Sport | Sapphire Black | Black Dakota | Nav Pro | iDrive | Bluetooth | PDC | Xenons | Hot Seats | Tracker | Blacklines
03-12-2008, 04:59 PM | #46 |
Rep 3,154
Seat Runner
Question all
I've PM'ed E92fan on this, but thought i'd put it to the people too Re: advice on a rattling front passenger seat. I had the dealer tighten up the seat, but its seems its still a tiny bit loose on the runnner, so with this little movement it rattles, I have sprayed a load of greece on the runners but it only cures it for a few days and its back again! What do you reckon? can you tighten the seat to the runner? (e92 coupe electric seats) cheers |
03-12-2008, 05:19 PM | #47 |
Rep 7,953
Drives: Merc diesel
Garage List 2010 TTRS [9.00]
2007 Audi S5 [0.00] May 2007 Porsche 99 ... [0.00] March 2007 Porsche ... [0.00] Sep. 2007 E92 335d SE [0.00] July 2006 E90 330i ... [0.00] |
Does the seat do it when there is a bum on it? My passenger seat only does it a bit minus a bum on the seat.
03-13-2008, 05:02 AM | #48 |
Rep 1,339
Drives: X1 25D M sport
Ill have to turn the music down and pay more attention to this lol
03-13-2008, 06:56 AM | #49 |
Rep 286
mine doesn't squeak but it has started to 'move' as if springs are letting go now before you start having a go about my weight, i have in fact lost 5 kilos this year and i only weigh 115kilos and my arse is not that large
does anyone have a link to the seat's construction (non sports) i cant see anything at all from underneath so guess it will need a repair...would this be under warranty or classed as normal wear and tear ? while we are on the subject could I get the standard seats replaced with sports ones ? thanks |
03-13-2008, 02:10 PM | #51 |
Rep 7,953
Drives: Merc diesel
03-15-2008, 06:37 PM | #52 | |
Rep 635
I can confirm its good stuff. Its actually cheaper from BMW though. about £20 for a tube.
04-29-2008, 11:56 AM | #53 |
Rep 204
Apologies for resurecting this old chestnut.
My drivers seat has started creaking. It's horrible, like rusty springs grinding. I've figured out that it's coming from the upright part of the seat and makes the noise as my back moves around in the seat. It can be heard on acceleration and cornering or if I just adjust myself in the seat. I cannot spray it because there is no opening to the inner seat. I will ask BMW to fix this under warranty but I can't see how they will open up the seat? I would hate them to unpick the stitching! Perhaps it will need a new seat. There is no movement in the seat rails though, it's the inside of the upright bit. Anyone else had this done under warranty? It's very annoying, not what you expect in a luxurious beemer!
BMW 330i M Sport Saloon - 06 plate - Le Mans Blue
04-29-2008, 12:19 PM | #54 |
Defected to the dark side.....
211
Rep 5,795
Drives: BMW M5 LCi
I have exactly the same issue with mine - when it was in the dealers a few months ago they sort of fixed it, but it re-appeared again within a few weeks (was not perfect even after they did it but it has never returned as bad as it did to start with)
My local dealer however is shite and I get sick of taking my car back to them for fault after fault. Most of them they dont fix first time anyhow. I may mention it next time it goes in but kinda feel I am wasting my breath! I have heard of a few seat bases being replaced but mine is like yours, with the noise worst when accelerating, and body weight transferring around the backrest. |
04-29-2008, 12:32 PM | #55 |
Rep 204
Thanks for that red, well I am about to book the car in for a service so I will insist they look at this under warranty at the same time.
I had a creak in the "seat" of the seat last year and eradicated it with a well aimed squirt of WD40. The car smelt of WD40 for a couple of weeks but it went away and the noise never returned. But with this latest creak there is no opening to spray into! Weird how these creaks suddenly start happening. To be fair to my local dealer they are pretty good, but I won't let this drop because it is pretty poor for a £34,000 car to creak like a Vauxhall Viva after just 2 years!
04-29-2008, 12:39 PM | #56 |
211
Rep 5,795
Drives: BMW M5 LCi
fully agree matey!!
You also dont expect a 38k car to have had steering rack, high pressure fuel pump, clutch, usb port, roof shell trims, headlamp washer mechanism, etc replaced alongside an airbag recall, CAN bus failure, seat base creak, injector reprograms, the list goes on..... Not bad for 6k miles and 10 months Quality German Engineering???? Not any longer IMO |
04-29-2008, 02:49 PM | #57 | |
Rep 793
Drives: F30 328i
Behold! F30 328i M-Sport - Tanzanite Blue with Opal White Leather
04-29-2008, 04:29 PM | #58 |
Rep 635
I found my creaking seat was caused by the pivot points of the front tilt mechanism (controlled by right hand front handle) By putting grease on those pivot points (mainly the Left hand side), the noise has gone.
04-30-2008, 02:04 AM | #59 |
Rep 204
Thanks I'll have a look at that. Mine sounds like it's a spring deep within the backrest, but I suppose it could be anywhere. Cheers.
05-19-2008, 06:03 AM | #60 |
Rep 204
Update.
BMW Dealer said seat creaking was common and they have lubricated the "usual places". Seems to have done the trick .... touch wood.
05-19-2008, 06:35 AM | #61 |
Rep 2,333
My seat creak (drivers side) was cured with a new steering rack.....
It only happened when cornering, and since dealer changed the rack it certainly seems to have gone......glad it was warranty work!
Current: F13 640i MSport, e85 Z4 3.0i
Previous - Alpina D3 BiTurbo E90 LCI Manual, 320d M Sport E92 Auto, 330i M Sport E92 courtesy of BMW UK....320i M Sport E92 Auto, 320d SE E90 Manual. |
05-15-2009, 02:43 PM | #63 |
Rep 269
Drives: E92 320i MSport > Merc C220CDI
I've had the seat creak on both my E92s. Cured them both myself with a can of spray grease, just moved the seat as high & forward as it would go and lubed up any springs, and also the screws/bolts underneath that hold the seats onto the rails and hey presto, no more creaks! Even though mine sounded like it was coming from the mid back, I haven't got any more creaks!
My left A pillar as also started rattling which was fixed with a slither of plastic between the pillar and the dash. I'm a freak for hearing rattles and haven't been beaten yet!
Sweeeeet
05-16-2009, 02:23 AM | #66 |
Rep 4,279
My seat creaks like old plumbing too, just dont want to put it in the hands of my mercenary stealer because it always seems to return with more audible defects than when they attempt a fix on few. Other issues are a horrible A Pillar rattle and the seatbelt making a low freq noise.
I thought it was a BMW, not a Lancia.
