CA Speedway Report
10-10-2007, 09:00 PM | #45 |
310
Rep 15,745
all these pics make me eager for next season. Some new tires and pads should really bring my car to life out there! And a brake flush too would help LOL.
My friends run with the PCA crew sometimes..depending on the club who has the event that day, it can either be a really good time, or a total drag... |
10-10-2007, 09:05 PM | #46 |
Supreme Allied Commander
3893
Rep 54,605
Drives: F80 M3
I may have caught some air off the curbing here! Too bad the E30 M3 blocked the camera's view!
10-10-2007, 09:07 PM | #47 |
3893
Rep 54,605
Drives: F80 M3
I believe the orange Mustang behind me was one of the faster ones. At least he didn't spin or hold us up!
10-11-2007, 12:11 AM | #49 |
Rep 648
HP Autowerks - Body roll is not such a bad thing. Do you prefer the extra movement or would prefer to have less with sways? The TCK's did great at Calspeedway and seemed to keep the tires on the ground. Whatever body roll I had did not bother me. Don't have any photos though to compare to yours.
10-11-2007, 12:47 AM | #50 | |
3893
Rep 54,605
Drives: F80 M3
Are you also running the TCK CO's? What front/rear spring rates are you running? Harold |
10-11-2007, 02:07 AM | #51 |
This is my unique custom title
269
Rep 700
10-11-2007, 02:09 AM | #52 | |
269
Rep 700
-Daniel |
10-11-2007, 08:26 AM | #53 | |
Rep 1,137
FourPoint...I see from your (amazing) pictures that you were running near that M5. My instructor said that he was having some issues. Did you notice anything? I started my pressures at 34/38 cold and eventually dropped 2 from the fronts. My car did run warm at times but never went into limp home or significantly reduced power. I know the computer starts reducing power at 280. When I was chasing that Carrera and the heat was creeping up, I did notice that I had increasing trouble staying with him on the straight sections. Part of that was due to poor exit speeds because the RFT's were so greasy. Part of that was also that I was getting tired and not driving well. But also maybe part was the computer cutting back power. For the next event I plan to switch to Red Line 10W-40 and see what happens. I was really happy with the combination of Turbo Tuner and 100 Octane. In actuality it was 1/4 tank of 91 and 3/4 of 100. The car ran real, real strong. As for next events, I really like Driving Concepts schools. They are small and seem to be well run. While I am not a big fan of WSIR, I just think the DC schools are safer. Perhaps I will go...After all, I did spend all that money on track insurance! Might as well use it.
2010 Evo X - silver with a big, stupid wing on the back
2009 VW CC - Black/Black - with a 2011 328i on order to replace it - ED 8/1/11 |
10-11-2007, 10:32 AM | #54 | |
Rep 648
10-11-2007, 10:37 AM | #55 | |
Rep 648
10-11-2007, 10:53 AM | #56 | |
3893
Rep 54,605
Drives: F80 M3
I am with the first school of thought at the moment with fairly stiff springs and damper, but without sway-bars. I was running about 2 degrees of negative camber up front, could use a bit more that is for sure. You are totally correct on using too much sway bar. Lifting the rear inside tire would hurt the 335i coming out of a turn with an open diff. What we may do is step up the spring rate a bit or use a slightly larger front bar only. Would you point me to the right directiong on the Motorsport sway-bar? Harold |
10-11-2007, 12:32 PM | #57 | |
Rep 1,137
10-11-2007, 12:42 PM | #58 | |
3893
Rep 54,605
Drives: F80 M3
It would be great if you could post that video on youtube. I would love to have a look at it. Thanks. Harold |
10-11-2007, 01:52 PM | #59 |
Rep 4,380
Drives: 2014 Audi A4 / 91 Track Miata
I got video from Sears Point...but its in the wrong format...its on tape..gotta convert it...I am following Lindsay's Audi..and that Mazdaspeed 626 touring car...nice footage for the few seconds they were around.
Car is now gone .... :-( |
10-11-2007, 02:15 PM | #60 |
3893
Rep 54,605
Drives: F80 M3
Would be great to see that as well. Have always seen Pat's car from the pits, but not on the track.
10-11-2007, 03:12 PM | #61 | |
Rep 1,137
Sorry for the low resolution...I was afraid youtube would reject it if the file was too much larger.
10-11-2007, 08:45 PM | #62 | |
Rep 1,349
I know the fronts just get beat to $hiite on these car with all the understeer, and the RFTs are too expensive to be chewing threw like Doublemint. Sounds like the guys who know what they're doing can't really optimize the pressures that well to minimize understeer without running customized suspension setups with more negative camber up front. Maybe it feels different in the Auto vs the Manual around 100mph? I just remember bouncing in my seat like I was riding a horse trying to get my car to goooooo! Dammit Porsche Twin Turbos!!!!!!!!!!!!!!!!!!
Any man who can drive safely while kissing a pretty girl is simply not giving the kiss the attention it deserves. ~Albert Einstein
10-11-2007, 10:48 PM | #63 |
Rep 1,714
I have the rear sway only and I will tell you, you spin like hell coming out of tight corners. The balance is quite nice now and I am, if anything, a bit tail happy.
I am thinking of putting a thicker front sway on to get some traction out back, but 0.5 mm greater than stock isn't something to get excited about. |
10-12-2007, 12:07 AM | #64 |
Rep 648
The video looks like normal body lean but the angles are not perfect to determine this. Harold, what are your current spring rates? What previous suspension were you running and how do you compare the two?
10-12-2007, 12:28 AM | #65 | |
3893
Rep 54,605
Drives: F80 M3
The video does not show much roll, but the photo does. 400/500 at the moment, up from 400/375. Not looking to degrade the ride quality, thus looking into sway bars for roll control. Sway bars front and rear would reduce body roll, give me less body roll induced camber change and give me a better contact patch. |
10-12-2007, 01:12 AM | #66 |
Rep 648
If it is the picture in this thread, is it possible that your right side tires were on the bump strip and therefore the excessive body lean to the left? I would be interested in your observations after the bar install. I personally think 400lb fronts are too soft for track work in a six inch length and lowered ride height, but understand your desire for comfort and sways can accomplish your goal to a certain extent. I just dont feel that the H&R front sway will do much over stock, but if I were buying, I would buy the set of front and rear.
