11-14-2022, 06:27 PM | #45 |
Rep 369
Drives: 2023 G80 Comp X-Drive
11-14-2022, 09:45 PM | #46 | |
Rep 713
Drives: 23 M3Cx
When did you order? I ordered 11/4 and the ETA from order e-mail says 11/30. Haven't gotten any updates on my end.
G80x/Dravit/Carbon Roof/Carbon Exterior/ Bi-Color 826/Shadowline Lasers/Full Silverstone/Vented Seats/Exec. Pack/DAP/PAP/M Drive Pro
11-14-2022, 10:03 PM | #47 | ||
Rep 369
11-14-2022, 10:05 PM | #48 | |||
Rep 713
Drives: 23 M3Cx
11-18-2022, 11:37 AM | #49 | |
Professional Lurker
59
Rep 80
I'm noticing that the part you have to pry against is also the glass of the console buttons (I think they're glass). Seems to be the only place where there's a large enough gap for a tool (without dimpling or scratching the other surrounds). If anyone can confirm it definitely pulls out from the top, that'd be great. Mine seems to be in there really good and something's gotta give. |
MunkyTool551.50 |
11-18-2022, 12:33 PM | #50 | |
Rep 258
X5ALIVE58.50 |
11-19-2022, 01:50 AM | #51 |
Rep 122
Don’t pry with a tool it won’t pop out. Take the center console from off and unscrew the entire shifter console out. Then you can release the tabs out and pop the badge out.
11-19-2022, 02:21 AM | #52 | ||
Rep 1
I did pry and it popped out without a problem. |
11-22-2022, 01:46 PM | #53 |
Rep 1,669
Has anyone tried any laser engraving for the gloss part above where it says M3/M4? I was thinking that would be a great place to put your instagram QR code / screenname or something.
Ego is the anesthesia that deadens the pain of stupidity.
The single biggest problem in communication is the illusion that it has taken place. Wheel horsepower is just crank horsepower after taxes. IG: EmFore_650 |
11-28-2022, 06:22 PM | #56 |
Rep 4,000
Mine from getbmwparts showed up yesterday. Took 3min to install with a trim tool.
Best place to pry is on the bottom and right sides. Use painters tape to protect the console.
Current: G82 M4 Comp xDrive // Frozen Deep Grey
Current: 95B.1 Macan Turbo // Dark Blue Metallic - for sale |
MunkyTool551.50 forcefed2596.50 904_FireG80308.50 T0RM3NT3793.50 jpichardo91161.50 Limegrntaln13701.00 venox22133.50 OwnerF16881.50 |
11-28-2022, 06:32 PM | #57 |
Rep 369
Limegrntaln13701.00 |
11-28-2022, 06:59 PM | #58 |
Rep 278
Drives: 2023 M3 Comp
11-30-2022, 02:19 PM | #61 |
Rep 74
I just tried doing it on mine
Won’t come out Either I’m - scared to break it if it doesn’t or this doesn’t work. Can anyone who’s already done it create a video? I mean, if it takes 5 minutes to do why not help out everyone else who is trying? Not an insane request, right ? |
11-30-2022, 02:20 PM | #62 | |
Rep 74
It feels like it’s clipped on |
11-30-2022, 02:22 PM | #63 | |
Rep 74
Do you mind showing some of us how you did it? I would appreciate it Mine seems it doesn’t want to come out Others are having a hard time as well. We would really appreciate it Mine comes up a bit from the front but then it stops almost like the back is clipped and unless we are 100% sure it comes out … we risk breaking the thing |
X5ALIVE58.50 |
11-30-2022, 04:02 PM | #64 | |
Rep 4,000
You might use 2 trim tools and go at it from the bottom and right sides at the same time. With mine, I had worked to pry the bottom side a bit, and then worked on the right side and it just popped up. Before trying the right side I spent time working the left side with my finger as I thought I might be able to get a good enough grip, but no go. Didn't have any luck getting a trim tool in there either, and didn't want to try too hard since you're rubbing up against shiny black plastic without a good way to protect it. IMHO, as long as you have the surrounding silver trim protected there is little risk of breaking anything. Of course, always mod at your own risk.
11-30-2022, 04:06 PM | #65 | |
Rep 258
OwnerF16881.50 |
11-30-2022, 05:34 PM | #66 | |
Rep 74
The plastic broke up trying to lever it up Just tried again for the second time Can’t do it The front comes up but the back or side won’t at all Might just bring it to a dealer IDGAF |
