11-19-2016, 10:44 AM | #45 | |
Rep 5,115
Connectivity is definitely more stable now (bluetooth) but still having issues with some ECUs like KOMBI not being stable enough to code. I forwarded Carly a bunch of logs so we'll see if there's another app update over the next few days or weeks.
'11 Z4 30i (retired);'11 X3 28i (retired); '15 M235i Stage 1 Dinan (recalled & crushed); '16 M235i Stage 3 Dinan (retired); '15 X3 28i (retired); '14 328i (retired), 2019 X3M40i (retired); Loaded '18 X1 (retired); Loaded '20 X3MC DG, Black/Tan Merino (retired); Loaded '23 X1 Cape York green and Red/Black interior; '23 Audi A4 Allroad Progressiv
harma24404.00 |
11-21-2016, 06:50 AM | #46 | |
Rep 37
If I understand you correctly, you can code some modules with no problems? But other modules (like ECU) won't play ball? If that is the case, it is very strange how the connection can be stable enough to code one module, but not another. Purely out of curiosity, do you always code in the same location? (Garage,Driveway etc?) I wonder if there is something interfering with it? Maybe try having a go at another location if you haven't already?
Gone: 1999 E36 316i, 2001 E46 318Ci, 2007 E60 525d, 2014 F32 420d, 1990 E30 320i, 2016 F22 M235, 2018 F20 M140i,2021 G20 320i
Current: 2024 U11 X1 sDrive20i MSport |
11-21-2016, 07:53 AM | #47 | ||
Rep 5,115
That said heard back from Carly last night re logs I'd forwarded and he said he's noticing a peculiar issue specifically around the KOMBI piece and wants me to try a few things. So bizarre....
11-21-2016, 07:59 AM | #48 | |
Rep 37
Hopefully the combination of new things to try and a different location may get things moving in the right direction. Fingers crossed for you. What are trying to code in KOMBI? Digital Speedo?
11-21-2016, 08:01 AM | #49 |
Rep 5,115
Let's hope so! Hadn't decided what I wanted to code....wanted to see the list of codable options but can't read the KOMBI ECU to see the list!
11-21-2016, 08:14 AM | #50 |
Rep 6,993
Drives: 15 F80 M3, 22 G01 X3 30i
Check the coding cheat sheet in this section...it will give you a list of all modules and features that are codable.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey Last edited by RoundelM3; 12-27-2016 at 08:20 AM.. |
BMWZ41914.00 |
12-27-2016, 02:27 AM | #51 |
Captain Unsensible
101
Rep 737
Drives: 2016 M240i Coupe - Estoril
I plugged mine today on my 240 and managed to code a few features, although it does not support the latest iDrive as yet.
The one thing I want to enable is enhanced bluetooth for office functions as it isnt on mine, but i understand it is. |
12-27-2016, 11:38 AM | #52 | |
Rep 140
Pat |
MattUK101.00 |
12-27-2016, 11:41 AM | #53 |
Captain Unsensible
101
Rep 737
Hiya
Carly does not support the new iDrive on the 240 yet so no you can't code anything there. The only things it allows are lights, seat belts and some dash mods. You can however do it via the full coding if you have the Bluetooth option.. I've yet to do it but I've been given the details just have to set it all up and try |
12-27-2016, 03:14 PM | #54 | |
Rep 5,115
12-27-2016, 10:56 PM | #55 | |
Captain Unsensible
101
Rep 737
When I had the 6 coded, there were a huge number of things I could code up that were not included, and their response is they only add what people ask for based on the demand. They are slow but I guess thats because they test it a lot as they have a lot riding on it going wrong, whereas if you are let lose with the coding tools yourself, then its down to you breaking it yourself.. |
12-28-2016, 07:59 AM | #56 |
Rep 5,115
New update available this morning for battery registration on F models.
01-01-2017, 10:15 AM | #57 |
Rep 6,993
I used Carly to code a friend's F25 X3 yesterday, and there were only a handful of useful features that I could code. Strangely, it can code "unlock doors at engine shutdown", but not "shut off electronics at driver door opening". I was able to do the digital speedo readout and remove the analog speedo correction and a couple of other things, but not near what can be done with E-Sys. That said, Carly's interface is a whole lot easier to use. I purchased the "iDrive Codings" option and it has a fair amount of features to code, but most of them have to do with "Video in Motion" and so forth.
2015 F80 ///M3 Sedan 7DCT Tanzanite, 2022 X3 sDrive30i 8AT Brooklyn Grey |
03-02-2017, 01:00 PM | #59 |
Rep 95
Good info, I was looking at this as an alternative, does anyone have a full list of what they were able to do with their m240i?
I'm actually surprised they give you all the tools to do unlimited coding, most programs like this use credits for coding. Pretty good deal. |
03-27-2017, 05:27 PM | #60 |
Rep 73
I have the carly and have coded some futures but domyou guys know if you can dissable active sound?
Also i tired the tilt mirror in reverse but didnt work. I would also like to activate trunk lights on with front drl. |
03-27-2017, 09:16 PM | #61 | |
Rep 505
For tilt mirror in reverse, you need to have the mirror adjustment switch set to the driver side. If you have it set to the passenger side, it won't work. Last edited by dailowill; 03-29-2017 at 09:50 AM.. Reason: Apparently you don't need power folding mirrors foro this feature. |
03-28-2017, 07:47 PM | #62 |
Cone Killer
85
Rep 209
03-29-2017, 01:16 PM | #63 |
Rep 5,115
Delete
03-29-2017, 01:16 PM | #64 |
Rep 5,115
Updated app available for download today. Supposed to include support for NBT idrive as well as disabling Active Sound!
EDIT: and also exhaust valve control
03-30-2017, 09:56 AM | #65 |
Rep 505
03-30-2017, 12:25 PM | #66 |
Rep 5,115
Will do. I'm hoping I'll have some time Sunday. I was going to try both, but interested in the exhaust valve.
