BIMMERPOST Universal Forums General BMW News and Cars Discussion Next Generation Toyota Corolla to get BMW engine?
      12-26-2016, 09:40 AM   #45
jpnh
jpnh's Avatar
1430
Drives: NA
Originally Posted by KSERGEI-BY View Post
B48 was one of the reason for me to order a new x1. I testdrove it and i liked it. The design pdf is actually telling me that bmw was able to make a proper 4 cyl engine once in while.
When the cars equipped with B48's (230, Mini Cooper S, X1) start turning 200k with zero engine issues or everything connected to it directly or indirectly having to be repaired or replaced I'll gladly buy one instead of a toyota as basic/entry level DD wheels
The problem is that the engine is considerably more expensive to manufacture than the 1.8l 4 pot currently in use in the corolla which defeats the purpose of an inexpensive entry level vehicle thats reliable
      12-26-2016, 10:19 PM   #46
John_01
John_01's Avatar
Australia
241
Drives: E90 325i, E82 135i
I don't think I would buy a Toyota with BMW engine if there is too much technology. They are supposed to be super reliable, and that is the main reason why people buy them.
      12-27-2016, 12:00 AM   #47
KSERGEI-BY
KSERGEI-BY's Avatar
47
Drives: Audi A6 quattro
I sold my Grand Cherokee and was looking for a big SUV initialy. I considered buying a Toyota (ended with a small x1 as I said before). In fact, I wanted Toyota Land Cruiser Prado 2.8d, testdrove it. This toyota is all good but the engine. It is a) slow on acceleration b) slow on pedal responce. Gas options (ancient 2.7) are even worse.
I would not buy toyota with bmw engine embedded, but I love to see some bmw(aka modern) tech implemented by toyota.
e36->f48->....
      12-27-2016, 07:54 AM   #48
M3 Adjuster
Albania
7901
Drives: 1M, X1 M Sport, E46 325ic
Originally Posted by ShocknAwe View Post
Doesn't mean much. I'm in one of the new X1 vans right now and the 2l turbo engine in that is pretty trash.
B48 was one of the reason for me to order a new x1. I testdrove it and i liked it. The design pdf is actually telling me that bmw was able to make a proper 4 cyl engine just for once.
Yeah the S14 totally was awful
      12-27-2016, 08:18 AM   #49
KSERGEI-BY
KSERGEI-BY's Avatar
47
s14 and m43 are the exceptions from the rule : Bmw is all about 6 cyl engine.
e36->f48->....
      12-27-2016, 08:19 AM   #50
M3 Adjuster
Albania
7901
Ok... so you really meant... just for Thrice .. instead of " just for once " when you said that
BMW is about 3,4, 6, 8,10, and 12 cylinder engines... not to mention motor cycle motors ...
it's BMW "fans" that are " all about the 6"
      12-27-2016, 01:19 PM   #51
raysspl
raysspl's Avatar
992
Drives: walking, bicycle, & bus
I gander that the reason for this joint venture is because Toyota is going to continue its focus on hybrid & hydro powertrain development & is outsourcing the next gen ICE to BMW
re
      12-27-2016, 03:50 PM   #52
motzus
Drives: i4 M50 (ordered)
I'm not sure that this is a good idea for Toyota... going with "things in general here." Suppose the BMW motor is just as reliable as a Toyota sourced motor. All motors have wear items that eventually needs to be replaced. Let's say you need a new valve cover gasket. On the current Corolla the replacement cost is running between $100 - $150 (according to repair pal). On a BMW 328i (which has a 2.0 liter turbo inline 4) the repair cost is estimated to be $649 - $959. Why the difference in cost you might ask? Well if you dig into the repair manuals replacing the valve cover on the BMW engine is much more complicated due to the way BMW designed the engine. On the Corolla you simply remove some bolts, take the valve cover off, scrape the gasket off, clean the valve cover, put a new gasket on, put the valve cover on and torque the bolts to spec. On the BMW engine you have to remove high pressure fuel rails, remove air intake hoses, remove bolts and throw away (bolts are torque to yield and cannot be reused, they are like $10 - $20 each, there are a bunch of them) etc. etc. A Corolla owner is going to be pretty surprised with the cost of a simple valve cover replacement. Maybe BMW can make slight alterations to customer engines that makes maintenance easier / cheaper but I'm not sure that they would bother.
      12-27-2016, 04:57 PM   #53
SCOTT26
SCOTT26's Avatar
5460
Drives: A big F-off German Truck.
Will not affect the US market. Will continue in Europe where it already has been without complaint,conspiracy or paranoia.
In regards to FWD. BMW projected 600,000 combined BMW/MINI FWD units by 2020. As it stands combined sales so far is around half that projection.
And with 2017 introducing the MINI Countryman and the BMW 1er Sedan. 2017 is expected to be closer still. But with more models coming before 2020. 600,000 units is expected to be surpassed earlier than initially projected.
The M850i is evidence that BMW have got their mojo back when it comes to dynamic sports cars...
mkoesel7467.00
      12-28-2016, 01:04 PM   #54
rainfall
Drives: A
It would be cool to see the GT86 with a 2-liter turbo. Or a Corolla hatchback with the same engine and AWD. Subaru got dominant in this segment after Mitsubishi quit the affordable sports car segment.
p.s.: calm down guys... it's ok to differ in opinions... Just don't judge the other person
      12-28-2016, 05:28 PM   #55
snipe
Drives: 330i
Fantastic news, if the goals are reached without a FWD 1 Series you don't need it! And then it can stay like it is, the best driving hatch in class!
      12-28-2016, 06:09 PM   #56
Spinnetti
Drives: Various
Originally Posted by James550i6spd View Post
I work for Toyota. R&D dollars are going into hybrid and electric car tech. BMW has just about perfected application of FI technology on 4,6 and 8-cylinder cars so better to pay them for that instead of recreating the same technology
So do I - how does that give you inside info?, and this makes no sense. Why give away margin on such a high volume product? And BMW is no low cost supplier... I call BS on this one. What facility do we have in Knoxville? I'm at HQ
      01-02-2017, 08:26 AM   #57
James550i6spd
Drives: BMW x5
Dude this info is from general auto industry publications. It's not a big secret regarding toyota's and bmw's future partnership and what each party can gain from each other
James
<GONE> 2014 BMW 335i Melbourne red
M sport. 6spd. Nothing more nothing less.
ISO of Manual 535/550/335
