09-24-2018, 03:16 PM | #45 | |
Rep 1,367
First M: New '99 M3 Titanium / Black
Most recently returned: New '18 M5 SG / Black Current: '21 X5 M50i Black / Black |
09-25-2018, 03:00 PM | #46 | |
Rep 2,703
I have a 2000 psi sunjoe washer (something like that its called) And a Torxs foam gun from chemical guys, and high gloss soap from them. and using this gives me a shaving cream foam on my car. |
09-25-2018, 04:45 PM | #47 | |
Rep 249
I always wash with a mitt. Some believe that you can foam and then rinse. I like to foam, rinse, soap with mitt and two buckets (one for rinse, other for soapy water), final rinse. Rinse is with 40 nozzle. I guess if the car isn't so dirty, you can foam and then spray. I would still do the above and just not rinse (go straight to soaping with mitt and bucket) if I wanted to save time. |
09-25-2018, 08:13 PM | #48 | |
Rep 1,367
09-29-2018, 07:43 PM | #49 |
Rep 1,367
Got a handle on the foaming!!
So first pass was washer on 40 to knock all off, was within few inches at times. Then foam bomb and then another 40 rinse off. Came out like diamonds and drove thru many a rain day.
slavearm226.00 |
12-22-2018, 08:38 PM | #50 |
Rep 533
This hose attached foam canon will produce FOAM. I know because we have both kinds and use this when we don't want to drag the pressure washer out.
https://www.amazon.com/Gilmour-Clean.../dp/B000Y190WE Here is a good pressure washer foam canon with it's own handle so you don't have to worry about the long wand. MTM Hydro 14.5005 Snub Gun Foam Cannon https://www.amazon.com/dp/B01MG9632D..._ttVhCbFS0JQJ8
JS
04-25-2019, 05:23 PM | #51 |
Rep 818
I use the touchless wash if the car is not too dirty then i spot clean at home. However, since that takes significant amount of time (drive to/from wash plus go back home to for touch up's), i've decided to get electric pressure washer and foam cannon and will just do it myself. This way all my cars will get a better wash and likely will end up taking the same amount of time or less.. I also have a full shop compressor in garage connected to air nozzle so i can air dry stubborn areas that shammy towel will not get.
06-01-2021, 10:26 AM | #52 | |
Rep 110
They seem to do an ok job-but its nothing like one would do themselves or a professional job. Water, soap, vacuum, something greasy on the dash, etc. |
