08-15-2018, 03:33 PM | #45 | |
Rep 1,264
Drives: 04 z4 3.0 Sport & 15 X5 35i XD
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
08-15-2018, 06:53 PM | #47 |
Rep 29
From experience I’ve learned weight loss comes more from what you do NOT put in your mouth!!
I lost 30 lbs in a month a half last year by not eating carbs and never ate past 6pm. I’ve maintained the weight the past year but limiting my carbs though I do cheat occasionally. Not easy at all with being Asian and you know how much we loooove rice!! Good luck! |
08-15-2018, 06:58 PM | #48 | |
Rep 1,385
imo amount of what you eat is more important than what you eat. your body is a factory. If you intake more than you put out you endup with storage.
2011 E90m3 ESS G2, active auto x pipe, RK FULL E85, DD
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD 1994 300zx 2jz Swapped slicktop- The toy/track car |
08-16-2018, 02:16 PM | #49 |
Rep 902
Drives: 2024 BMW 230i xDrive
I may have missed it somewhere, but what about liquids. The single biggest thing I was told after my heart attack was not to drink your calories.
This post sent using 100% recycled electrons.
hooligan_G016541.00 |
08-16-2018, 02:56 PM | #50 |
Rep 307
No expert here, but we are extremely similar in weight and requirement. I am unwilling to give up on my carbs (Italian wife) who cooks like a champ so I am eating pasta and bread frequently through the week.
I obviously struggled with losing weight under these pretenses, like you I did the treadmill, I walked frequently in the evenings or mornings but did not do any weights. Outside of home cooked goodness I eat clean, drink water only pretty much and stick to non-processed foods. I am after just losing about 25 lbs of chub. I basically resided myself to ensuring I increase my activity and took up jumping rope. I am happy to say that to me, there is no better exercise which will burn calories as fast for the time period committed. My leg muscles, calves and waist saw improvement in the first few weeks of jumping rope. Without changing my diet I dropped 15 lbs in the first month and toned up which I couldn't do on the treadmill or walking. The added benefit of it being an exercise which can easily travel with you was a big help for me. Like others mentioned, you might need more activity.
2008 E93 M3 | SSII | HRE P40's (Sold 2018)
2011 E90 M3 | Jerez Black (Sold 2019) 2019 Lexus IS300 (lasted 3 months) 2020 Toyota 4Runner TRD (fun truck) 2014 Tesla Model S P85 (wicked car) 2011.5 E92 M3 | Space Grey | ADV.1?s |
08-16-2018, 04:13 PM | #51 |
18532
Rep 9,432
You just can't exercise your way out of a poor diet. I've been trying for almost 40 years. . .
08-16-2018, 06:02 PM | #52 |
Rep 960
08-16-2018, 06:16 PM | #53 | |
Rep 4,135
Good sources of inspiration are bodybuilding quotes, although you probably are not exererting the same regiem or have same goals. there discipline is very motivating. check out evan centopani on youtube. you are aren't going to follow his diet to a tee. But he has good nutrion tips and eats a simple clean deit. Honestly if you eat square meals of carb/protein according to macros, and lift. your body will have no reason to store excess fat. |
08-16-2018, 06:23 PM | #54 |
Rep 1,848
You guys are making this way more complicated than it needs to be.
Eat less (make sure you get good nutrition). It's literally that simple. Calories in less than daily caloric expenditure and thanks to physics you will lose weight. You can optionally exercise to increase your caloric expenditure but you can sit in a room motionless all day and as long as you eat less than your body requires calorie wise you will lose weight. The hard part is sticking with it. Calculator to give rough idea of how many calories you expend: https://www.freedieting.com/calorie-calculator To expand on getting good nutrition, it's probably a good idea to take a multivitamin and make sure you get plenty of protein and fat (unsaturated is best). Fill out the rest with carbs if there's room left over. Why? You body NEEDS protein and fat or you will die, carbs are optional although useful for exercise. The multivitamin helps round out any small-nutrient deficiencies in your diet. |
08-16-2018, 08:07 PM | #56 |
Rep 87
Fact of the matter is your body is built in the kitchen.
You want to burn FAT I suggest. 1. Do the Keto Diet 2. Intermitten Fasting 3. Interval training - Cardio Sprints OR ALSO KNOWN as HIT 4. Lift 5 Days a week TUT (time under tension)- CHEST AND ARMS EVERYDAY obviously... And skip leg days (jk) |
08-16-2018, 08:48 PM | #57 |
Rep 2
I lost 8kg over 2 years without changing my exercise regime at all. I cut out soft drinks and reduced my sugar intake (without eliminating all treats). And i also got into intermitting fasting, whereby I wouldn't eat anything after 8pm and not starting eating the next day until at least 10am. This gives the body a rest from digestion which helps with healing, etc too. Good luck!
08-17-2018, 02:59 PM | #58 |
18532
Rep 9,432
08-17-2018, 03:26 PM | #59 | |
Run Deep
15088
Rep 4,123
Drives: Back and Forth To Work
Garage List 2018 Alfa Romeo Giu ... [0.00]
2022 Ford Bronco 2d ... [0.00] 2016 Alfa Romeo 4C [8.50] 2019 BMW i8 Roadster [10.00] |
I burn about 325Cal running 5Kms on a treadmill and about 375 running 5kms outside with hills. Are you saying you are running 10Kms a day??? Cause that is what it would take to burn 800cals. That seems unrealistic. Also, weight training burns very little actual calories. I find it very suspect that you are burning 500cals during a single weight training session, unless it involves a ton of cardio as well. I think your calorie values are inaccurate. |
08-21-2018, 09:19 AM | #60 |
Rep 451
I went from 301 to 225 in just over a year. I started with a C25K program and lifting every other night, then when it got warm out, at about the 6 month mark, I added in a hour on my road bike on my nights off. I went from a 44 waist to 36... 50 jacket to 46. I'm 6'1 and almost to my goal weight of 185. It's a journey, don't sweat what others are doing. At the end of the day, it all comes down to calories in vs. calories out. I also started keto about halfway through and have found that lifestyle fits me well. might or might not for you but definitely look into what you're putting into your body.
08-21-2018, 11:44 AM | #62 |
Rep 4,365
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
Try to hit a calorie target without subtracting your exercise... I think you are over counting your negatives and under counting your positives. This is the approach I take and in cut phases usually lose 1-2lb a week without loss of strength.
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4 2017 Harley StreetGlide • Denim Black • V&H Tune 2021 BMW x30i • Phytonic Blue Metallic • Fully loaded |
08-21-2018, 12:42 PM | #63 |
Sicario
1133
Rep 1,248
Drives: 2018 M3 ZCP
Intermittent fasting is the way to go man. That is if you want to drop weight quick. 8/16. 8 and 16 means you eat for an eight hour period in the day and fast the other 16.
Wake up in the morning and do some sort of fasted cardio. An hour walk, 30-45 jog, hike, swim, whatever. Get your metabolism going. Drink coffee, it helps. Have 1-3 cups of black coffee throughout the morning. Make sure you are drinking plenty of water. First snack should be around 250 calories. Second snack around the same. Last meal should be around 1,000-1,200 calories but that you can decide for yourself. Again, like everyone has said your diet is going to be the key to getting lean and putting on muscle. Muscle burns fat man, so mix in more weights with your routine. HIIT will burn more calories for a longer period. Also, when doing cardio you need to know your body. A 30-minute jog is not going to cut it all the time. Most peoples bodies do not start diving into fat stores when doing cardio till about 50 minutes in. However, that is the benefit of HIIT as it keeps you diving in and out of cardio zones. It confuses your body. Also, stay the hell away from supplements. Multivitamins are fine, fish oil, etc, but don't start using fat burners and other horseshit, it doesn't work. A calorie deficit means everything. Other people here have made great suggestions and options, I am just telling you what will work the best. Honestly, you should go see a nutrition and get information on everything. They often times will have BODPODs and other devices that can help you figure out where you need to be safely. Do not just dive into a program you read on line and assume it is going to work for you. I am not some sort of fitness god or know it all, but I do have a lot of knowledge and training. MFT - Master Fitness Trainer (US Army school. That is where I got my start) Certified Personal Trainer Certified Dietition
Ryan King
2018 M3 ZCP |
08-21-2018, 12:47 PM | #64 |
Rep 11,191
I'll never go on a diet since my wife might as well work in a Michelin star restaurant, so that's out of the question. Counting macros sounds like something reserved for those in hell. Anyways...
I balance that out by getting plenty of exercise. And no, I'm no talking about wasting away in a smelly gym. I really try my best to get 10,000+ steps in per day. You're outside, you get some fresh air, great time to be left along as well and get some good thinking done. I ride my bike on the weekends, or during the week if I can squeeze it in. |
Graves1133.00 |
08-21-2018, 02:24 PM | #65 |
Rep 1,094
Different strokes for different folks, but here's what worked for me:
Intermittent fasting - skip breakfast, lunch and dinner within 12pm - 8pm window; satisfying but sensible meals Weightlifting - heavy and compound exercises; work the same muscles (upper and lower) multiple times during the week; never neglect legs Cardio - HIIT over long/slow I'm new to all of this (especially strength training), but shed about 20 lbs over the past couple of months, so I think something must be working. ha. |
so0fresh46.50 Germanauto9849.00 |
08-21-2018, 03:48 PM | #66 |
Rep 4,365
A lot of people talking about intermittent fasting... it didn't work super well for me. I find better results personally when I eat as constantly as I can, first thing when I wake up, throughout the day, big dinner and then some long burn protein right before bed. As long as you hit a caloric target you should be fine, regardless of when you are consuming the calories.
edit: Can we also stop talking about confusing the muscles or confusing the body... that is nonsense.
