02-16-2022, 09:06 PM | #45 |
Rep 4
Guys i wish i saw this post before picking up my 2022 X3M. Unfortunately ran into same issue and have paint chipping behind the plastic bracket. Quite pissed.
Couple of questions on the amazon replica for the bracket posted above. 1. What is behind the housing for the 4 screws on the corners? Is it a metal piece covered by soft material? 2. Do the screws on this replica rust? Has anyone had any issues? |
02-17-2022, 06:10 AM | #46 | |
Rep 2,558
I've never removed the foam square from the back of the screw housings on the good bracket, and they've never loosened, so not sure if it is flat plastic or metal, but suspect the threaded piece is sealed in the plastic. Either way, it is fully protected from harming the paint like the cheap bracket can. Note again that they aren't cutting screws either. I've used the good bracket for years and never once had an issue with rusting or seizing. But then again, I don't live up North where snow and salt are an issue, so perhaps spta97 and others can comment. After reading his suggestion about 'anti-seize' which I'm embarrassed to say I'd never heard of, I purchased some and have begun using just to be on the safe side. |
02-17-2022, 12:51 PM | #47 |
Rep 254
I ordered an OEM license plate bracket from ECS which was a perfect fit so if you want an original BMW frame (and are willing to pay a little extra for it), this was what I ordered: https://www.ecstuning.com/b-genuine-...r/51188238061/
You’ll need to buy the machine screws for securing the plate to the frame. |
02-18-2022, 11:35 PM | #48 |
Rep 4
Thanks for the info. I ordered Amazon aftermarket bracket that was suggested on this thread which should arrive in the next couple of days. I also ordered 4 stainless steel screws from Amazon apparently fits the bracket as well. I am still pissed with the crappy bracket situation and the paint chips I had to fill up. Anyway will need to get over it.
Another question for the group. The dealer suggested not to drill the front license bracket on the M vehicle and suggested to get a tow hook license plate holder. I live in Toronto Canada and we need to have front and back plates. Does anyone have a good recommendation on which one to get that does not block parking sensor and also good quality which doesn’t rust or loosen over time? I ended up getting a standard front license bracket on my previous M4 but have second thoughts on doing the same on the X3m. Any advice from the group? |
02-19-2022, 06:07 PM | #49 | |
Rep 158
https://x3.xbimmers.com/forums/showt...ighlight=plate
2022 X3MC MBB (mine), 2021 X7 40i BSM (wife's), 2014 640i BSM (sold)
Build page --> https://x3.xbimmers.com/forums/showthread.php?t=1849502 |
Max Well4813.00 |
02-19-2022, 07:37 PM | #50 | |
Need mo $$s
873
Rep 913
Used a small bit of Anti-Seize on the threads, just in case.
2020 TRM-BLACK X4///M Competition
2020 Porsche Macan 1995 Dodge Stealth TwinTurbo Past: 2020 X3M, 2019 TTS, 2008 X5 4.8 M Sport |
Max Well4813.00 |
02-23-2022, 05:12 PM | #52 |
Rep 4,057
The Amazon bracket is an "exact replica" of the revised / better unit that BMW never should've stopped using to save a buck. And no, the screws don't rust.
1998 E36 M3 - Totaled
2003 E39 M5 - Gone but not forgotten 2011 E90 335i M-Sport - Daily Driver 2017 F87 M2 - Sold & missed 2020 F97 X3 M Competition - Finally arrived /// |
02-23-2022, 06:13 PM | #53 | |
Rep 2,221
If it is a big concern, you can get stainless screws from Ace/HD/Lowes. |
02-23-2022, 06:42 PM | #54 | |||
Rep 2,221
I just checked my X3 (which is still covered in salt). I have the caps on them but the screw (head anyway) doesn't appear to be rusting. And I did make a post about them claiming to be stainless but also can be grabbed by a magnet - in further research it seems to not correlate so they may in fact be stainless steel. However, I have found 316 (marine grade which is not attracted to magnets) to be more rust resistant than 304. More info: Quote:
02-23-2022, 06:48 PM | #55 | |
Rep 2,221
Usage, therefore, is as follows: 1) Spread a generous amount all over your clothes/body/hands/face. 2) Put a dab on the threads of the screw/bolt. No matter how careful I am, I always manage to get some on me..ALWAYS!! But good stuff to use if you are worried about bolts/screws rusting and seizing. Just a PSA that if you are torqueing a bolt to spec, it is usually listed as "dry". If you use anti-seize, the same torque will be more due to the lubrication. |
11-28-2022, 02:13 AM | #57 |
Rep 2,797
Drives: 2020 M4 ZCP / 2023 X3 M40i
Can anyone with a 2023 check to see if BMW is still using the newer cheap bracket?
11-28-2022, 03:58 PM | #58 |
Rep 2,558
While at the Dealership this morning scheduling a svc appt I intentionally looked at the floor cars after seeing your early AM question. All of the empty frames I saw were attached with the cutting screws, not the nice machine screws, so I have to surmise they are still using the cheap brackets. And this was on some X vehicles including M performance variants. Maybe others who actually have their 2023 models can chime in as well.
alex23642935.00 Kevin_The_Clean13433.50 |
11-28-2022, 05:03 PM | #59 | |
Rep 2,797
11-29-2022, 01:38 AM | #60 | |
Rep 4,057
Max Well4813.00 |
12-21-2022, 07:38 AM | #61 | |
Rep 2,558
Any F/U on whether it came with the cheap vs good rear license bracket at delivery? |
12-21-2022, 11:01 AM | #62 | |
Rep 2,797
Max Well4813.00 |
12-21-2022, 07:39 PM | #63 |
Rep 2,797
Also forgot to mention one thing, the screws that came with the bracket is shorter than the ones in your post so it’s not scratching the paint. I’ll attach a pic of it. I believe the screw is part #07146959895 but someone should double check on it.
12-22-2022, 01:28 PM | #64 | |
Rep 2,558
01-15-2023, 06:41 PM | #66 |
Rep 2,558
