04-03-2020, 08:56 PM | #45 | |
Rep 556
Drives: 2011 528i M-sport (sold), 2018
How much it cost in Indonesia bro?
04-04-2020, 07:02 AM | #46 |
Rep 50
04-04-2020, 03:48 PM | #47 |
'20 M2 Comp.
906
Rep 182
Drives: '20 M2 Competition DCT
AMAZING build!! Gotta take some time to appreciate those Focal Beryllium tweeters. How do they sound? I love seeing more of these audio upgrades
'20 BSM M2 Competition DCT
IG: @porky_m2c |
04-08-2020, 04:17 AM | #49 |
Rep 50
04-09-2020, 03:49 PM | #50 |
#dubspec
6347
Rep 5,201
this is wrong information. you do NOT lengthen the links. there are front and rear links provided. you shorten the front link 5mm over oem and shorten the rear links by 6mm over oem
LCI ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow instagram: @ dubsesd |
04-09-2020, 08:03 PM | #51 | |
Rep 50
I just do it what i found on youtube. 5mm length change= 28mm drop Front link longer will provide drop Rear link shorter will provide drop It also works for me |
04-09-2020, 08:56 PM | #52 |
#dubspec
6347
Rep 5,201
this means the longer of the 2 links goes in front. you do not extend the links longer than oem.
05-10-2020, 04:26 PM | #56 | ||
Rep 182
I did install them this weekend and have a lot of pictures. First pictures bbm links, the longer go in the front. Second pictures oem links.. all the same length The reason why it works reverse is because the front ones are above the axe , they can be removed without removing the wheel if you lift it enough. The rear ones are under the axe. I still have fine tune the new links a little bit, this van be done without removing the back wheels but there is verry limited space if you don't have a bridge. I will write a howto soon ;-) One tip. leave your door open so the car won't lower when disconnecting the links. |
05-20-2020, 05:08 AM | #62 |
Rep 50
05-29-2020, 09:19 AM | #66 |
Rep 1,952
Looks like you're getting bad contact on your calipers from your brake pads. Nice and shiny in the middle but rusted on the outer and inner rings.
