BIMMERPOST Universal Forums Off-Topic Discussions Board Question for those of you who have CAT5/6 wired homes...
      07-24-2022, 05:35 PM   #45
Glen e
Retired from BMWNA
200
Drives: ‘21 X2 m35i
My condo was built in 2014 and recessed into the wall in the bedroom closet is a small door that includes power and the coax and cat5 that feed every room thru the walls. A wifi router used to sit in the living room cadenza, But everything that was important like all my streaming page and computers were hardwired to the CAT5.All of that went away when they ran optical up to the closet box and put in a small Wi-Fi modem about three months ago. It increased the speed from 80 Mbps to 500…Because optical feeding the Wi-Fi modem is so damn fast now, The cables through the walls are unnecessary, I’m getting 500 Mbps anywhere in the condo now without any cables.
Glen
Ft Lauderdale
'23 228i GC
      07-24-2022, 08:55 PM   #46
zx10guy
Drives: 2013 135i
Originally Posted by wdb View Post
I have an OC200 hardware controller. https://www.tp-link.com/us/business-...troller/oc200/
TP-Link competes against Ubiquiti and that ilk. I found it to be more accessible and cheaper than the others. They're rapidly adding more hardware, and constantly improving the software and integration. That said there are little glitches to work around, all of them easy. The company is also buying out consumer class vendors so you'll see their name in that space too.
A buddy of mine recently opened up an AirBnB rental. He has some sort of little Google thingies scattered around so that he has WiFi signal. I offered to fix it for him. ;-)
That's good to know about TP-Link. I wonder if they're really doing all of the engineering in house or having another OEM do it for them. Netgear was doing this with their higher end ProSafe line of business switches. They had a chassis switch which I think was either an Enterasys or Extreme Networks switch rebranded under Netgear.
As to the Google thingies, it's probably Google WiFi which uses a mesh setup between APs. This is not the same as a repeater/booster.
Originally Posted by Lups View Post
We might not be in an agreement on Trump, but I'll be the first penis chaser here to say I'll rather take it up in the ass than to argue with you on this.
      07-25-2022, 08:12 PM   #47
wdb
dances with roads
wdb's Avatar
5248
Drives: '07 E86, '02 996, '95 Seven
Wireless backhaul though.
      07-26-2022, 11:16 PM   #48
B58-M340iX
Drives: 2021 M340i xDrive
You want a wired backhaul for your mesh extenders if you can do it - I use it with my Google Fiber 2 gig service. It was a huge pain to get the wired part to work in my house, but I eventually figured out how to get it going with a wired backhaul.
      07-27-2022, 08:32 AM   #49
Agreed. My system, with multiple Deco X20 nodes, was vastly improved by wired backhaul.
      07-27-2022, 06:55 PM   #50
Chick Webb
Drives: '10 E92, '17 540i, '21 X6 M50i
Yeah, even Powerline networking for backhaul is preferable than using the wireless channel.
      07-28-2022, 07:14 AM   #51
zx10guy
Drives: 2013 135i
For clarification, of course, any wired connection is preferable to going wireless for the backhaul.
My comment was about a different situation. Repeaters and boosters connect to the main AP as a regular wireless client. Not only does this cause more congestion and performance issues on the overall wireless network, it divides the bandwidth in half. Mesh wireless backhauls are very different than this. Mesh wireless backbones use a different part of the 5GHz radio RF than the normal ones used by wireless clients. These are DEDICATED connections between member APs in the cluster. Of course the performance of these wireless backbones are entirely dependent on things that normally affect wireless networks.
As to powerline networking, in many cases yes, it is preferable to using wireless backhauls. But not always. It also depends on the quality of the wiring in the house and that there is no noise in the A/C line between the two powerline nodes.
