BIMMERPOST Universal Forums General Automotive (non-BMW) Talk + Photos/Videos Anyone have Quick Jack?
      04-12-2024, 03:59 PM   #45
GolfCoyote
GolfCoyote's Avatar
1242
Drives: 2024 M3 Comp xDrive
Originally Posted by ShopVac View Post
Risking my life under jack stands was all the more reason to get. When I had my HF jack explode on me...it was eye opening.
Not sure if it was stated prior, Costco runs a sale on these twice a year, taking 300-400 off the costs
Needless, use mine twice a month at a minimum. Maybe I just work on my cars more than others.
Honestly getting the G80 up on jack stands is what pushed me to get the Quickjacks. This car is such a pain in the ass to get on two stands. Earlier this month I spent like 45 minutes trying to get my car OFF jack stands because my jack decided it no longer wanted to pump as high, meanwhile the car is slowly wiggling its way closer to the edge of the jack-pad every time I lifted and lowered the car trying to get the stands out. That event was enough to buy the Quickjacks lol.
I miss my Mustang where I could just buy a jack rail that went along the entire side of the car so you could jack from anywhere.,,
2024 M3 Comp xDrive
2023 Mach-E Premium AWD
ShopVac4720.50
      04-12-2024, 11:32 PM   #46
cozye
cozye's Avatar
635
Drives: 2024 M3 Comp - 328ix (hers)
I really wanted to get the quickjack and nearly did for my exhaust system install, but I couldn’t justify having to by the 6000 to fit the G80, and it being too long for any other car. The frames are pretty costly too, as I looked into the option of buying the smaller frames for other cars.
      04-13-2024, 07:27 AM   #47
M-technik-3
Drives: E30 M3, E36 M3, 328iT, 335i
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
Just came across this photo on garage journal, guy I know over there had borrowed a set and he made a comment on them and someone posted their G21 on them. I did not think of lifting mine that way so I am going to try it out.
      04-13-2024, 08:16 AM   #48
Hagasan41
Hagasan41's Avatar
Drives: 2013 E92 ///M3, 1999 E36 ///M3
I may reconsider a built in lift down the road, but the Quick Jacks have been a solid investment for the last ~5yrs or so for me. I still have a floor jack and a pair of stands when I don’t need to fully lift the car off the ground.
Just used to do an oil change on the 36.
ShopVac4720.50
      04-13-2024, 08:54 AM   #49
ShopVac
Not willing to take advice
ShopVac's Avatar
Drives: F82 M4 - 6MT
Originally Posted by flybigjet View Post
Which model do you have? I've been looking, but I need one that will work with the M2C, a Miata, an Element and an RDX.
It looks like you may have done the research for me!
TIA--
R.
5000TL - but I bought the extender for the SUV's. This works on the Acura I had - and as you can see, the Genesis. Home Depot online had the cheapest price for the extenders
For my friends XM3, I needed to turn them sideways...but still worked.
Proud owner of 4 Turbos and 1 Supercharger
flybigjet8065.00
      04-13-2024, 09:02 AM   #50
M-technik-3
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
I got mine at home depot as well
ShopVac4720.50
      04-13-2024, 11:10 AM   #51
cozye
cozye's Avatar
635
The extenders wont work for a G80. Turning sideways is an issue if you want to do exhaust things, access to the center of the car, etc.
      05-07-2024, 03:29 PM   #52
XutvJet
XutvJet's Avatar
6113
Drives: 2011 Cayman Base, 2018 M2
I got my Quickjack 5000TL and assembled it last weekend. Works great. The key to assembly is reading the directions completely before actually building the thing. Bleeding the lines is critical. Quickjack provides a thread sealant because apparently many people don't know how to use PTFE thread tape the right way. I used PTFE thread tape and had no issues. Quickjack says you can use it if that's your preference. I watched so many Quickjack build videos and fails and saw so many people not following the directions. They put sealant on threads QJ specifically says not to, they overwrap the threads in PTFE, they way overtighten the fittings, they don't position the jacks correctly for bleeding, etc.
I got the 5000TL so I could lift my Cayman (2940lbs), M235 (3400lbs), my wife's 2020 4runner (4600lbs), son's 2020 Mazda 3 (3200lbs), my daughter's 2015 Outback (3700lbs), and possibly a single cab/2WD 2024 F150 XL (5.0 V8; 4100lbs), if I replace my M235. The Outback is the only vehicle it won't fit. I'll need to get the extension bars as the Outback jack points are a couple of inches too wide.
When not in use, I push the Quickjacks together and park over them with my Cayman.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
Almuliman560.50
ShopVac4720.50
s_ribs99.00
KCee45.00
      08-24-2024, 07:29 PM   #53
TTM0TION
Drives: 2018 Grigio Telesto ZCP
Question for those with a Quickjack. Mine automatically goes up once plugged in. I don’t hit a button. If I hold down it goes down but as soon as you let go it goes up again unless you unplug it. Any thoughts?
      08-24-2024, 07:58 PM   #54
chris3g
chris3g's Avatar
3157
Drives: 2023 M3 xdrive
sounds like a wiring problem with the control unit assuming you checked the button isn't stuck. definitely not supposed to do that. if it's new i'd get them to replace it. if not open it up and see what's going on in there.
      08-25-2024, 09:26 AM   #55
bosstones
Drives: o_0
Not normal. My guess is that whatever electrically indicates to the control unit that 'Up' is pressed is stuck. There is likely some cheap electrical component that gave up the ghost and results in the voltage (or ground) associated with 'Up' being constantly sent to the controller.
