02-09-2025, 12:21 PM | #45 |
![]() ![]() ![]() ![]() 515
Rep 571
Drives: 23 M5C, 19 X5
I just started looking in the E90 tech guide for the ATC300 transfer case. I think that is where the "1%" comes from:
"The tire circumference can fluctuate up to 1% or more as a result of mixed tires or wear. The tire tolerance logic decides depending on the driver's command and driving situation whether the slip is to occur in the transfer case clutch or at the contact area between tire and road. If the slip is permitted in the transfer case clutch, the locking pressure set by the pre-control is reduced in order to keep the work loss low. In the driving dynamic control situation, the clutch is locked slightly more than normal, the four wheel drive is always guaranteed when required. For maximum xDrive performance, tires (and wheels) of the same diameter should be installed on the vehicle." |
DrVenture1784.00 |
02-09-2025, 12:46 PM | #46 |
![]() ![]() 864
Rep 716
I have read in several sources that star tires for BMW, and the equivalent for several other manufacturers (e.g. M-B), are different from the standard spec tires for that model.
One may or may not care about the differences, but I gather that they do exist.
A BMW car and several BMW motorcycles
DrVenture1784.00 Westside Guy7697.50 |
02-09-2025, 04:11 PM | #47 | |
![]() 3570
Rep 2,311
BMW Remote Coding - https://chris3g.com CS Software/Antidazzle/ASD Package for G8X BMW Service Manuals - https://g80.bimmerpost.com/forums/sh....php?t=2167202 |
02-09-2025, 04:15 PM | #48 |
![]() ![]() ![]() 6176
Rep 11,725
Which means that non star spec tires won’t damage or adversely affect the handling of your car — BMW is using non star spec tires under the most adverse conditions.
snowbimmer6906.00 |
02-10-2025, 07:56 AM | #49 |
BMW Owner Since 1971
2635
Rep 1,577
Drives: 1964 700 Sport Cabriolet
I was surprised to see the first post in this thread comparing different brands rather than star to non-star tires from the same brand.
I can't say if it's still relevant today but years ago when the E34 was the current 5-series, a good customer came to me after replacing his original Michelin MXV-4s with the "same" tire without the star from the local Michelin dealer. He was complaining about the change in handling and so we compared the still-original BMW spare tire with the new store-bought Micheins. Right there on the sidewall showed the non-star tire was constructed with two-fewer plies in its carcass than the OE star version. Obviously there was a noticeable difference in sidewall flex which resulted in a larger slip angle. And these tires, other than the star, were the same spec, brand, and model. ![]() |
BMWbiker864.00 |
02-10-2025, 08:30 AM | #50 |
Rep 11,725
Star are different in some or maybe all cases. There should be no dispute about that. Might be just a change to improve the load rating or might be a tread compound or design difference. But that does not mean your BMW will perform poorly with non star tires.
I recommend doing some research on what others have used or what should work well. For the Michelin PS4 with star for the F90 M5, it appears there is a Continental tire that is a great alternative — even BMW is using it. If you don’t know what you are doing or don’t want to research, buy star tires. No one is saying they are not a good choice. Some of us are simply saying there may be additional choices that may be considered. |
jmg20646.00 |
02-10-2025, 11:13 PM | #52 | |||
![]() ![]() ![]() 20646
Rep 14,686
Drives: G87 M2
Garage List 2025 BMW M2 [9.50]
2022 G82 M4C X-Drive [9.81] 2018 F80 M3 CS [9.92] 2018 BMW i3 REx [4.87] 2015 BMW i3 REx [3.00] 2016 BMW F80 M3 [7.63] 2016 BMW F30 340i ZTR [10.00] 2013 BMW F30 328i [8.50] 2006 Audi S4 25Quattro [7.33] |
This is incorrect. You merely have to feel the outer corners of the * spec vs the non-* spec. It has a different composition. Quote:
The difference is 1.18% or 0.315 inches. Some source say 2.5% is the max. I've heard 1%. Are there problems with this setup in the M440i?
![]() 2025 G87 ///M2 LCI - KWHAS, Millway Motorsport Uniball Camber Plates, SPL Adjustable Tie Rods, Unit17 OEM++ Spoiler Previous: 2022 G82 M4 Comp X-Drive • 2018 F80 M3 CS • 2016 F80 M3 |
02-10-2025, 11:51 PM | #53 | |
![]() 127
Rep 48
02-11-2025, 11:34 AM | #54 | |
![]() ![]() 864
Rep 716
I’m still breaking mine in, so I’ve mostly been driving it like a stereotypical grandmother, and definitely staying under 4K RPM (per the owners manual).
02-11-2025, 01:13 PM | #55 |
Rep 11,725
I assume there is some sort of electronic control that can be programmed to inform the transfer case of the front to rear difference. Does anyone know?
02-11-2025, 01:24 PM | #56 |
Rep 6
Novadays I'm researching alot also, I will choice oem tire when replace, * will guarantee to engineering and fine tunning end to end match. Also About run flat tech, it is really important to me for high speed safety!
02-12-2025, 12:14 PM | #57 |
Rep 571
I don't think it is needed. There is no reduction gearing or anything so if the axle speeds are different the clutch needs to slip. There is some text in the guides that allude to it detecting that and setting the clutch a little less to allow the slippage to occur more smoothly. This would imply that if you have mismatched sets there is greater slippage so the AWD can be less effective at transferring power to the front.
SpeedOften80.50 |
