BIMMERPOST Universal Forums General Automotive (non-BMW) Talk + Photos/Videos Mustang GTD laps NRing in 6:57.685
      12-11-2024, 02:22 PM   #45
Bumpinjeep
Bumpinjeep's Avatar
Drives: 2023 M2
2023 M2  [8.33]
Originally Posted by clutchdj View Post
And a better value to say the least. Why does this car need 815hp? Anyone have the weight specs?
This is Ford's Halo car in Mustang guise. It has to one up the 760 HP GT500 with the same motor, hence the 815 HP. Probably has something to do with Hellcats getting 807 HP as well. No car needs a ton of horsepower, this isn't a car that anyone actually needs either, this is a halo car that people simply want and Ford knows that and got the huge HP number.
Ideally when the track warms up and Ford can get a few days under it's belt, we'll see a low 6:5X or even a 6:4X time because I honestly believe this car is capable of it, it should be faster than the GT3RS.
Present BMW: 2023 M2 BSM W/Carbon everything, 6 Speed
Past BMWs: 2020 M2C HS Executive, 6 Speed
2017 M3 YMB Executive, 6 Speed, ZCP
Everything else: 2024 Wrangler 4Xe
2020 MK 7.5 GTI
clutchdj2167.50
Efthreeoh19688.00
      12-11-2024, 11:48 PM   #46
RM7
RM7's Avatar
3057
Drives: Camaro SS 1LE
Originally Posted by ///MPhatic View Post
Remove the straights and see a different result.
No.
Normally, I hate on Mustangs pretty heavy because Ford is just not serious about making them serious competitors, kind of living somewhere where they don't have the HP of a Mopar and they can't turn or brake like a Chevrolet. But that specific Boss was none of those things. They kick ass pretty well at autoX because of that watts-link and are not the terrible turning car you'd think they are.
Current: 2018 Camaro SS 1LE, 2023 Colorado ZR2. Former: BMW 428i Gran Coupe.
      12-12-2024, 05:54 AM   #47
M4Tejas
M4Tejas's Avatar
1081
Drives: 22 G82 M4xDrive
Lightbulb
Originally Posted by RM7 View Post
That was a very special car. It had a solid axle. But it was not the solid axle that came on the other Mustangs. Watts link. Unfortunately a very bad transmission, but if the weak points there were fixed, a very capable car.
Never seen a Ford Boss 302 with a factory installed Watts link. Had a race prep 2012 5.0 for 11 years. Aftermarket, yes available. It did have the Torsen diffy.
https://www.cortexracing.com/what-s-a-watts-link
2022 M4 Comp xDrive Aventurin Red Metallic
https://wieninger.de/ Seit 1666
      12-12-2024, 07:48 AM   #48
No.
Prove it.
      12-12-2024, 09:43 AM   #49
BlkGS
BlkGS's Avatar
3682
Drives: BMW X5 M50i
Prove it.
By the same token you have no proof for your statement.
Boss 302 pulls 0.9 g on a skidpad on garbage P Zeros. E92 pulls 0.96 with Sport Cup tires on. Boss 302 Laguna Seca pulls .96 g on the same garbage P Zeros.
Independent rear suspension makes the e92 a little less of a handful, but it doesn't really handle any better.
      12-12-2024, 11:32 AM   #50
      12-12-2024, 02:46 PM   #51
BlkGS
BlkGS's Avatar
3682
Drives: BMW X5 M50i
So what was the Mustang that hurt you?
      12-12-2024, 03:57 PM   #52
RM7
RM7's Avatar
3057
Maybe what I was seeing was aftermarket, because we were checking out the underside at the races.
So I may be wrong about that from the factory. But again, overall, it was a very competent car, not "held back".
      12-12-2024, 09:42 PM   #53
None of them. I actually have quite an affinity for Mustangs, but I absolutely realize they are quite the blunt instrument compared to a BMW. It is what it is. I also don't think that outright speed is everything, otherwise I wouldn't have bought a Lotus. To each their own.
