BIMMERPOST Universal Forums Site Related Announcements - Suggestions - Feedback - Questions Can't access Bimmerpost through internet
      05-16-2025, 11:33 AM   #45
cMbg
Drives: M340i G20
Having issues accessing this forum as well. From my desktop it doesn’t work at all anymore, also not when connected via VPN, public or private. It works from my mobile, which is on the same (home) network. But sometimes when I’m on mobile data, it does not. From a virtual machine connected to a public VPN it works. I don’t know what was implemented, but it’s quite a mess…
      05-21-2025, 08:51 PM   #46
Franksierra
Drives: Bmw e90
Same, since a couple of weeks, I was not registered so I didn’t know what to do. I had to register from my phone to post this 😅
      05-22-2025, 01:20 PM   #47
robertni
Drives: 2020 M340i
Same issue here.
I have not been able to access bimmerpost for a few weeks now, I just assumed the site is down or closed. I kept trying from time to time with no luck, until today when I forgot my work-provided VPN on and it worked. After deactivating the VPN it stopped working again. I can access it just fine through my VPN connection, but not through my home network.
      05-24-2025, 05:31 PM   #48
Bulldog33
Drives: Bmw f31 pre lci Touring
Same issue here in UK. Not connecting with WiFi after messing with settings of my router not knowing what I was really doing. Using 4g mobile to access on phone . Pmd you Apptest. Cheers
      05-25-2025, 09:09 AM   #49
apptest
all I do is test!!
apptest's Avatar
4684
Drives: I lost count of how many
Hi I never got your pm. Can you resend?
Test 23456rt
      05-26-2025, 03:43 PM   #50
Bulldog33
Hi,I seem to be able to connect now through my own WiFi but if you want to confirm anything?
      05-26-2025, 04:48 PM   #51
GolfCoyote
GolfCoyote's Avatar
1529
Drives: 2024 M3 Comp xDrive
Interesting the people are having trouble connecting with no VPN, but when I use my VPN it gives me issues.
2024 M3 Comp xDrive
2023 Mach-E Premium AWD
      05-27-2025, 12:00 AM   #52
NealfromNZ
NealfromNZ's Avatar
New Zealand
1081
Drives: 2016 F80 M3
For a while I’d get locked out on USA Sundays without fail from home address ( overseas user ) . It would take 12 hrs to three days before the “connection refused” would clear. Suspect possibly load related and credential check timing out. Got hit by cloud flare blacklist also which I find amusing , looks like it can be overly sensitive if it’s not tuned.
But there is also a couple of ip address reputation tracing services that frankly should get off the internet which feed some of the protection providers which could be contributing to cloudflares blocking of legit users.
Eg , try this site and put your ip into the end of the url https://www.ipqualityscore.com/free-.../222.153.73.12
Looks like everyone in my suburb has a score of 58 out of 100 including my own ip ( that’s not my ip btw ) . These company’s are giving low scores to entire ISP address ranges and then on selling services to major cyber protection suppliers.
Meanwhile looks like Nigeria IPs is a great and safe place from a reputation pov
https://www.ipqualityscore.com/free-.../197.255.160.6
Go figure 🤷‍♂️
      06-05-2025, 12:35 AM   #53
streborx
Drives: 2022 BMW X7 M50i
Access halted again 2 days ago. Starlink update installed an hour ago restored access. Third time this has occurred.
LuckyBrand2300.00
      06-05-2025, 08:02 AM   #54
streborx
Access inhibited again, but can still get through using VPN connection. Fixing things that aren't broken usually breaks them.
      06-13-2025, 07:46 AM   #55
zinner
zinner's Avatar
Drives: `17 X5 35d/`15 335i/`18 M550IX
i got blocked from my isp, ting north carolina. just appears ping http/https are blocked at a protocol level. not sure the solution to autoban ips or the reasons but fairly confident my ip isn’t compromised, but if you have examples i will investigate my logs.
