06-04-2009, 12:48 AM | #45 |
Rep 5,945
reading all the replies. If I'm thinking correctly, the OP is probably as lost as some of the other members reading this. I think we took it a bit overboard....however, you guys do have nice setups. I just need to send in this GTX280 for the step up to the GTX295 soon....it'll be hard without a PC for a week or two
However, I think Nvidia is releasing the GTX300+ soon along with the GTX290 |
06-04-2009, 09:21 AM | #46 | |
One cam is enough
136
Rep 6,801
SOME games are starting to utilize more than two cores, but for the most part, an E8400 E0 (They are all E0 stepping now, thank God) at 4.0GHz will be more than enough. My favorite setup that I have is my E8600, which clocks very nicely. It's a bit pricey, and the E8400 and E8500 are better bang for your buck for sure. If you're OC'ing, the RAM is one thing that I would not skimp on for sure.... If you're going quad, but don't want to fork over the $$ quite for an LGA1366 system, go with the AM3. They're really AMD's best effort in quite a while, and you can get DDR3 support as well. DDR3 has come down a ton in price too. Best advice would be to go to overclock.net, and do a whole bunch of research, look at recent build logs and proposed builds, and make your decisions based off of that. Truth is, just like these cars, it's all about what flavor you want and how much you're willing to spend. For under $1k, you can build a system that will fly through everything out there right now, and for $3k you could build a monster that is a few months further ahead. Things you don't want to skimp on are the case, PS, and hard drive, simply because when it's time to upgrade the system in a year or two, more than likely these will still be great (especially the case). Mobos, procs, RAM, and GPU's come and go, but those other items can save you from having to build an entire new beast from scratch. |
06-04-2009, 10:41 AM | #47 | |
Rep 133
Keep an eye out for the new 300 series from Nvidia - it may not be as good as hoped from what I'm reading. |
06-04-2009, 01:10 PM | #48 | |
Rep 1,201
Marty i'm still waiting on how much you can sink into your rig |
06-04-2009, 05:14 PM | #50 |
Rep 5,945
how much did you spend?
also, why not grab another 1TB and go raid 0? the system I built for my brother is flawless just might be a bitch to get the raid drivers if your mobo didn't come with any |
06-04-2009, 05:30 PM | #51 |
Rep 1,209
06-04-2009, 05:52 PM | #52 |
Rep 5,945
06-04-2009, 06:22 PM | #53 |
Rep 1,201
Get cables and a few other things and hook up the two IDENTICAL hard drives together under system enter RAID-0.
06-04-2009, 08:28 PM | #54 |
Rep 133
Raid 0 = Two HD's or more with files spread OVER the two drives.
Benefits = Faster File Access. Drawbacks = 1 Drive Fail means BOTH fail - data is spread over BOTH drives and you're now up the creek unless you have some good back ups. Raid 1 = Two HD's or more with the SAME files on each drive. Benefits = 1 HD fails, doesn't matter, you have mirror copy on your other drive, redundancy is your friend. Drawbacks = Loss of capacity - i.e. you have 2 1T HD's, but now only 1T of storage as they are BOTH the same HD. With HD's cheap as can be these days, Raid 1 is the way to go - the speed of Raid 0 but without the risk. |
06-05-2009, 10:11 AM | #55 | |
One cam is enough
136
Rep 6,801
