BIMMERPOST Universal Forums Off-Topic Discussions Board What kind of sunglasses/shades do you guys wear?
      05-21-2010, 05:29 PM   #45
Mr Tonka
is probably out riding.
Mr Tonka's Avatar
Drives: Something Italian
Originally Posted by FredVMI View Post
The statement about cheap lenses being potentially as good as expensive lenses for UV protection is accurate; however, UV protection is only one element of a good lens.
The main advantage of a polarized lens is that it contains a special filter that blocks intense reflected light from flat surfaces (roads, water, etc), which ultimately means a reduction in glare. Filtering light is much preferred over blocking light. This is because a lens that simply blocks light eliminates what you want to see in addition to what you don't. With this in mind, try a simple comparison. Select a couple of glasses with polarized lenses and without. Viewing through the polarized lenses will appear brighter than through the lenses that are not polarized. That's because the polarized lenses are not blocking the desirable light. The result is that you'll see the road (and everything else) better with polarized lenses.
One more note on cheap lenses. While cheap lenses can block UV, they also distort the light that is not blocked or filtered. Cheap lenses are just pieces of plastic with a tint coating. Cheap lenses may (or may not) block harmful UV, but, that's about all they do. Cheap glasses are a great example of you get what you pay for!
I recommend reading the article at the following link. It will definitely answer all of your questions, and then some. Good luck!
http://science.howstuffworks.com/sunglass.htm/printable
Not to mention the longevity of the UV and polarized coatings....
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
http://www.m3post.com/forums/signaturepics/sigpic59612_1.gif
      05-21-2010, 05:59 PM   #46
KiokenM3
KiokenM3's Avatar
92
Drives: LIFTED JEEP JK!
Persol's for me
      05-21-2010, 08:17 PM   #47
vioaltec
Sasha Fierce
vioaltec's Avatar
Drives: 2009 bmw 3 series coupe
LV Pilote shades, very hot
Vivre, Aimer et Voler
      05-21-2010, 10:13 PM   #48
Serengetis. Four different styles. Couple of them I've had for more than 10 years. Very durable.
      05-22-2010, 04:41 AM   #49
atlpitbull
atlpitbull's Avatar
Drives: 07 Jet BLK E92 335
Gucci and Oakley's (gascan's)
07 e92 Jet BLK 335/JB+/BMS DCI
08 FJ Cruiser BLK/TRD exhaust/TRD CAI
09 BLK C6 Z51/SLP Loudmouth II exhaust/MTI Stg 1 suspension
      05-22-2010, 07:17 AM   #50
Verbiage
Dismembered Member
Verbiage's Avatar
Jamaica
3650
Drives: F80 ZCP 6MT, R55 Clubman S 6MT
Originally Posted by silvergray545 View Post
Link me?
http://www.e90post.com/forums/showth...=175068&page=8
Middle of that page
Originally Posted by CollinsE90 View Post
theres a reason i like both of you...my repost deputies when im not on here
My delivery experience and beach photoshoot here.
      06-09-2010, 04:16 PM   #51
1cleanm6
1cleanm6's Avatar
Drives: M5 comp/Range/i3S
d n g
      06-09-2010, 04:19 PM   #52
jpsum
jpsum's Avatar
Drives: 2010 TSX
