BIMMERPOST Universal Forums Off-Topic Discussions Board How are you passing time and staying entertained during the pandemic?
      04-05-2020, 10:20 PM   #705
Nuckle
Drives: 2023 Defender X
Originally Posted by M_Six View Post
As I mentioned before, I have a 40" 4k TV coming later this week. I was going to bring the shitty 32" Vizio into my office just to have a TV in there. I was planning on using the top of a bookcase where my network gear sits now, once I move that stuff off onto the new shelf unit I have coming. But the bookcase is against the same wall as my desk, so I won't have a very good angle to see my TV. I'm thinking about a wall mount swing arm, but I am downright incompetent when it comes to mounting something like that.
Can you just do the whole stud-finder bit to set up a wall mount swing arm? I just successfully used a new stud-finder to mount some bicycle hangers in my garage, so I'm pretty confident the one I have works. But screwing up the garage wall and screwing up my home office wall are two very different things.
Drill a small pilot hole if you are concerned. If the drill pulls out wood you should be good. I normally trust stud finders but like to start from different places to zero. A new 40" TV should not weigh much.
These also work well in a pinch. There are different sizes and will tell you the weight they hold.
      04-05-2020, 10:21 PM   #706
upstatedoc
I'll get back to you
upstatedoc's Avatar
7547
Drives: blue streak
I just took a nice dump
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/
Countermeasure enthusiast.
Nuckle2282.00
Germanauto9847.50
Murf99314096.50
vreihen1622158.50
King Rudi13079.50
      04-05-2020, 10:58 PM   #707
Just had a chat with my brother in FL who does this stuff all the time. He suggested I find a nice piece of 3/4" plywood (which I have plenty of) and use that as a base for the mount. Easier to mount the plywood to the wall securely and then mount the swing arm to that.
vreihen1622158.50
      04-05-2020, 11:11 PM   #708
Germanauto
Germanauto's Avatar
Drives: Alfa Romeo Giulia, Rosso
Me and like 10 others just got placed on [paid] quarantine for 2 wks due to close contact with a positive coworker.
Besides studying, I'm gonna hit some of those LA canyon roads.
Former
-2008 E90 328 black/brown
-2012 Lexus IS250 black/black
wdb5157.50
      04-05-2020, 11:30 PM   #709
Nuckle
Definitely a safe suggestion but it's overkill and ugly. How much does the TV weigh? I expect it is light.
M_Six19781.50
      04-05-2020, 11:33 PM   #710
True. And he did mention that butterfly bolts would be entirely sufficient for a 32" TV if I got at least some of the mount into a stud and used butterfly bolts for the rest.
That said, I do have a swivel base and I can scoot the bookcase out away from the wall a bit, so I may not need a wall mount at all, which would be ideal. It's not like I plan on watching a lot of TV there. Just the occasional show.
      04-05-2020, 11:40 PM   #711
Nuckle
The panels are so flat now that the load they put on a wall is closer to vertical than horizontal. Put that puppy on the wall and don't look back! I have 5 wall mounted in my house including a 83" that were all DIY.
M_Six19781.50
      04-06-2020, 12:22 AM   #712
jimbobiggens
jimbobiggens's Avatar
Drives: 2013 335i xDrive
If you can get to the other side of the wall, cut into the wall and use right angle brackets to secure the 3/4 plywood ( In my case I used a short piece of 2"X12") to the studs. Then close the hole, repair it, and now you can mount the TV where you want it.
I'm not completely useless, I can be used as a bad example.
      04-06-2020, 01:58 AM   #713
Danlnyc88
Danlnyc88's Avatar
515
Drives: 2020 M4 Comp, 2017 Macan Turbo
its raining in Socal for the next 5 days and I'm going to wash my car.
      04-06-2020, 09:38 AM   #714
King Rudi
King Rudi's Avatar
13080
Drives: Meat Suit
My previous job involved setting up offices once the fiber was terminated. These were(/still are) some of the most used items for me. These two things are invaluable for hanging TV's/large monitors.
Best stud finder ever made - https://www.amazon.com/CH-Hanson-030...6180158&sr=8-4
Toggles - https://www.amazon.com/TOGGLER-SNAPT...6180206&sr=8-6
Between these two, you can slap a TV/Monitor anywhere you want.
Originally Posted by jmg View Post
We're Americans. Leave your logic and science witchcraft out of this! Jesus and guns are all we need.
M_Six19781.50
Hawkeye2065.50
      04-06-2020, 11:05 AM   #715
Yeah, that's what I meant in my other post above when I referred to butterfly bolts. Toggle bolts is the proper term, I see.
King Rudi13079.50
      04-06-2020, 12:26 PM   #716
383vett
383vett's Avatar
Drives: 2018 X3 M40i, 2012 X3 Xdrive35
The house has never looked better. Many small projects that had been put off are now completed. Zipping through my book library.
2016 Z06 Vette, 10.53@132
1984 Vette, 406, 10.23@131
2021 SQ5
      04-06-2020, 04:12 PM   #717
Hawkeye
Hawkeye's Avatar
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
This is the stud finder I trust the most. Even my expensive one is still wrong every now and then (mostly around electricity) although it is nice that it can detect a current behind the drywall to avoid any dangerous drilling.
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4
2017 Harley StreetGlide • Denim Black • V&H Tune
2021 BMW x30i • Phytonic Blue Metallic • Fully loaded
King Rudi13079.50
      04-06-2020, 04:49 PM   #718
Turkish Pickle
Drives: '21 330i xDrive
Currently: reading on the specs of electric toothbrushes. Anyone use the Oral B Pro 6000?
Edit: Ordered it, but let me know if you like/hate yours
      04-06-2020, 05:05 PM   #719
King Rudi
King Rudi's Avatar
13080
Drives: Meat Suit
Same here. I've got 3 high dollar stud finders. Oddly enough, the most basic and cheapest is the best all around in this instance.
      04-06-2020, 05:06 PM   #720
Rmtt
Rmtt's Avatar
Drives: 2011 BMW 128i, 2008 LS3 C6
I have the Philips Sonicare toothbrush Diamond series. It was around $200 when I got it.
But I had also just had porcelain veneers done, so that was what the aesthetic dentist recommended.
With what I paid for the veneers, I didn't want to skimp out on the toothbrush. It's been great though.
Everybody has a gameplan....until they get punched in the mouth.
      04-06-2020, 05:21 PM   #721
I've been using the Oral B 1000 for a few years now. No complaints. My dentist often comments that I must be flossing regularly (I don't) because my gums are tougher now. It does a great job cutting down the plaque as well.
      04-06-2020, 06:29 PM   #722
BMW F22
BMW F22's Avatar
Drives: ///M235i
We spent a few hours a day and a lot of time this past weekend to do hardwood floors for the second story. Lots of work but worth it and a good way to pass the time as well as staying active.
Not sure but reviews seemed great. I ordered a set of 2 from Costco this past weekend for $100. Been using Sonicare last 4-5 years and it’s dying on me (barely holds a charge for a 4-5 mins brushing). Decided to switch to circular brushes and I think they are more effective and better for the teeth and gum.
      04-06-2020, 07:26 PM   #723
rebekahb
Drives: 2020 X5 M50i
I've had quite a few Sonicare toothbrushes & the first model they made lasted the longest. The other 2 have been crap so after this one bites the dust I will have to look into the Oral B.
      04-06-2020, 07:48 PM   #724
Cleaning up my home office so it's presentable for online meetings.
Also bought a 16-port switch to clear up the birds nest of smaller switches and cabling in my office. I have a nice shelf unit coming from Home Depot this week to mount everything on. I figure if this is going to be my place of occupation for a few months or more, it needs to be up to snuff.
Thanks for two reminders. My ~15 year-old rats nest of AV and data cables has been getting on my nerves for a while now. It's probably too much to hope for that Amazon has a pile of super-short patch cables in stock right now.
The second reminder is that I volunteered for a municipal committee, and our first meeting is next week via an as-of-yet undisclosed online meeting system. I have to make at least a half-hearted effort to present a residential-looking background for my computer's camera.
They were kind enough to send me 20+ files, each with hundreds of pages of conflicting municipal, county, and state goals for homework and background reading before the first meeting. Guess I know what I'll be doing for the upcoming 4-day holiday weekend......
M_Six19781.50
MKSixer34164.00
      04-06-2020, 07:54 PM   #725
Really could use a new desk. Not easy at this point getting rid of the old one, though.
      04-06-2020, 08:19 PM   #726
MKSixer
MKSixer's Avatar
34164
Drives: 2015 BMW i8, E63 M6, 328d
2016 M4 GTS (Allotted)  [0.00]
2013 BMW 328d  [0.00]
2007 BMW M6  [10.00]
2015 BMW i8  [10.00]
Bingeing Ozark in the evenings.
Several actors have played James Bond, Sean Connery IS James Bond...
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion.
