BIMMERPOST Universal Forums Off-Topic Discussions Board The BBQ & Grilling Thread
      06-01-2018, 01:57 PM   #771
AlpineWhite_SJ
Drives: 2018 F80 M3 ZCP, 2020 F97 X3MC
Originally Posted by RickFLM4 View Post
I have a smoker in which I use lump charcoal and wood for slow cooking. But for fast cooking like steaks, burgers, chicken breasts, etc., it is hard to beat the convenience of propane. Cooking on charcoal is great but doing it correctly takes time.
Lump hardwood charcoal, chimney starter and paraffin cubes don't take much longer than pre-heating a propane grill. You basically just light it, go inside and finish prep, come back out and distribute the coals and give it a few minutes to bring the grill surface up to temp.
      06-01-2018, 02:20 PM   #772
TheHouseWon
TheHouseWon's Avatar
648
Drives: 2013 M5
Gas grill at 450*. Throw a little lawry's on it and some Maggi sauce before... Perfection every time!
      06-01-2018, 02:20 PM   #773
RickFLM4
RickFLM4's Avatar
Drives: M4
Sorry but that sounds neither convenient nor quick, not to mention disposal when done cooking.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
      06-01-2018, 02:40 PM   #774
Hawkeye
Hawkeye's Avatar
Drives: '07 Z4 Coupe, '21 X3, '16 GMC
Step 1 is get good grass fed beef. For cooking I generally use a cast iron in the oven @ 500 degrees. Letting it sit out for a bit before AND after cooking is also pretty crucial.
2007 Z4 3.0si Coupe • 6 MT • Black Saphire Metallic • PP • SP
2016 GMC Sierra SLT Z71 Premium Plus 4x4
2017 Harley StreetGlide • Denim Black • V&H Tune
2021 BMW x30i • Phytonic Blue Metallic • Fully loaded
      06-01-2018, 02:56 PM   #775
AlpineWhite_SJ
It's 15 minutes, of which less than 5 minutes is hands-on. How is that any slower or more inconvenient than pre-heating propane?
There's not a whole lot to dispose of - you let the coals burn down to ash. You dump out the ash catcher when it's getting full (every other use).
The convenience advantage of propane is overblown and hardwood charcoal tastes better.
      06-01-2018, 03:18 PM   #776
Zara
Drives: 2025 M340i
My mouth started to water after reading this thread..
2025 M340i xDrive /// Dravit Grey - Tacora Red
      06-01-2018, 05:01 PM   #777
stbm5
Drives: 2018 M5 DG
cast iron skillet. coat both side of steak liberally with fresh cracked pepper. add oil to pan. 4 min per side. perfection.
      06-02-2018, 04:23 AM   #778
Dog Face Pony Soldier
2006 TIME Person Of The Year
Dog Face Pony Soldier's Avatar
Drives: M Sport 335i
2014 335i  [9.74]
My favorite method is how Ruth's Chris prepares steak, but I'll use a grill at home more often than not. Depends on the cut, the weather, my ambition, etc..
MKSixer34165.50
RickFLM412081.50
      06-02-2018, 08:11 AM   #779
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
Ever try cooking a frozen steak? It kinda puts the whole 'let steak warm up' concept to bed.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      06-02-2018, 08:37 AM   #780
MKSixer
MKSixer's Avatar
34166
Drives: 2015 BMW i8, E63 M6, 328d
2016 M4 GTS (Allotted)  [0.00]
2013 BMW 328d  [0.00]
2007 BMW M6  [10.00]
2015 BMW i8  [10.00]
Never have. Please explain.
Several actors have played James Bond, Sean Connery IS James Bond...
Sir 7ewis, 7X FIA Formula One World Championship, World Driving Champion. 100 Wins. 101 Pole Positions. 54 Fastest Laps. Actual Rain Master. Leave me to it, Bono. One Race Win in each of his 15 years in F1. Most Laps Led in Formula One. The Centurion.
      06-02-2018, 01:02 PM   #781
TheHouseWon
648
Drives: 2013 M5
I tried grilling a semi frozen steak once and it turned out awful
      06-02-2018, 03:01 PM   #782
2014 335i  [9.74]
I should disclose that I live in a condo and can not use any flame. Major handicap! After fooling with others, I bought the best electric grill my 15A circuit could handle... Kenyon.
https://www.cookwithkenyon.com
      06-02-2018, 04:02 PM   #783
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
https://www.cooksillustrated.com/how...-frozen-steaks
MKSixer34165.50
      06-02-2018, 04:17 PM   #784
boca1
boca1's Avatar
26
Drives: 07 z4 3.0si
sous vide is the only way to cook a steak if you want consistent results every time
https://www.seriouseats.com/recipes/...ks-recipe.html
      06-03-2018, 01:40 PM   #785
2014 335i  [9.74]
How long does it take to cook a steak that way?
      06-03-2018, 01:45 PM   #786
spencers
Isle of Man
199
Drives: Sthrizzle
I like to reverse sear. Always comes out perfect and juicy!
https://www.seriouseats.com/2017/03/...ook-steak.html
      06-03-2018, 04:21 PM   #787
aajjcc
Drives: F82
sous vide and then searing afterwards
      06-03-2018, 04:28 PM   #788
aajjcc
Drives: F82
ya man you definitely need to sous vide. I use anova precision cooker. for steak i prefer medium rare so I set the timer for 2 hours at 130 F and when its done I sear both sides for about a minute on high heat for that crispy finish. comes out perfect every time!
      06-03-2018, 04:54 PM   #789
RickFLM4
RickFLM4's Avatar
Drives: M4
2 hours?! Does it always take that long?
      06-03-2018, 07:43 PM   #790
bbbbmw
Drives: 135i
Originally Posted by MightyMouseTech View Post
Reverse sear, rare. Finish on the BBQ.
Slightly different to this article, I only salt before going in the oven. Once out of the oven, I add salt free Montreal steak spice then sear.
Once you have done it a couple of times, you will not go back. It is so easy, and so easy to get it perfect.
I just tried the Montreal Steak seasoning - it's good. Amazing they developed it in Montreal, Oklahoma.
<OO (llll)(llll) OO>
      06-03-2018, 08:01 PM   #791
bbbbmw
Drives: 135i
Get one of these:
https://assets.academy.com/mgen/25/10441525.jpg
You stuff two sheets of newspaper, or a paper grocery bag in the bottom. Then put charcoal in the top. Set on fire via the holes in the bottom. In less than 10 mins, you have hot coals. Boom - done.
Propane grills should be a capital offense.
It seriously takes like 10 mins til ready
      06-03-2018, 08:39 PM   #792
2014 335i  [9.74]
I've been experimenting with the new Brazilian Steakhouse lately. Good, but I still think Montreal Steak is better. Nice for a little variety.
Tip: Worcestershire Pub Burger is a tasty option for burgers.
bbbbmw2391.50
