HPFP failure FAQ!
01-21-2010, 10:49 PM | #67 | |
Rep 1,938
01-22-2010, 09:08 AM | #68 | |
Rep 341
Broken promises don't upset me. I just think, why did they believe me? |
01-22-2010, 09:19 AM | #69 |
Rep 341
Anyone know if the failure case are more or lesser in Auto / manual ?
01-22-2010, 10:31 AM | #70 |
Rep 1,105
If someone has a connection with the techs, could you ask WHAT exactly is failing in the HPFPs? Piston/cylinder wear? Bearings? Actuator? Swash plate? Until we know this, it'll be very difficult to get a good idea on what could be causing the problem.
01-22-2010, 04:05 PM | #73 |
Rep 13
2000k miles on my 2010 335 coupe .... I have had some long cranks at start up already. I cant believe im heading for failure .... I drove the car real easy for break in period and used Sunoco 93 only. I experienced fuel pump problems when I had a eclipse turbo and I finally fixed it with a stock Supra fuel pump ..... I wish there was an easy solution for the n54.
01-23-2010, 08:32 AM | #74 | |
Rep 390
I believe I have mentioned this several times....this HPFP is very minor for those of us who love the cars so much and so lucky that we only have to replace it once so far. I understand for those that continuously have multiple failures, it is unacceptable and I already listed the options in number 8. I guess what I am trying to say is we all are tired of hearing users complaining about HPFP failures; thus, I created this FAQ to provide additional information and in the hope that we won't have to see users posting the same thing over and over again. Cheers! |
01-23-2010, 10:24 AM | #75 | |
Rep 175
For me if I have to Lemon so be it - I'll gladly take my money back and jump in a M3. |
01-23-2010, 01:59 PM | #76 |
Rep 24
I also suspect the ethanol might be causing these failures. It is more corrosive than gasoline. And I don't think they use ethanol in Europe.
2007 E92 335i Manual 6-speed
2002 E39 540i Manual 6-speed - gone 2000 Z3 Roadster Manual 5-speed - gone |
01-23-2010, 06:05 PM | #78 |
Rep 1,938
The failure is related to the way the fuel is delivered in the N54 engine, so it does not depend on the transmission type. It may look as if there were more frequent problems on AT cars, since there are more of them than cars with manual transmission.
01-23-2010, 06:08 PM | #79 | |
Rep 1,938
01-25-2010, 09:02 PM | #80 |
Rep 3,460
To the people that say "we love our x35 blah blah blah, I'll live with it" I do not understand how you can say this? If you have a modded car, you have to remove everything to bring it in. I had a fully bolted stage 3 meth 135, pump failed, brought it back to stock to get the pump replaced. Got the pump replaced, and pretty much didnt put the mods back on. Eventually i put on a tune and meth, pump failed. The first pump started cranking at 12,xxx miles, replaced at 18k, the second pump started cranking at 22k, now it has 24k and is going to the dealer this week. This car is the reason I will NEVER buy another BMW. I can buy a KIA and have less problems. This will be my 6th dealer visit in 12 months of ownership. That is insane.
BTW 09 135 6mt feb 09 production date |
01-26-2010, 04:17 AM | #81 |
Rep 6
Thanks for the info.
My brand new 335i started cranking 3-4 seconds on cold starts last week with around 1.8k miles on the odometer. I am still driving the car up until now as if it is still within the "break-in" period, so the cranking was quite alarming. I grew suspect of a larger problem brewing and found this thread and learned of the issue for the first time. It's really unfortunate that I didn't do my research before buying the car. Some specifications: - 2010 335i E90 Sedan - Built: Sept. 2009 (in Germany) - Purchased: December 12, 2009 (w/ 7 miles on odo.) I'm sure you're all tired of hearing about new people with the same problem. I just wanted to let buyers and future customers be aware that this issue still exists in the new makes. Save yourself the trouble and wait for a solution! Seems like these cars are being built to fail. Last edited by set0; 01-27-2010 at 11:11 PM.. Reason: Wrong build date! |
01-26-2010, 07:52 AM | #83 | |
Rep 390
1. Don't have a fully modded car (I don't) 2. They don't mind removing the parts or they don't care about warranty or their cars no longer have warranty and they would go fully modded. |
01-26-2010, 08:13 AM | #84 |
Rep 406
Any reason why BMW just doesn't do an across the board recall for these? Seems like that would eliminate much of the stresses and hassles associated with a fairly common problem.
Specs: '16 340i|6sp MT|Silver Metallic|Black Leather with Oyster Highlights|Aluminum Hexagon Trim. Options: M-Sport|Cold Weather|Technology|Track Handling|Power Rear Sunshade|Driving Assistance |Driving Assistance Plus|Lighting|Harman Kardon|Surround View Pics of my car |
01-26-2010, 02:33 PM | #85 |
Rep 15
Shaky seats, Leaky fluids
Even the New York Times is reporting on this. Here is from Jan. 21, 2010 -
BMW Some 2007-8 335i, 335xi, 535i and 535xi models with the twin-turbo 6-cylinder N54 engine may develop a fuel pump problem that results in extended cranking time when starting or the engine control system defaulting to fail-safe mode. In T.S.B. 130309 issued on Nov. 1, BMW said it would extend the fuel-pump warranty on those cars to 10 years or 120,000 miles, from four years or 50,000 miles. http://www.nytimes.com/2010/01/24/au...emc=wheelsema4 |
01-28-2010, 01:56 PM | #87 | |
Rep 57
... SI B 13 03 09 Fuel Systems January 2010 Technical Service This Service Information bulletin supersedes SI B13 03 09 dated November 2009. designates changes to this revision SUBJECT N54 Special Limited High-pressure Pump (HDP) Emissions Warranty of 10 Years/120,000 Miles MODEL MY 2007,2008, 2009 E60, E61 – 535i, 535xDrive with N54 engine MY 2007, 2008, 2009 E90, E92, E93 – 335i, 335xDrive, 335Ci, 335CixDrive, 335Cic with N54 engine MY 2008, 2009 E82, E88 – 135is with N54 engine MY 2009 E89 – Z4 sDrive 35i with N54 engine MY 2009 E71 – X6 xDrive 35i with N54 engine SITUATION BMW has become aware of a potential problem that could affect the durability of the High–pressure Fuel Pump (HDP) of certain MY 2007, 2008, and 2009 BMW automobiles equipped with N54 engines. We estimate that only a small percentage of vehicles will actually develop a problem. Vehicles affected may have the Service Engine Soon lamp illuminated with various low fuel pressure-related faults (e.g., 29DC, 29F1, 29F2 ) stored in the Engine Control Module (DME). Also, the affected vehicles may experience an extended engine starting time ("long crank") or reduced engine performance ("engine failsafe mode") when the High-pressure Fuel Pump malfunctions. CORRECTION In the event that the High-pressure Fuel Pump of an MY 2007, 2008 or 2009 3 Series vehicle (335i/xi Sedan/Coupe/Convertible), MY 2007, 2008 or 2009 5 Series vehicle (535i/xi Sedan/Sports Wagon), MY 2008 or 2009 1 Series vehicle (135is Coupe/Convertible), MY 2009 Z4 sDrive 35i, or MY 2009 X6 xDrive 35i equipped with the N54 engine exhibits the symptoms listed above, it should be replaced with the improved part (P/N 13 51 7 592 881). For HDP diagnostic and replacement instructions, refer to SI B12 55 06 and RA 13 51 017, found in BMW TIS. IMPORTANT: Since Monday, October 19, 2009, a Part Replacement Authorization has been required (via submission of a TC Case) for replacement of the N54 HDP Pump on E82, E88, E89, E60, E61 and E71 vehicles. For details related to the "N54 Fuel System TC Action", refer to SI B13 08 09. PARTS INFORMATION Part Number Description 13 51 7 592 881 HDP High-pressure Fuel Pump 11 61 7 547 242 Profile manifold gasket kit 13 53 7 582 770 ASA bolt M8x17.5 |
