06-11-2018, 11:10 AM | #67 | |
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
07-24-2018, 07:28 AM | #68 |
Rep 842
03-01-2019, 01:09 AM | #70 |
BimmerPost Supporting Vendor
446
Rep 1,659
Yes. It will clear.
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers /// Project ML-10 Survey |
03-01-2019, 06:31 AM | #71 |
Be Original.
267
Rep 523
03-01-2019, 06:37 AM | #72 | |
Rep 259
Instagram: @m_rochen
Alpinemss Tuned | Tecnocraft E9X ///M3 Envy™ Intake System | MS Pulleys | Akrapovic Evolution Exhaust | Ohlins Road&track| BBK Brembo 6p Front & Brembo 4p Rear| H&R Stabilisator| Solid subframe bushings| full spherical bushings| Recaro pole position |
03-01-2019, 09:43 AM | #73 | ||
Rep 6,734
'23 X7
Rochen_00351.00 |
03-01-2019, 01:44 PM | #74 |
Rep 1,005
Drives: GMC Sierra
I think the BBS MRF spec RI-A in 18" clears Brembo 380 kit. Si???
We grow food to feed the animals so we can eat the animals
03-02-2019, 09:06 AM | #75 |
Rep 6,734
The RIA does not clear Brembo 380. I have had bbs check caliper diagrams. It's very close and there is a possibility that they could be made to fit with brake hardware modification.
'23 X7
Timujin352.50 |
01-11-2020, 01:57 PM | #77 |
Rep 2,824
Bump.. does the RIA clear the Brembo 380s in any spec? Wondering if it’s an offset issue or barrel issue. iND says they’d fit here: https://www.m3post.com/forums/showthread.php?t=1413685
01-11-2020, 09:42 PM | #78 | |
Rep 6,734
'23 X7
01-11-2020, 10:28 PM | #79 | |
Rep 588
thx |
01-12-2020, 01:35 PM | #81 |
Rep 6,734
There's a bolt protruding in the rear on Brembo 380 caliper. It can be modified to improve clearance
'23 X7
01-12-2020, 04:02 PM | #82 |
Rep 5,967
romero1990175.50 |
01-13-2020, 10:17 AM | #83 |
Rep 2,824
01-13-2020, 11:04 AM | #84 | |
Rep 6,734
'23 X7
02-13-2020, 09:44 PM | #85 |
just another M3
514
Rep 1,152
Couldn't find a definitive answer. Does Stoptech 380 6 piston fit under bmw m260 wheels
///M3... Don't want more power, Just want it to turn sharper one step closer each time. -Ohlins TTX Raceline, PolePostions seats, Akrapovic EVO, ARC-8, 1/2 Cage, Seat Delete, Stoptech BBK, solid Subframe and diff bushing, spherical bearing on everything.
03-30-2020, 10:39 AM | #88 |
Rep 259
Finally I would like to comment that I found a combination that I like and pound with 18" 260M oem wheels.
- Front: 6p Porsche 997 GT3 mk2 brake caliper + bmw M4 oem front rotor 380x30 - Rear: 4p Porsche 997 Carrera 4s 3.8 Petrol + bmw M4 oem rear rotor 370x24 Only need a 10-12mm spacer
