05-02-2022, 04:03 PM | #67 |
Rep 64
Mine was assembled in March, and I've had it for nearly a month. I've driven 603 miles and have not noticed any noises like this. Driven over enough rough surfaces to have become annoyed with the runflats and replaced with different tires
05-03-2022, 07:04 AM | #68 |
Rep 202
My sounds like a hollow, barely audible thump/bump coming from the rear - possibly from under the boot somewhere. Barely noticeable, 1 in 5 drives and certain condition, low speed, right sort of undulation in the road, no stereo or rev's, etc.
It is a super stiff car so I attribute it to that. If it's an issue or can be corrected I'm sure BMW will do so in time and I'd be disappointed if a recall or retrofit wasn't available to us early adopters. For now, it doesnt bother me at all. I love this car, I enjoy driving just as much as my 2021 Porsche 911 4S - that's saying something. |
05-07-2022, 12:02 PM | #69 | |
Rep 147
Drives: 2022 M240iX
I sure hope someone from BMW reads this thread.
BMW #9: 2022 M240ix (Dec 2021) BMW #8: 2022 330iX (Dec 2021) Past: 320iX, M550iX, M235iX, 335iX, two Z4, 540i |
05-14-2022, 08:27 AM | #70 |
Rep 202
It appears there is a BMW Repair Bulletin for the G42 (originally for the G26) out that may be the root cause and fix for this issue;
Service Information Bulletin RATTLE NOISE FROM TAILGATE B51 04 22 [SI] March 2022 SITUATION When driving over rough road surfaces, a rattle noise is present from the tailgate. Cause CAUSE Interference of the tailgate stop pad wedging element. Measure MODEL E-Series Model Description G26 4 Series Gran Coupe CORRECTION Apply anti-friction coating. PROCEDURE 1. Clean the stop pad wedging element (circled) using cleaner R2 P/N 83 19 0 417 324 or a suitable ethanol/water mixture. Allow the cleaner to dry. 2. Apply Berucoat AK 978 P/N: 83 19 2 358 109 anti-squeak paint to the wedging element. Allow the anti-squeak paint to dry for 8 minutes with the tailgate open. 3. Close the tailgate and retest the vehicle. PARTS INFORMATION Part Number Description Quantity 83 19 0 417 324 BMW Group R2 Brake Pedal Assembly Aid - (500 ml) Sublet as necessary 83 19 2 358 109 Anti-squeak paint Berucoat AK 978 (100 ml) Sublet as necessary CLAIM INFORMATION Covered under the terms of the BMW New Vehicle Limited Warranty for Passenger Cars and Light Trucks. Defect Code: 5124403900 Tailgate wedging element Unpleasant noises Only one Main work flat rate labor operation code can be claimed per workshop visit. Labor Operation Description Labor Allowance 51 99 000 Work time to apply anti-squeak paint (Main work) 4 FRU Or: 51 99 000 Work time to apply anti-squeak paint (Plus work – Vehicle is already in the workshop) 2 FRU And, as needed: Sublet – Bulk Materials (RO and Claim Comments Required) Sublet Code 4 See the sublet reimbursement calculations below Reimbursement for the repair-related bulk materials (Do not use the BMW part numbers for claim submission) Sublet reimbursement calculation for claiming the applicable repair-related bulk materials (BMW part numbers) is at the dealer net price amount for the quantities used plus your center’s handling. Enter this material cost in sublet and itemize the amount on the repair order and in claim comment section. Based on which one applies to your center, please refer to SI B01 01 20 or B01 07 20 for the applicable procedure for documenting, claiming, and explaining, on the RO and in the claim comments, your diagnosis work time (WT), job/repair work time (WT), and the vehicle repairs your center performed, unless otherwise required by State law. QUESTIONS REGARDING THIS BULLETIN Technical inquiries Submit feedback at the top of this bulletin Warranty inquiries Please contact the Warranty department by either using the Live Chat that’s available in the Warranty Documentation Portal or through IDS by selecting Coverage, Policy, Coding Questions and Mileage Corrections Parts inquiries Submit an IDS ticket to the Parts Department Validity information Service Information Bulletin Metadata Model series: ALL Engine range: ALL Body style: ALL Fault codes: Last edited by BeemerBaron; 05-14-2022 at 08:35 AM.. |
05-25-2022, 01:09 PM | #71 |
Rep 30
All I hear...
Heard this sound from day 1--description as a subtle "loose shock mount" is right on. Didn't help that the GF "didn't hear anything".
Problem is, now that is ALL that I hear every time I get in the damn car. Not that it is loud, but once heard, I can't unhear it--even way in the background. Seems pretty innocuous, but still--shouldn't be there. Only about 900 miles so far, but annoying as hell. Looking forward to seeing if a solution is found. Frustrating. ps--where is the mythical "wedge" referenced in the service bulletin? would love to try and adjust/whatever that. Thanks. |
dszpiro53.50 |
05-25-2022, 02:30 PM | #72 |
Rep 147
Drives: 2022 M240iX
I know what you mean - I hear it constantly too! The only solution I have found is to take the care out on the highway and drive very fast.
jmelaw32.00 Giovany_249.00 |
05-26-2022, 04:52 AM | #74 | |
Rep 615
05-27-2022, 05:35 AM | #75 | |
Rep 202
Very odd. It seems BMW are aware of a sound in the M240i but haven't referenced a fix correctly in the Bulletin as yet. |
jmelaw32.00 |
07-05-2022, 03:43 PM | #76 |
Rep 597
So strange I’ve come across this post! I’ve been complaining about this in my car and thought it was the lowering springs I’ve installed around 2k miles ago.
Going to check them anyway but interesting to hear it could be this too! |
07-06-2022, 09:45 AM | #77 | |
Rep 202
TBH I hardly notice the thump it doesnt bother me at all, it just reminds of how stiff the chassis is on this machine |
07-06-2022, 11:26 AM | #79 |
Rep 358
“Ride comfort on the open road is good too, absorbing large obstacles with a muted thump and covering up small ones almost completely” - Motor1
https://www.motor1.com/reviews/54838...rst-drive/amp/ |
Rickbollocks12.00 |
08-10-2022, 09:57 AM | #80 |
Rep 30
Softball(s) in a wooden box in the trunk?
[QUOTE=Value;29081878]“Ride comfort on the open road is good too, absorbing large obstacles with a muted thump and covering up small ones almost completely” - Motor1
Not related to "large obstacles". In fact, it's at small amplitude/lower speeds that it's present. Thought about it and, while kind of "loose shock mount" sound, it's more like a softball in a wooden box in the trunk bouncing around. Anyone get any resolution/resources for this? STILL driving me nuts.... |
08-10-2022, 10:58 AM | #81 |
Rep 5
I contacted my local BMW Service Center in MA this week. They said they have had no service bulletins or have heard other complaints about this issue. This may be because there are just not a lot of 22 240's out there. They asked me to bring it in, which I will. While the noise is a tad annoying, I can live with it but is it causing additional damage to surrounding components is my question!
08-16-2022, 12:33 PM | #83 | |
Rep 30
Thinking of selling this car--not for this reason, but it's damn annoying and doesn't endear the car to me. Maybe if my OCD wasn't so bad I wouldn't be bothered...... |
08-28-2022, 02:22 PM | #84 |
Rep 24
Did anyone solve this problem? After 2000 km this issue appeared in my M240. In next week I will deliver my car to dealer for inspection. but maybe you found a solution before.
09-01-2022, 09:36 AM | #86 |
Stupid Idiot
134
Rep 827
Yeah… I’m only at 2500 miles, but it’s still there. I’ve just learned to ignore it at this point. It’s pretty irritating if you’re fixated on it, but otherwise it’s a fairly minor complaint. I pretty much gave up on trying to fix it after I drove another car that made identical sounds.
I’m keeping an eye out for new service bulletins or advanced information from BMW, but nothing as of right now. |
jmelaw32.00 |
09-13-2022, 12:56 PM | #87 |
Rep 24
Solved
My dealer fixed this problem. There was something wrong with boot lid. For sure it was not a suspension. Driving without this annoying noise... priceless |
Giovany_249.00 |
09-13-2022, 02:01 PM | #88 |
Rep 615
