05-08-2015, 10:50 AM | #68 |
Rep 2,371
Ever since I did that, I have not had a single problem with the scraping noise, so yeah, rather than waste your time going to the dealer and hoping for a fix from BMW, just do a 5 min DIY procedure.
2015 Black Sapphire Metallic 6MT M4
05-24-2015, 09:52 AM | #69 |
Rep 62
I second that. The pot hole repair in the NY/NJ/CT area is off the hook. Those little pieces of gravel get caught behind the heat shield constantly causing that scraping sound. I had one of my wheels off yesterday clearing it out for the third time in a month. Word of advice when you're doing it. Not only pull the heat shield away so that the offending piece of gravel will drop out but, also check on top. There is a little crease or, valley where small bits of gravel can collect.
02-20-2016, 01:41 PM | #70 |
Rep 3,688
Drives: 2021 Supra 3.0 (Past: 2015 M23
The single worst thing about this car
So I've had my car for almost 2 years and 20k miles. It's been awesome. Pretty much problem free except for one thing... The damn "rock in the wheel" that noise is horrible! And can stay for days and in my latest case weeks ?
02-20-2016, 03:02 PM | #73 |
Rep 1,794
Drives: 06' E90 330, 20' F97 X3m
That's sucks man. Have you tried going in there w your hands and pushing the shields away from the rotors? The rocks usually drop out after that and the noise is gone. Well known issue w these cars. Ive read a thread about how there's supposed to be a tsb fix w new dust shields but don't think it's in full swing. The CCB issue is worse w the rocks getting stuck between the rotor and wheel and cutting grooves into the inner barrels of the rim. Bad designs all together
LIVE FAST..DRIVE FASTER!! |
02-20-2016, 03:08 PM | #74 | |
In The Rain
8234
Rep 6,290
Drives: '24 GT4RS, '24 Macan GTS
I left my girl with them for a few days and got her back and I have had this rock issue since. I think the 2016 cars have this fixed already, it's the first year adopters that have to deal with it now.
'24 Porsche Cayman GT4RS Arctic Grey "Alice"
'24 Porsche Macan GTS Dolomite Silver "Gina" |
02-20-2016, 03:17 PM | #75 | |
fuck this field
2193
Rep 2,605
02-20-2016, 03:40 PM | #77 | ||
In The Rain
8234
Rep 6,290
Regardless there should be a service bulletin for this on F80/F82.
02-20-2016, 03:45 PM | #78 | ||
Rep 2,135
2016 F80 | MG/SO | DCT | Adaptive M Suspension | 19" Black 437M Wheels | CF Roof | CF Trim
02-20-2016, 04:33 PM | #79 |
Useful Idiot
1330
Rep 1,777
Drives: My wife and kids insane.
Yup, pretty exhaustive thread on this too (for those of you new to the forums and/or car.....
It's been around since the beginning, and only marginally improved with the new brake shields. Problem still exists, however..... http://f80.bimmerpost.com/forums/sho....php?t=1052226
02-20-2016, 05:31 PM | #80 |
Large Member
951
Rep 1,749
I haven't had one since I got the updated shields installed. And the reason they don't tell you about the SB is because the bulletin requires them to install new bearings which obviously costs $$$$.
2008 E92 M3 (Engine swap completed), 2015 F82 M4
02-20-2016, 06:40 PM | #81 |
Rep 11,764
Drives: 2018 M4 Comp Indv
02-20-2016, 06:41 PM | #82 |
IG@i.am.wah
2780
Rep 3,815
Drives: M2 CS
Yours is quiet. This was mine a month after picking up my car. I have since had the service bulletin done, and haven't had as big of a problem, but rocks still get stuck in there from time to time.
02-20-2016, 07:22 PM | #83 | |
Rep 395
Had less then 300 miles when i heard a rock get thrown around the brake/shield area. I was like "Oh crap... That does sound scary when it picks up rocks." |
02-20-2016, 07:28 PM | #84 | |
Roofless & Ruthless
1356
Rep 1,480
Drives: 2015 AY 6MT F83
Well if that's the worst thing, that's not too bad.
Just push the little heat shield thing back a bit - rock almost always just falls right out.
02-20-2016, 08:25 PM | #85 |
Rep 2,134
I've had some pretty loud experiences with mine, always in the rear. If I can stop and get out I will and bend the heat shield away from the rotor. If I can't get out I just grin and bear it, it usually goes away relatively quickly.
02-20-2016, 09:23 PM | #87 |
Rep 400
I've had mine done but occasionally I'll still get rocks caught in the brake shields. Super annoying and frustrating. It doesn't always happen but when it does it's annoying lol
IG: @gin_master
2018 M3 Atlantis Metallic | AWE | KW | ///M Performance| RKP | MRG Race Co. | BM3 | RW Carbon | KlassenID 2015 M3 Alpine White III | Gone |
02-20-2016, 09:25 PM | #88 |
Rep 573
had the rock issue once. but it must have fallen out, noise only lasted a few seconds, thankfully! I read so much about it here on the forum that when it happened I knew exactly what it was. why not pull over and give the dust shield a lil tap and the rock should fall out?
Instagram: @coloradom3
