BIMMERPOST Universal Forums Off-Topic Discussions Board Home maintenance tips or home trickery
      12-02-2021, 08:49 PM   #67
upstatedoc
I'll get back to you
upstatedoc's Avatar
7549
Drives: blue streak
Originally Posted by vreihen16 View Post
If your garbage company is using automated trucks to lift the cans, fill the bottoms with water for ballast and they'll never know.....
No automated trucks. These are hard-working fellas. But they won't lift the cans if they're over a certain weight…
2018 Stinger GT
2009 E90 N51 /Active Autowerke Stage 2 tune/BMW Performance Exhaust/
Countermeasure enthusiast.
vreihen1622630.00
      12-02-2021, 09:15 PM   #68
RickFLM4
RickFLM4's Avatar
Drives: M4
https://forsalebyinventor.com/produc...sh-can-anchor/
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82
      12-03-2021, 10:59 AM   #69
OkieSnuffBox
Drives: '13 135i
Ugh, I don't even want to imagine the foul smell coming from trash fermenting in the water. It's obviously hotter much more of the year than it is up there. It's December and we are still running the AC.
      12-03-2021, 10:07 PM   #70
Not so much a trick, but I recently bought expanding foam tape to seal up the outside door jamb on our 3-season porch. The door has never fit perfectly and you could see daylight through the jamb. The expanding foam tape worked as designed and filled the gap. Then I used window sealing tape over that to seal around the entire jamb. The difference in warmth on the porch is astounding. We have an oil circulating radiator out there that used to be effective down to 30F outside temp or so. Anything lower than that and it was just too cold to keep the inside porch door open. This year, since I sealed the door, we've kept it open when it's been in the low 20's outside. The heater keeps the porch at a comfy 65F or so. I'm kicking myself for not having done this years ago.
      12-04-2021, 01:21 AM   #71
mc-m3
Drives: 2006 X3, 2015 Panamera
bar soap (don't recall the brand) got Hawaii red dirt stain out of a white shirt.
