01-08-2009, 06:59 PM | #67 |
![]() ![]() 268
Rep 1,414
Drives: 2008 BMW 550i
+1 on this. . .need that info also.
01-08-2009, 07:25 PM | #68 |
you know he kills little girls like you
![]() 403
Rep 892
A quick google search indicates that some folks have had success with these router settings:
radio mode: 802.11n (802.11b/g) channel: 11 multicast rate: 5.5Mbps Also, make sure you're up to date on the firmware on both devices. Once you get that working with WEP, I'd advise dumping WEP and moving to WPA or WPA2 if possible. You can do both WPA and WPA2 on the Airport Extreme simultaneously, or just use WPA2 exclusively. I don't know if this is compatible with the PS3, but WEP is *weak* protection. Good luck man! |
