04-26-2023, 12:08 PM | #67 | |
![]() 3632
Rep 1,774
Water is also cheap out here believe it or not... A new pool pump is $3000 depending on which model you pick (that's installed) So if you have a lawn and maintain that - a pool is the same price. |
04-26-2023, 12:26 PM | #68 |
![]() ![]() ![]() 4303
Rep 5,740
Drives: 2019 M2 Competition
solar panels
pool bbq alexa things |
04-26-2023, 12:26 PM | #69 | |
![]() ![]() 883
Rep 1,122
Drives: Lots of BMWs
Garage List 2018 M4 Vert [0.00]
2006 Z4M Roadster [0.00] 1995 540i [0.00] 2008 BMW M5 [0.00] 2019 i3 Rex [0.00] 2021 X7 40i MSport [0.00] |
Yeah water, electricity, and NG are surprisingly cheap in Utah also. If nothing went wrong for me and all I needed was utilities plus chemicals I could be at your 100/month. But I know many areas in the US have much higher utility costs, friends in MA, CT, NY, RI are paying about 200/month in utility costs to run their pool for 4-5 months.
2008 M5 6spd, 1995 540i 6spd
2018 M4 Vert Comp, 2019 i3 120ah REX 2021 X7 40i MSport, 2006 Z4M 6spd |
04-26-2023, 12:42 PM | #70 | ||
sportscars only
![]() 3564
Rep 3,280
That's an interesting one, did you explain why besides you don't think you have any expensive stuff lying around and are insured?
![]() Did you see post #53 and others? Seems like there are varying opinions on what it actually takes to maintain a pool. Quote:
The richest one percent of this country owns half our country's wealth, five trillion dollars. One third of that comes from hard work, two thirds comes from inheritance, interest on interest accumulating to widows and idiot sons and what I do, stock and real estate speculation...It's bullsh*t. I create nothing. I own. We make the rules, pal...Now you're not naive enough to think we're living in a democracy, are you buddy?
04-26-2023, 01:09 PM | #71 | |
![]() ![]() ![]() ![]() ![]() 2167
Rep 970
TIA.
2018 F80 M3. YMB/BLK. ZCP. Three Pedals.
"Education will never be as expensive as ignorance." |
04-26-2023, 01:11 PM | #72 | |
![]() ![]() 6124
Rep 2,111
Been dreading having to get a pool heater. I saw this one thing that supposedly uses the heat coming off your AC unit to heat the water. So it's basically practically free heating, at least for as long as the AC is running. |
04-26-2023, 01:19 PM | #73 | |
![]() ![]() 6124
Rep 2,111
Got a smaller newer model coleman for the NC house for around $200. Works pretty much the same, just slightly smaller, not green, better design for the control panel. Then recently Walmart had that same smaller coleman for under $200 so I picked that one up to replace the big coleman that was starting to look a bit run down and the older control panel design was starting to peel off in the FL sun. I like this latest one because it has wifi so I can up the heat from anywhere if I feel like using it later that day or night. I believe it's this one: https://www.walmart.com/ip/Coleman-7...e&athbdg=L1103 But they are all pretty much the same I think. Wait for a sale I see them all the time for $200ish or less. |
DocL2166.50 |
04-26-2023, 01:45 PM | #74 | |
![]() ![]() 883
Rep 1,122
If you have a pool house or shed close there are solar options to do cheaply, friend did this, only good if its not shaded. For our next house I may find other options especially if I can't get a NG line, my current 400k BTU heater uses a lot, if propane I would need a massive tank for the house or weekly delivery fills.
04-26-2023, 01:49 PM | #75 | |
![]() ![]() 6124
Rep 2,111
04-26-2023, 02:32 PM | #76 | |
![]() 7018
Rep 3,373
04-26-2023, 03:42 PM | #77 |
![]() ![]() 883
Rep 1,122
My house has NG for tankless water, grill, 2 kitchen cooktops, furnace, fireplace, & pool. August my NG usage was 50 CCF, Sept 225, Oct 230. Definitely did not have the house heat on in Sept/Oct so the majority of that was pool heater. 1 CCF = 100 cubic feet = 1.2 gallons. So lets say I used 200g of NG in Sept & Oct, google says propane can provide double the BTUs per CF, so maybe its not as bad as I thought. Sept & Oct would of been maybe 100 gallons of propane each month.
I definitely run the pool heater more than I should, but will be more cognizant of it this year not believing the family when they say they will be in it a lot during Sept & Oct as those gas bills last year were scary.
04-26-2023, 03:47 PM | #78 |
![]() 7018
Rep 3,373
There's the issue, wife says to heat it then its a few degrees colder than forecasted and she still won't get in. She makes great money but fuck me she can waste it.
04-26-2023, 04:24 PM | #80 | |
![]() ![]() 6124
Rep 2,111
![]() We have a 350 gallon propane tank for stove, water heater, grill and furnace. We are in FL most of the winter so the furnace rarely gets used. I don't think we've used those 350 gallons in the 2 years we've owned it. However at $3.28 a gallon which is what Google says is average price of propane in NC... that's $328 for 100 gallons... $328/month is kinda steep. That's higher than my entire electric bill and water combined. This is what I was talking about that's suppose to use the heat from your AC unit. https://www.hotspotenergy.com/pool-heater/ |
04-26-2023, 04:39 PM | #81 | |
![]() 15366
Rep 3,491
We live in a low crime area for both violent crimes and property crimes. In our lives we've never had an incident. We've never had a neighbor have an incident that we know of. For us, the chance of having a problem is not worth the hassle and the stress of running a security system. If something does happen, that's what insurance is for. In the unlikely event of a violent crime, it's not clear to me that a security system would make the situation safer anyway. Others may have a different position on this matter. That's okay. |
tranquility3563.50 |
04-26-2023, 04:49 PM | #82 |
![]() ![]() 883
Rep 1,122
Our wives might be identical twins lol
04-26-2023, 04:56 PM | #83 | |
![]() 3632
Rep 1,774
I have 3 panic alarms in various places...all hardwired and encrypted. |
04-26-2023, 04:57 PM | #84 | |
![]() 3632
Rep 1,774
04-26-2023, 05:00 PM | #85 | |
![]() ![]() 883
Rep 1,122
We'll you'd prolly use 1/2 or less than my bad use case. If you knew you were going to use it on a weekend could just run it starting on Friday at $5-10/day. I am really lazy about optimizing my systems use, everything automatically starts at 8am and runs till 9pm, think the heater is set to 84-86 so it runs until that temp. Even when its 100 degrees days on end the nights in July are usually 60s, so the heater runs in the morning even on the hottest days. I really should manage it better.
Thanks, will have to add that AC unit thing to my wish list for next house build looks like a great idea, with my current house the pool equipment & AC condensers are on opposite ends, connecting would be a nightmare. Quote:
04-26-2023, 05:00 PM | #86 | |
sportscars only
![]() 3564
Rep 3,280
sygazelle15366.00 |
04-26-2023, 05:03 PM | #87 | |
sportscars only
![]() 3564
Rep 3,280
04-26-2023, 05:11 PM | #88 |
![]() ![]() ![]() ![]() ![]() 1208
Rep 727
