BIMMERPOST Universal Forums General Automotive (non-BMW) Talk + Photos/Videos Still want an EV? (NO POLITICS)
      09-01-2024, 12:41 AM   #9109
BlkGS
BlkGS's Avatar
3688
Drives: BMW X5 M50i
Originally Posted by RM7 View Post
Well that's the thing, your useful hydrogen density for a fuel cell is still thousands of PSI and even better, they still require a supplemental hybrid drive (battery) because fuel cells don't do well with accelerations. So you are going to burn to death and blow up.
...yeah, you wouldn't run a fuel cell as a drive power source. You would run it as a charge source, the fuel cell generation the electricity needed to keep the battery charged. You'd still run a battery pack of several kwh, and you'd use the fuel cell as a charging source, just like you'd use a hydrocarbon powered generator on something like Ramcharger.
But you're right - the reality is the safest solution is to just burn some overall inert hydrocarbons in a generator to charge that battery while you go. Even better if you can use a biofuel, like an algae derived biodiesel. There's been some amazing work on that where the algae could in theory use more CO2 to create their biofuel than burning it would release. That's got the added benefit of actively removing all that pesky CO2 we are worried about.
What would truly be a wonderful product would be something like Ramcharger with a diesel generator to charge the battery. Because of how well diesels handle high load vs gasoline, they're a perfect fit for a high load application like this, so you'd use significantly less fuel to charge the vehicle.
      09-01-2024, 03:35 AM   #9110
Originally Posted by BlkGS View Post
There is no reason to not have a plug in though. If you never use it no big deal. If you do, cool that's less gasoline burned.
Have you watched the electric consumption meter shoot up when you plug in your hybrid, takes around six or more hours to charge just standing there, to 100% from zero and doesn't give you that many miles.
eugenebmw2218.50
      09-01-2024, 08:06 AM   #9111
pbonsalb
Drives: 18 F90 M5, 99 E36 M3 Turbo
Isn’t RAM doing this now with the gas 3.6 as the generator? Why did they pick the gas engine? Doesn’t Dodge have a 3.0 diesel? Diesel might weigh more if it’s an iron block and the gas is aluminum.
      09-01-2024, 08:15 AM   #9112
pbonsalb
That is partially the case. There are about 17,000 hydrogen cars in the US, all in CA. What the article below does not say is that the price of hydrogen has gone way up in the last few years and people are paying hundreds to fill the tank, which is good for only several hundred miles. However many buyers received a big credit with the car to buy hydrogen to incentivize buyers.
https://www.caranddriver.com/features/a41103863/hydrogen-cars-fcev/
      09-01-2024, 09:48 AM   #9113
Efthreeoh
Drives: The E90 + Z4 Coupe & Z3 R'ster
I can think of cost as a reason.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
      09-01-2024, 11:22 AM   #9114
BlkGS
BlkGS's Avatar
3688
Drives: BMW X5 M50i
The EPA has essentially regulated most small diesels off the market. Regulatory issues aside (and the fact that it went out of production for like 2023), the eco diesel was an expensive engine, and the pentastar is not. Pentastar gets used in everything and is mass.prodiced to the extreme.
Ramcharger will probably start at like 65k for a basic ass truck. It would have likely gone up to like 70k with eco diesel. Which would have killed it before it started for a base truck.
      09-01-2024, 06:30 PM   #9115
BlkGS
BlkGS's Avatar
3688
Drives: BMW X5 M50i
The cost to add charging for a small battery is negligible. $100 tops.
      09-01-2024, 09:19 PM   #9116
tturedraider
tturedraider's Avatar
Drives: 2018 340i M Sport
I would completely disagree with that. I’ve actually been a fairly big fan of the 330e. I haven’t driven a G20 330e, but I’ve driven an F30 330e quite a few times. As I think about it I may have driven a G20 330e once at a BMW driving event. Anyway, I always enjoyed driving the F30 330e and was always pretty impressed with its performance. I’ve always driven one with juice in the battery. I live in a condo with garage parking where I could not easily charge a plug-in hybrid. My parking space is close to a storage room and I even considered whether I could run an extension cord from there to my car, but I knew I would run into a Karen or two who would unplug it. I even posted a thread on F30Post asking opinions and, of course, the overwhelming response was “no, don’t do it” and quite a bit of discussion about hauling around dead weight if I drove it uncharged and losing mpgs if I drove it in self-charge mode with the motor charging the battery. So, I would say there absolutely is a reason not to have a plug-in hybrid if you don’t have an easy way to charge it.
https://youtu.be/-ay-8p2p29w
www.bmwcca.org
member #388003 - Use me as a referral
& you could win a one day ///M Driving School!!
___________________________________________
M5Rick71641.50
Efthreeoh19703.00
eugenebmw2218.50
      09-01-2024, 09:40 PM   #9117
BlkGS
BlkGS's Avatar
3688
Drives: BMW X5 M50i
Whoever told you that was... To be blunt, an idiot.
Yes, there's a weight penalty, but there's also a "free thrust" from the electric motor to compensate. If you can't charge it, then it's just a hybrid vehicle, regenerating power when you decelerate. Now of you can't charge it, you'll likely never see an ROI based on fuel savings, and that's what really matters (I wouldn't buy a PHEV in your case either) but you're not going to use more fuel in a PHEV that isn't charged.
That said, I think you missed the context of my comment. My comment was "it makes no sense to have a fairly large hybrid battery that is not a plug in". For example, if the 330e had an optional charge port, everyone would buy that option because not having it would be stupid, and it would have no downside except being a $250 or whatever option.
Caveat, a lot of peop.wpuld buy it without the charge port because they would assume the charge port came standard.
      09-01-2024, 11:09 PM   #9118
dreamingat30fps
Drives: Miata, Cayenne, Model 3, F350
Meanwhile it would be of no interest to me since I can plugin and prefer to do so. I highly doubt you would even notice the weight. Then again I would just go for a BEV instead of a HEV since one of my favorite things about my BEV is never going to the gas station.
And this is why they make different cars for different people.
      09-02-2024, 12:53 AM   #9119
tturedraider
There is no reason not to have a plug in though. If you never use it no big deal. If you do, cool that's less gasoline burned.
Where did you say that?? I went back to see if you said something before the quote I responded to and I couldn’t find anything.
Just how much regenerative power do imagine is produced when braking?
I’m not sure what “optional charge port” you’re referring to.
Is this what you are talking about?
www.bmwcca.org
M5Rick71641.50
eugenebmw2218.50
      09-02-2024, 02:56 AM   #9120
^ I'm a bit confused at the 'optional charge port' also, all hybrids should have them as standard, can't just rely on engine and braking to charge the lith battery.
eugenebmw2218.50
      09-02-2024, 07:06 AM   #9121
pbonsalb
Not all hybrids plug in; those without have less range. Not sure it’s all regenerative braking though that certainly helps — a more powerful alternator can help charge a smaller drive battery. https://www.caranddriver.com/news/a46414049/toyota-prius-vs-prius-prime-test-results/#
      09-02-2024, 09:24 AM   #9122
BlkGS
BlkGS's Avatar
3688
Drives: BMW X5 M50i
I was responding to another guy who said he wanted a vehicle with a small battery, electric motors, and a small generator to keep the batteries charged. I said that's basically what a Ramcharger is, and he said he didn't want it to be plug in. I said that's silly not not have a plug in. People said the making it a plug in would make it too expensive.
My point was that if there was a car that had the same battery pack and electric motor, and it was either a regular hybrid, or as an option you could add a charging port, nobody would not buy that option, except for a handful of dummies who thought it was standard.
eugenebmw2218.50
      09-02-2024, 09:27 AM   #9123
Efthreeoh
I don't consider a 15 to 20 kWh battery as small. I think there is more than $100 of added (manufacturing) cost to have a DCFC-capable built-in charging system along with the complexity of an on-board generator system.
      09-02-2024, 09:32 AM   #9124
Efthreeoh
I really don't understand this sentiment. What is so distasteful about "going to the gas station"? And you have several ICEV in your fleet, so you still have to go to the gas station. Not a flame. I just really don't understand what is so off putting about a gas station.
eugenebmw2218.50
M5Rick71641.50
kyriian965.50
      09-02-2024, 10:47 AM   #9125
RM7
RM7's Avatar
3057
Drives: Camaro SS 1LE
Do you still go to Blockbuster to get movies?
      09-02-2024, 11:39 AM   #9126
eugenebmw
eugenebmw's Avatar
2219
Drives: G15 M850i G82 M4, G22 M440
Welcome to Canada
Tesla’s official map of its charging network shows that its Superchargers are noticeably absent in Canada’s northern provinces.
“We are in the Yukon, which is pretty cool because all the chargers are free,” he said in a recent video. “It’s free because it’s one charge post. I waited an hour to be able to plug in here and I will have to change for like two and a half hours to make it to the next charger.”
Before even getting to the Yukon, Bearded Tesla was battling with a charger that was shutting off every five minutes.
Three Tesla Cybertruck Owners Are Driving From Florida To The Arctic Circle And Already They Are Having Problems
https://jalopnik.com/three-tesla-cyb...ida-1851637005
M5Rick71641.50
      09-02-2024, 11:56 AM   #9127
BlkGS
BlkGS's Avatar
3688
Drives: BMW X5 M50i
Same. I get gas at Sam's or Costco. I'm at one, or both, of them at least once a week .taking an extra 5 minutes to get gas before or after getting groceries is super easy and convenient.
Efthreeoh19703.00
eugenebmw2218.50
M5Rick71641.50
      09-02-2024, 12:55 PM   #9128
eugenebmw
eugenebmw's Avatar
2219
I fill up my G82 yesterday only take 6 mins. It is good for another 500km of joy ride.
M5Rick71641.50
      09-02-2024, 03:27 PM   #9129
dreamingat30fps
I would have said the same until I owned an EV.
Is it the worst thing in the world? No. These are all first world problems as they say, but if I want to take the miata out in the morning to go for breakfast up the mountain and I get in and see it doesn’t have enough gas. Now I have to stop what I was going to do to go to Walmart or what not to put gas before I can do what I wanted. Maybe it takes 10-15min extra to get there put gas etc… not a big deal, but when I’m in FL for the winter where I basically only drive the Tesla and I come back to NC where I have 3 ICE vehicles I notice how much I actually dislike it. Again it was something that surprised me when I got my Tesla how much I disliked having to put gas. Would have never guessed at that being a benefit until I experienced it.
gblansten2565.00
dfox1444.00
      09-02-2024, 04:00 PM   #9130
tturedraider
Thanks for the answer. And the other two questions?
www.bmwcca.org
