03-03-2014, 08:30 AM | #89 | |
Rep 549
F80 M3 SO/SO |BM3 St.1 91 oct.|Cattless DPs|Tractive P'n'P|Brembo 6pot|Rays G25 with CUP2 tires|GTS coding|
1M VO FBO (KW DDC) PTF st.2+ sold e90 335i FBO jb4 sold |
03-03-2014, 09:34 AM | #90 | |
Rep 5,396
both need to be changed ideally. I wouldn't do it any other way
03-03-2014, 09:36 AM | #91 | |
Rep 5,396
doesn't mean much. you are fooling yourself if you think some basic, and pretty cheap OEM replacement shocks have anywhere near the tech or quality of bilstein race components. its not a comparison worth making again, in order to get a suspension that can deal with all road conditions well (ie not ride stiff / rough on regular roads or a bumpy track) you need to spend a lot of money. the money is all in the shocks. KW v3 is not enough for my taste. substantial road comfort compromises are made, ones which make the m3 less enjoyable aroiund town, and that is not a sacrifice I would make. I would leave it stock (which I will do) or go for a proper kit with higher quality dampers.
03-03-2014, 12:21 PM | #92 | ||
Law Enforcer
25302
Rep 22,324
03-03-2014, 01:15 PM | #93 |
Rep 2,997
Everyone knows:
1. Lower = better 2. Wheel gap = not a true racer 3. A stock suspension = never as good as what an aftermarket company can offer for $1-2.5k .... The best blend I've ever seen on a stock sedan was an Audi RS4. The fenders bulged out OVER the tire, allowing for significant travel while visually looking both attractive and minimizing wheel gap. However, the rear wheels at least had enormous travel for a showroom-race-car. Mind-boggling travel. And suspension travel is an excellent thing on a tightly sprung car, as it allows the tire to be forced down into the surface even as the weight of the vehicle has been elevated. |
03-03-2014, 01:40 PM | #94 | |
Law Enforcer
25302
Rep 22,324
You guys take this stuff beyond serious. Ever consider that people just prefer a certain look despite whether or not it causes a reduction in the overall performance of the vehicle? These are street cars after all......street cars that will spend 90% of their existence within (..or just aft of) posted speed limits. |
03-03-2014, 01:41 PM | #95 | |
Rep 348
WTB: 2016 M3 sedan, Black Sapphire, Extended Sakhir Lether, Ceramic Brakes, 19" black wheels, Lighting Package, HK sound, USB/Bluetooth
Sold: 2006 e90 325i 6MT, ground control coilovers, Remus exhaust |
03-03-2014, 01:42 PM | #96 |
Law Enforcer
25302
Rep 22,324
03-03-2014, 02:04 PM | #97 | |
Rep 5,396
problem is when people belive that lowering the car with springs will "ride like stock and handle even better". that is pure BS people are free to do whatever, but they should realize that by lowering the car with anything but the highest of quality equipment (and even then, still small compromises made) the car will be compromised. that's a fact
03-03-2014, 03:42 PM | #98 |
Rep 4,319
Please tell me this was sarcasm as well...
GT3 RS | Desperately seeking the next great M car...
03-03-2014, 09:43 PM | #99 |
///M Enthusiast
31
Rep 357
Drives: '12 F30, '15 x5 5.0, '15 M4,M5
So oem over coils? Probably not going to track, but being able to lower your car would be nice.. Unless i replace the springs.
03-03-2014, 11:39 PM | #100 |
BimmerPost Supporting Vendor
9608
Rep 10,891
As a disclaimer:
I'm writing this off the cuff, and skipping around. This is by no means a thorough or complete document, and is meant as an overview and fuel for discussion only. With that said, allow me to go on a bit of a rant: There is a set amount of variables to adjust with any car, whether it is a race car or street car. Many of those variables, with respect to chassis tuning, play against each other and must be adjusted to an optimal functional medium. I might be able to make a post that will elaborate a bit on the issues suspension designers consider, to give folks an idea of what's involved in creating a good OE or aftermarket performance suspension. Among the variables that engineers might consider, we can discuss
Many of these variables are very closely connected- changing one will compromise the other, and vice versa. Balancing these variables to create a good handling car is the art of suspension tuning. Geometry The term geometry typically refers to not only the base alignment of the wheels when the car is in a static position, but more importantly to the varying lengths and positions of the suspension arms. Varying the design and lengths of the suspension arms can affect a tremendous amount of factors, but essentially the designer is chasing after just one thing- keeping as much of the tire in contact with the road as possible during all conditions- braking, acceleration, cornering, bump, and droop. There are a myriad of designs to choose from, and the benefits and drawbacks of each possible layout can create enough discussion to fill a textbook (and often does). As we change the lengths and relative positions and mounting points of the suspension arms we can affect the sweep of the arms through space as the suspension moves through "bump" and "droop" positions (up and down, respectively). In doing so, we can determine various important characteristics of the suspension: camber curve and camber gain (the amount of camber the tire will have as the suspension moves away from it's static position, and how this camber will change progressively as the tire moves up or down inside it's wheel housing), toe curve and toe gain (the amount of toe the tire will have as the suspension moves away from it's static position, and how this toe will change progressively as the tire moves up or down in it's wheel housing). Many other factors exist, when discussing suspension geometry itself, but we'll focus on camber and toe in this discussion. If you're interested in researching some other areas, you can read about:
These, and literally hundreds of other factors can all be manipulated by simply changing the shape, location, and mounting positions of the suspension arms and components. Fortunately, all of these items are outside the scope of our discussion, with the exception of camber and toe. Center of mass Center of mass is relatively self explanatory. Each car has a center of mass, or an average point that is the midpoint between all of the masses in the car. When engineering a car, however, "mass centroid" is more relevant. Mass Centroid divides the car into many slices in the longitudinal direction, and allows us to locate the center of mass in that particular slice. This is useful because in a front engine car, for example, the engine's center of mass is much higher than the center of mass at the differential. Because most of the weight in the rear of a front engine rear drive car is located very low, the mass centroid at that particular location is also substantially lower than it is at the front of that same front engine car. This is very useful information, and we'll relate this to roll center, later. Roll Center Roll center is a virtual (but very real) point, about which the car will roll as cornering force is applied. As the left and right suspension are both firmly attached to the chassis (at least ideally), when cornering force is applied one side of the suspension will compress, and one side will droop. The point about which the chassis rolls as a result is called the roll center. It should be noted that both the front and rear suspensions have their own roll centers, which are determined by examining the respective geometries of those suspensions independently. It should also be noted that as the suspension moves, the roll center will change and "migrate", and so is only the roll center at that particular instance. Spring Rate Most cars are suspended by metal springs, wound into coils. Springs maintain a given ride height and geometry, while also allowing for compliance and movement of the suspension over road irregularities. Spring rate is typically measured in KG per MM, or LBS per inch, meaning that a typical spring measurement will show the amount of force necessary to compress a spring a given distance. For example, a 500lbs/in spring will compress 1 inch when a 500lbs force is applied. It is important to note that when a spring is compressed and released, it will oscillate unless a damper is there to control it. Roll Stiffness and Roll Moment All this nonsense finally brings us to roll stiffness, where we can relate a few of the above factors and see how some variables interact. Roll Moment is literally a moment, in physics terms. A roll moment is determined by obtaining a distance measurement between the (front or rear) suspension's roll center and the location of the mass centroid at that particular location. The larger the roll moment, the more the car will roll as it takes a corner. Two notes-
Roll Stiffness is the measure of the car's ability to resist roll. We typically refer to roll stiffness only as a factor of spring rate, and do not usually take the size of the roll moment into account, when making basic suspension setup decisions. A very soft spring will not do much to resist body roll. As cornering force is applied and the roll moment does it's job, the spring will compress with relatively small forces, and your grandmother's Cadillac will rapidly raise one side of the car while wildly compressing the other, in an exciting display fit for 80s action movies. A stiffer spring will resist these cornering forces to a greater degree, and keep your BMW M4 flat through the corners. Sway bars or anti roll bars also provide roll stiffness, and allow for a car to resist roll. We'll get back to why this is important later. Damper Valving Dampers are what keep your spring from oscillating. If you've ever seen a very old car bouncing up and down on it's suspension after driving over a bump, you've seen a car with non-functional dampers. We'll discuss why this is a problem later as well. Tuning suspension dampers is a science in itself, and good tuning requires the use of some expensive testing equipment and some very clever engineers. Fortunately the more reputable companies have the basic valving figured out for you, and leave only the fine adjustments to you. I won't discuss any more specifics of damper valving here, but we can leave it at this- entire books have been written about dampers alone. Compliance In order to maintain a tire's contact with the ground, a suspension must be compliant. That is to say, a suspension must adequately absorb road irregularities by allowing for the tire's movement. Compliance is typically achieved by using adequately soft spring rates, but this comes at a compromise, which I promise we will discuss soon. And now, without further ado.... The Big Picture The big picture is, that the job a suspension engineer is incredibly complex not simply because they must spec a car to the manufacturer's liking, but because meeting their goals involves juggling and compromising many variables that are in absolute conflict and opposition with each other. Allow me to give you some examples- Compliance keeps your tire in contact with the road, so compliance is good, right? This means that we should use a soft spring. One of the negative consequences of using a very soft spring is that you cannot adequately counteract cornering forces. What you get is body roll, followed by dreaded unwanted geometry change. In simple terms, if you decided that you want 3 degrees of negative camber to keep your tire in perfect contact with the road while cornering, using a very soft spring (and the resultant body roll) will force one side of the car into very heavy compression, and one side into very heavy droop. This means, half your car has entirely too much negative camber, and half your car has nearly none! We do not have good cornering grip, and that just won't do. So we go back to the drawing board, realizing now that unwanted geometry change is our enemy, and we use a stiff spring. We've now lost compliance, and our car's tires are skipping across road irregularities with no opportunity to absorb them! Once again, we do not have good grip. This is just one example of the conflicting variables that suspension engineers have to deal with every day. There are literally thousands of factors to consider, nearly all of them in opposition to all the rest. But Ilia, what is your point? My point is as follows:
Hope that helps!
03-03-2014, 11:46 PM | #101 |
9608
Rep 10,891
Oh, one more thing-
Spring rates typically work best with a given tire. Install a grippier tire, and you'll need to change your spring and damper to suit as forces acting on the car are multiplied. So while the original spring and damper will more than likely suit the original tire nicely, upgrade your tires to sports tires or even r compounds, and it will behoove you to change your springs and dampers as well.
03-04-2014, 05:01 PM | #102 | |
Rep 1,191
The more biased towards racetrack performance a car is, the more useful a 7-post rig becomes. Last edited by Racer20; 03-04-2014 at 07:21 PM.. |
03-04-2014, 06:24 PM | #103 |
Rep 2,104
Pretty useless post. All that's common sense knowledge ever 16 yr old boy racer knows
Seriously, though, I knew it was complicated. But this is another level. Now I'm reconsidering... Do aftermarket manufacturers, like KW, Ohlins, etc. design/test the suspensions for a specific car, in the case of "specialty" mass market sports cars, such as the M3/M4, 911, etc?? Seems like that would be the only way to do it accurately... Also, how does adaptive or passive play into all this, for quality aftermarket suspensions?? And really, thanks for all the info. |
03-04-2014, 06:44 PM | #104 | |
Driving Mika all over California.....
57
Rep 619
2008 E60 M5 Sepang Bronze Metallic, gloss black grills and gills, LED side markers, 12mm spacers all around, stud conversion kit, custom exhaust with Magnaflow mufflers and x-pipe.
03-04-2014, 09:04 PM | #105 | |
Law Enforcer
25302
Rep 22,324
Thank you!!!!! This should help quiet at least some of the detractors. |
03-04-2014, 09:44 PM | #107 |
Rep 1,022
majority of people who fiddle with suspension on vehicles like M3 (where countless hrs were spent by M division professional to set up), end up with worse dynamic vehicle. if it's worth the final esthetics (i.e lower / no wheel gap), than so be it.
I personally think F80 already comes with minimal wheel gap, and at the same time enough clearnace to cope daily driving in LA. Even with all the track times i've spent, i don't even think i can find 10/10 of this car's ability anytime soon anyway. just don't feel the need for "upgrade" in the suspension department. |
03-04-2014, 10:31 PM | #108 | |
Law Enforcer
25302
Rep 22,324
03-05-2014, 02:59 PM | #109 | |||
9608
Rep 10,891
BMW used KW's Clubsport coilover on the M3 GTS, and I have a feeling BMW will continue to use KW on their higher performance models. Quote:
Thank you both so much for the kind words!
03-07-2014, 12:29 AM | #110 | |
Rep 9,034
Let me get this straight... You are swapping out parts designed by some of the top engineers in the world because some guys sponsored by a company told you it's "better??" But when you ask the same guy about tracking, "oh no, I have a kid now" or "I just detailed my car." or "i just got new tires."
