04-27-2013, 11:15 AM | #1168 | |
Rep 1,247
Drives: fat cars are still boats
Location: compensating a fat car with horsepower is like giving an alcoholic cocaine to sober him up.
First of all, I'm talking about a turbo diesel engine, obviously. Secondly, I already showed you that the Volkswagen Bluesport with its 180 hp turbo diesel engine is faster, in a meaningful way, than the Toyobaru with its 200 hp from the NA petrol engine. Thirdly, you can easily go from the actual 150 hp figure of the Subaru boxer diesel engine to 180 hp in order to match the Volkswagen Bluesport engine's max. power, since the max. torque is already the same in both engines (coincidentally, the same 258 lb-ft max. torque present in the Alfa Romeo 4c's turbocharged petrol engine). Now, what is not being told to you is that NOTHING can beat a modern turbocharged diesel engine in terms of performance/fuel economy and emissions ratio when you drive hard, full throttle or whatever, and I mean by a LARGE margin. Forget about hybrids or electric cars... it was already shown in previous posts that the latter do nothing for the carbon footprint if you can't derive electric energy from a 0% CO2 emissions energy source, i.e. nuclear energy (to comply with the actual and future electric energy demand there's no other way available to man for doing it!). And, that's where the problem begins... although we can see them already in motorsports and winning, THERE IS NO DRIVER'S CAR ON THE MARKET TODAY OFFERING A DIESEL ENGINE OPTION. This would be a great chance for the Toyobaru to be the pioneer since Volkswagen, unexplainable, didn't give green light to the Bluesport. It's precisely because I own and daily drive a 1M, with now 41000 km on the clock of hard driving, that I'm perfectly aware of what is getting an average fuel consumption of 18-19 l/100 km and paying in average 1.6 € per 1 liter of gasoline. Just do the math and see how much money I have been throwing out of the window till now and every time I startup the 1M's turbocharged petrol engine. So, the best answer to this is low weight and high low end torque from a turbocharged diesel engine... and if this is not possible then the next best answer is even lower weight and high low end torque from downsized direct petrol injection turbocharged engine, e.g. Alfa Romeo 4c. Last edited by GoingTooFast; 04-27-2013 at 01:53 PM.. |
04-27-2013, 02:48 PM | #1170 |
Rep 1,247
To better understand why hybrid technology is also not the answer we have to realize that low weight AND batteries or high energy storage capacitors are NOT yet compatible for meaningful fuel saving with hard driving, which is what a driver's car is made for - accelerate hard, frequently going through the gears, going WOT, etc...
04-27-2013, 03:38 PM | #1171 | |
Rep 1,247
04-27-2013, 03:54 PM | #1172 | |
Rep 3,888
04-27-2013, 04:45 PM | #1173 | |
Rep 1,247
Also, when I'm talking about the huge amounts of money I spend in gasoline, trust me, the 'induction noise' is the least of my concerns... Finally, the exhaust sound is not only about being loud... it's also about its 'character'. |
04-28-2013, 07:41 PM | #1174 |
Rep 1,247
To better understand the diesel advantage look at the only diesel offering by BMW in the US at the moment (a 328d diesel version with 184 hp will be offered) and just compare it to its petrol counterpart. Despite the huge weight disadvantage of the diesel version (although with a better weight distribution), the lower power output and the 6-speed only transmission when compared to the 8-speed automatic transmission of the petrol version the performance of both versions is remarkably close! What set them definitely apart is the mileage you can get with each of them. And, if you take both versions for a test drive on the same route and drive them hard like a 'true sports car' I can assure you that with the diesel version you will get the DOUBLE of the mileage you will get from its petrol counterpart. GUARANTEED!!!
.................................................. ............ X5 xDrive35i........................ X5 xDrive35d (diesel) Weight distribution, front/rear................. 47.3/52.7 %......................... 49.0/51.0 % Weight Unladen........................................ 4960 lbs............................... 5192 lbs Nominal output hp/rpm........................... 300/5800-6250................... 265/4200 Max. torque lb-ft/rpm.............................. 300/1300-5000................... 425/1750-2250 Top speed (limited electronically)........... 130 mph.............................. 130 mph Acceleration 0-60 mph............................. 6.4 sec................................. 6.9 sec Fuel Consumption City/Highway............. 16/23 mpg........................... 19/26 mpg |
04-29-2013, 04:01 PM | #1175 |
Rep 1,247
People normally don't realize that crashing into a wall that doesn't deform itself even at 40 mph is an hell of BANG!!!
04-29-2013, 05:43 PM | #1176 |
Rep 746
WTF is the point of this thread?
54 pages of pointless drivel and mindless self-hijacking. Whoever paid you to spam the crap out of our board should be fired. Out of a cannon. Into the sun. |
04-29-2013, 06:44 PM | #1177 | |
Rep 1,247
04-30-2013, 05:33 AM | #1178 | |
Rep 1,247
As I've said, NOTHING can beat a diesel engine in performance per mileage AND the important point is... you do NOT need to loose in performance.
To prove you that hybrid technology is only good for fuel saving on slow town traffic and cruising and not for a properly driven driver's car, here are the results of not too much hard driving (min 4:00): Quote:
04-30-2013, 04:31 PM | #1179 | |
Rep 575
05-01-2013, 07:35 PM | #1180 |
Rep 1,247
If Toyota is preparing to give us a hot hybrid version of the Toyobaru with the assumption that it will be more fuel-efficient that way, let me reaffirm that if fuel-efficiency is a real concern and not merely a marketing operation to promote Toyota's hybrid technology which will necessarily sacrifice lightweight in order to accommodate the heavy batteries or the also heavy high energy storge capacitors then if it's all about fuel-efficieny with increased performance NOTHING could be better than a uprated version of the Subaru boxer diesel engine similarly to what Toyota have done to the Subaru boxer petrol engine in the current Toyobaru. Moreover, since both the petrol and the diesel version have the same exact bore x stroke dimensions, 86 mm x 86 mm, the number that gave the name to the Toyota GT86 and the number which corresponds to the exact diameter of the Toyobaru's tail pipes can be maintained!
Just look at the fuel consumption shown on the Toyobaru's computer after a reset when going WOT all the way through the gears to top speed in a downhill (yet a favorable condition) : |
05-02-2013, 05:32 PM | #1181 |
Rep 1,247
The Toyobaru could be the FIRST truly driver's car in the world for street use with a diesel engine and for the planned price of the Volkswagen Bluesport it would be an even greater success than it already is:
05-02-2013, 06:40 PM | #1182 |
Rep 12,446
You really are scraping the bottom of the barrel for material to keep this thread alive.
Past: '08 E92 335i|ZPP|ZSP|6AT
Past: '15 Mustang GT|401A|PP|6MT Current: '20 Shelby GT350|6MT |
05-02-2013, 07:54 PM | #1183 |
Rep 1,247
No, not really... the Volkswagen Bluesport is the most underrated driver's car concept of all times because of marketing reasons and since I've known that Toyota is trying hard to produce an hotter hybrid version of the Toyobaru I can't go without expressing my disapproval and disappointment about such option. The car industry is trying to sell us the false idea that the electric car is the way to go in the near future because of the CO2 emissions. Nothing could be more far from reality until you have a 'CO2 clean' energy source worldwide from which you can derive the necessary electric energy to supply the present world demand, let alone the even higher demand in such scenario! Just look at China and their rapid nuclear energy expansion and yet it will only represent roughly 5% of their electricity needs in 2020. It will take some decades until the electric car can make sense as a 'green' option. And, I'm not talking yet about all the CO2 emissions involved on the electric batteries manufacturing. This is rubbish!!!
An hybrid driver's car is also rubbish... you are only adding weight when you should be reducing it as much as you could - but that is more expensive to perform and that's the real issue - because when you push hard like you suppose to do in a true driver's car the batteries or the capacitors, whatever, can only give you that much of extra power much like the overboost function on the my 1M, it will last what?! 7 seconds... and then nothing until you brake hard again consecutively, so you will be burning a lot of fuel again unless you have a diesel engine. When you drive hard nothing can beat a good diesel engine in fuel-efficiency and performance... nothing!!!! |
05-02-2013, 10:56 PM | #1184 |
Rep 3,622
05-03-2013, 10:09 AM | #1185 | |
Rep 1,247
So, we are back to lightweight and to what makes sense for a driver's car... Renault and Maserati would be more than happy to follow the leader... the BEAUTIFUL Alfa 4c:
05-03-2013, 10:23 AM | #1186 |
Rep 3,888
There is no Maserati based on 4C. It will not come, it is not that car. The car will be less light weight, it will be 2+2 mid-front engined, more an M3 and 911 rival, in fact in between. It could be called Shamal.
05-03-2013, 04:46 PM | #1187 | ||
Rep 1,247
I don't even know if the Alpine will ever see the sunlight, let alone a 4c based Maserati... all I'm saying is it's a nice idea...
Also... Quote:
05-03-2013, 07:16 PM | #1188 | |||
Rep 1,247
