BIMMERPOST Universal Forums General BMW News and Cars Discussion 2023 3.0 CSL BMW prototype spied from every angle [updated with Nurburgring video]
      07-02-2022, 12:23 AM   #111
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
27117
Originally Posted by Onesie View Post
@sedan_clan a few points to add to the conversation (and to sidebar from the ridiculous name calling and whatnot the other poster was doing):
1- you brought up stopping distance. That has nothing to do with brakes. That is all traction. Unless the brakes fade during that breaking, every car has enough brakes to lock the wheels. How far they take to stop depends on the traction the tires have to stop. Stopping distance is immaterial to the floating/fixed piston discussion.
2- when you bring up that few people track their cars, and if they do they upgrade the brakes, you're somewhat making the point that BMW cheaped out on brakes. And they may have used the same logic you did.
I understand you're trying to say BMW didn't cheap out. A fixed calliper is more expensive than a floating single piston calliper. BMW decided to use a single piston floating calliper on a heavier car. If not for cost, what technical reason did they have?
I may have missed your perspective in other posts.
By "cheap out", let's understand BMW used what was necessary to have the car perform as they wanted it to, while making compromises to make the car viable (or else every part would be carbon fibre, for example, cost a fortune and not sell), and lucrative.
By "cheap out", some are making the case that BMW is profiting more now than they did.
Which is industry standard.
An engineer that develops a hub with one less bolt (e.g. from 5 to 4), while saving pennies per wheel, saves the company millions as millions of cars are built. That's how it works. I'm curious to understand how it isn't "cheaper, but it is better". Unless we're splitting hairs here and debating the semantics of "cheapening out". If we agree with this, I think we're all on the same page. Doesn't make the new brakes better though.
Thanks for posting.
  • I agree, and I did account for other things that contribute to stopping distance/ability, including tires, in one of my prior posts.
  • As for BMW's technical justification, I don't have the inside scoop to answer that with any authority. My speculation is/was the floating design they used was sufficient to meet the criteria they set forth. BMW also mentioned their electronic e-brake system is easier to interface with the floating caliper design. Whether or not that's a sufficient answer depends on where you stand on the issue. There are plenty of threads on this forum consisting of members debating this issue/non-issue. This would be a good question to ask the ///M division though. I'm sure some in-depth technical analysis might provide clarity for some and fall on the deaf ears of others (…who will undoubtedly exclaim, "Porsche does it. Why can't you?). I also think it depends on how one frames the question. Did BMW ///M change the set-up to be cheap?….or did they realize there was no justification for going with a more expensive set-up to achieve little gain? Keep in mind we're talking about a two piston rear caliper on the F8X. It's not like we're talking about 4 or 6 pot calipers in the rear that BMW jettisoned in favor of a floating caliper.
I think BMW balanced out the need to provide a better overall car than the outgoing model (…which objectively they accomplished; weight and personal opinion(s) about the aesthetics notwithstanding) while keeping overall costs reasonable. They brought a lot of positives to the table (…e.g. carbon fiber buckets, for example) for not much more expense than the prior model. It all depends on your vantage point I suppose. If you're looking for a reason to be mad at the company, look no further than rear brakes and hood lines. If you're reasonable in your assessments (…speaking generally, not directed at you personally), it's not hard to see that BMW brought a more premium product to the masses than what we got with the F8X. Make no mistake, I loved my F8X's just as much as any ///M car I owned prior, but I do feel the G8X is a step above the outgoing car.
Originally Posted by Ziosella View Post
Originally Posted by Sedan_Clan View Post
I don't own a G82.
We know..under the flag of Brazil it reads "'22 Chalk Gray Porsche C2S".
It's moving that you defend every BMW with such determination...with your regal ass on that gray and ugly thing.
Yes, I have a Chalk 992. No, I don't defend every BMW. I just like to offer an alternative narrative to what's often posted in these threads.
      07-02-2022, 01:08 AM   #112
VIERsr
Drives: BMW M2
Originally Posted by TargaM2 View Post
Don't agree at all, one is merely cosmetic the other is performance related.
If you don't understand the difference between a multi piston caliper & a sliding single piston caliper do some research.
It's simply a cost cutting exercise due to the implementation of an electric handbrake & SOME manufacturers (eg BMW/Mercedes) unwillingness to develop & implement a better solution than simply upping the front brakes stopping power or increasing rotor sizing. Some other manufacturers of performance cars do it properly (eg Ferrari/Porsche).
Yes you can obviously make it work but it's clearly never going to be as good a solution.
ANYONE who can't understand that ask yourself why did BMW feel a need to have multi piston calipers on the rear of the previous F series M cars which were also comparably lighter & less powerful cars…?
Sorry to go off topic but I get tired of the statements by those with zero mechanical understanding that are so willing to swallow & parrot whatever marketing bs they are fed.🙄
I think the one with zero mechanical understanding is you.
We are talking about rear calipers on a street car, since you are so expert you should know what impact this has on performance (nearly zero), the advantage of a multi-piston caliper at the rear is almost irrelevant and it is an unnecessary complication for a street car combined with the e-parking brake (this is the reason, just get informed before you talk randomly). Definitely not something to worry about.
It's funny to read about cost cutting, Bmw could have used more expensive calipers (since they exist) and passed the price onto the finished product and thus onto the customer, but the benefit would have been irrelevant and I thank Bmw for saving me this unnecessary cost (well, in case I had it).
There are much higher performance, heavier and more expensive cars than any Bmw with floating rear calipers, and they brake perfectly.
I have no idea about the final specs of this CSL (I don't even read all the speculation these days, I only trust the official documents that I haven't seen yet), but it is too early to judge.
You only have to drive a G8x to realize how much better it brakes than the F8x's multi-piston rear brake; judging braking performance by the number of pistons in the rear is like measuring manhood by the inches of your tool. Definitely forum bullshit.
Most people wouldn't even know they have a floating caliper at the rear if someone didn't tell them.
Sedan_Clan27117.00
      07-02-2022, 01:20 AM   #113
VIERsr
Drives: BMW M2
Name calling doesn't make your point for you (…talk is cheap coming from anonymous big mouths online; you wouldn't be so cavalier standing in front of me) and I don't own a G82.
We aren't talking race/rally cars with expensive braking systems. We are talking about a performance street car with plenty of braking power for the street and casual track duty. The G82 with a sliding rear caliper bests the lighter F82 with a piston rear caliper in all braking tests. Sure, some of that is larger rotors, etc., but it just demonstrates that a sliding rear caliper set-up doesn't immediately spell doom for performance. Most owners aren't tracking these cars anyway, and if they are, they are changing pads, brake fluids and/or brake systems altogether (..not to mention tires; all of which add up to better braking performance). For a street car, the G8X far surpasses what 95% of its buyers need.
The reason is so simple that it is probably too difficult for such knowledgeable professors to understand.
Bmw figured out where to increase braking (at the front, with a better caliper and wider rotors) and where to use a simpler solution (at the rear) without penalizing performance once it switched to electronic parking brake. They introduced the floating rear caliper back in 2011 with the F10 (first M car with e-brake) and no one complained, while it started to be a huge problem with the G8x for unknown reasons.
It's a win-win: we have a car with better braking performance, lower costs, less unsprung mass, and even better aesthetics (just compare the rear offset of the F8x and G8x).
Sedan_Clan27117.00
      07-02-2022, 01:27 AM   #114
PLF69
PLF69's Avatar
3807
Drives: 2023 M3
It works but can't absorb as much heat obviously. Don't really care it looks smaller, my ego doesn't neither.
Fun/HPDE: 2023 M3 6MT Individual Malachite
Past:2023 M4 CSL, 2022 M4C Vert, 2020 M340i, 2018 M2, 2015 M235i, 2008 135i 550whp
Daily: 2023 X5 45e
Daily/Family: 2021 Atlas Cross Sport 3.6
Sedan_Clan27117.00
      07-02-2022, 01:28 AM   #115
VIERsr
Drives: BMW M2
2- when you bring up that few people track their cars, and if they do they upgrade the brakes, you’re somewhat making the point that BMW cheaped out on brakes. And they may have used the same logic you did.
I understand you’re trying to say BMW didn’t cheap out. A fixed calliper is more expensive than a floating single piston calliper. BMW decided to use a single piston floating calliper on a heavier car. If not for cost, what technical reason did they have?
By “cheap out”, let’s understand BMW used what was necessary to have the car perform as they wanted it to, while making compromises to make the car viable (or else every part would be carbon fibre, for example, cost a fortune and not sell), and lucrative.
By “cheap out”, some are making the case that BMW is profiting more now than they did.
An engineer that develops a hub with one less bolt (e.g. from 5 to 4), while saving pennies per wheel, saves the company millions as millions of cars are built. That’s how it works. I’m curious to understand how it isn’t “cheaper, but it is better”. Unless we’re splitting hairs here and debating the semantics of “cheapening out”. If we agree with this, I think we’re all on the same page. Doesn’t make the new brakes better though.
As far as I know, Bmw does not manufacture or design brakes.
They merely choose which products to use from those offered by suppliers on the market (Brembo, in this case).
Brembo (not Bmw) produces both more expensive and higher performance solutions (multi-piston rear calipers with e-brake integrated) for exotic supercars, and simpler and cheaper solutions for street cars (floating single pot caliper with e-brake).
They could have chosen the more expensive solution and I'm pretty sure Brembo would have been more than happy to sell them, but it probably wouldn't have been worth it considering the intended use, that's all.
Sedan_Clan27117.00
      07-02-2022, 01:57 AM   #116
VIERsr
Drives: BMW M2
Exactly. Thus, more profits.
Of course, they don't do charity. But did we lose anything? I'd say no.
The only M-car with a multi-piston rear caliper was the F8x, which braked like crap just like its single-piston rear caliper predecessors.
The G8x won't go down in history for its braking (the grille steals the show), but the overall braking performance is a step up from its predecessor, and that's good enough for me. Too bad about the aesthetics of that tiny caliper, but whatever.
      07-02-2022, 02:11 AM   #117
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
27117
….and therein lies the rub. On forums, people expect a manufacturer not to profit and any profit the manufacturer experiences seems to rub some the wrong way. They should never buy a Porsche then. That company's profits are off the charts.
I think you're also spot-on with reference to your other point in bold. We lost nothing.
VIERsr2657.00
      07-02-2022, 05:55 AM   #118
tjlees
England
354
Drives: F30 Chav Mobile
Floating rear calipers simplify the cost and packaging when combined with the parking brake.
For street use you won't notice the difference, on my race car it makes a second a lap difference (apparently ;-)) and fade is better.
It also can look look ugly - both ways
      07-02-2022, 11:49 AM   #119
3RDSECTOR
Drives: 330i M-Sport (G20)
Originally Posted by Sublime00 View Post
Originally Posted by Nettles View Post
Originally Posted by Germanauto View Post
MUCH better front fascia. Nobody here was opposed to a more distinctive front end, but what they gave the world is straight trash.
Shouldn't you be banned for saying that
Mods will ban him soon enough. Can't say anything critical about BMW on a BMW forum, lol.
Happened to me. Mods are softer than Charmin toilet paper when you a critique a G8X model.
      07-02-2022, 11:56 AM   #120
3RDSECTOR
Originally Posted by GuyOh View Post
Atleast give it the proper holfmeister kink
Nobody really cares about that just like nobody cares about the revised hood line. That's a forum geek thing.
Not true, but ok.
GuyOh1253.00
      07-02-2022, 12:47 PM   #121
Bumpinjeep
Bumpinjeep's Avatar
Drives: 2023 M2
2023 M2  [8.33]
Just for reference….
…an F82 needed about 151 feet to brake from 70-0 mph. The G82 needs 146 feet to achieve the same thing. Those numbers vary slightly depending on surface, time of day, etc., but overall stopping power isn't affected.
The reason for the initial brake advantage for the G series car is due to the tires.
G series cars have wider (by 20mm) and newer model tires that simply have more grip than the F series M Cars.
The brakes on the F generation cars are just better. The difference is initial braking vs sustained braking. Swap the tires and I would wager the F car will outperform the G car in both initial and sustained braking.
Present BMW: 2023 M2 BSM W/Carbon everything, 6 Speed
Past BMWs: 2020 M2C HS Executive, 6 Speed
2017 M3 YMB Executive, 6 Speed, ZCP
Everything else: 2024 Wrangler 4Xe
2020 MK 7.5 GTI
      07-02-2022, 02:36 PM   #122
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
27117
Not true, but ok.
We can agree to disagree. Most things complained about on the forum are not concerns of the average buyer. If you asked the average person about the Hofmeister kink, they wouldn't even know what you're talking about (…let alone its General Motors origins).
xlover2237.50
      07-02-2022, 02:43 PM   #123
VIERsr
Drives: BMW M2
This is absolutely false.
Front calipers: 2-pieces 4 pot / 380x30mm vs monoblock 6 pot / 380x36mm
Rear calipers: 2 pieces 2 pot / vs floating single pot, same rotors
The brakes on the G80 are clearly better.
Sedan_Clan27117.00
      07-02-2022, 03:43 PM   #124
Sedan_Clan
Law Enforcer
Sedan_Clan's Avatar
Brazil
27117
+1
xlover2237.50
      07-04-2022, 11:10 AM   #125
Garage5
Drives: BMW M3
1999 BMW M3  [0.00]
If it would have a cooler motor than the S58, would have been awesome.
Squeeze a s65b44 in it or a s85 or s62.... that's real homage!
Current:
///More Ms than friends at this point in my life and I am ok with it.
Currently own all 7 gens of the ///M3 = life complete
      07-04-2022, 01:45 PM   #126
seis-speed
#savethemanuals
seis-speed's Avatar
Drives: 1M | GT3 | J392 | G80
If they have this manual transmission, why not do a special run for for the 4-door fans on the G80. Maybe a US spec CS that is not an automatic? Seems like a lot of development cost to just use on one car.
      07-05-2022, 11:37 AM   #127
ThesaVeliona
Starry_Angel
ThesaVeliona's Avatar
Drives: '19 BMW 330i (G20)
Originally Posted by FreshlySnipes View Post
I wonder if this is what the LCI 4-series front will look like...
Are we even gonna get a LCI for 4er?
Girl power is about loving yourself and having confidence and strength from within, so even if you're not wearing a sexy outfit, you feel sexy.
      07-05-2022, 11:47 PM   #128
MadBimmeRad
MadBimmeRad's Avatar
Australia
7139
Drives: M235i, 420i, and now the M2 CS
I certainly am not a BMW officinado by any measure of imagination, but, wouldn't it be going against the grain if you put an 8 or 10-cylinder engine in the car that's meant to be paying homage to the original 3.0 CSL which was a 6-cylinder car?
Afterall, that's one reason this car is only coming in manual transmission.
M2CS,
The second coming of ///M!
      07-06-2022, 05:25 AM   #129
edwinm3
edwinm3's Avatar
Drives: F82
I miss the times when a bmw special model was truly just that, special. I guess I'm getting old lol
Grigio Telesto M4, 6MT.
Coyote 5.0 F-150
991 GT3
kyriian950.50
jp1984516.50
cotmfk2132.50
      07-06-2022, 09:53 AM   #130
KSERGEI-BY
KSERGEI-BY's Avatar
47
Drives: Audi A6 quattro
Im under impression this is just a body kit for a 4 series with some glorified name and rediculous price tag.
e36->f48->....
edwinm31007.50
Cos270608.50
      07-06-2022, 11:52 PM   #131
FreshlySnipes
FreshlySnipes's Avatar
Drives: G80 M3 (MT); G05 X5 45e
No, BMW did a special E46 M3 CSL with the V8 from the E39 M5. There's a video of it on YouTube. Unfortunately they never sold it but it still exists.
‘22 G80 (6-speed) ; ‘23 X5 45e
SEAHAWKS - 12
      07-07-2022, 03:08 AM   #132
MadBimmeRad
Australia
7139
Fair enough. I should have been clearer and distinguish that I meant those that made it to market, not prototyped specimen.
M2CS,
