04-29-2023, 02:58 PM | #111 |
Rep 5,226
04-29-2023, 03:12 PM | #112 |
#buildnotbought
14303
Rep 5,566
Where in the rulebook does it say that it's ok to drive into another car and cause damage and gain a position?
Max left him enough space, and more important, he was ahead and RUS wasn't pushed by someone else. He just drove into him. He (RUS) said it himself, he had no grip, which means he either was going too fast for the line he was driving or he wasn't steering good enough. Having no grip is a drivers error. Surely causing a 50cm hole in the sidepod can't be seen as abiding by the rules... The crash could be seen as a racing incident, but that still leaves RUS to give the position back. But at the start from the next safetycar (later in that same lap) Max overtook him again, so I guess that's why no further action was taken. I guess they're racing different races. Max races for the WDC, RUS has to get points wherever he can, so it's elbows out. But lets see what happens next time when RUS is put in a similar position. Max can hold a grudge like no one.
Z4 3.0i | ESS TS2+ supercharger | Quaife ATB LSD | Brembo/BMW performance BBK front/rear | Schrick FI cams | Schmiedmann headers+cats | Powerflex/strongflex PU bushings | Vibra-technics engine mounts | H&R anti rollbars | KW V3 coilovers/KW camber plates | Sachs race engineering clutch | tons of custom sh#t
04-29-2023, 03:35 PM | #113 |
Rep 1,038
04-29-2023, 03:36 PM | #114 | |
Rep 5,226
firstly did the stewards do anything or noted any of the lap 1 incidents today or other days? when Max was younger he's caused way more damage doing the same thing on lap 1. roles are reversed now. |
04-29-2023, 03:36 PM | #115 |
Rep 1,038
So, I think I clearly missed something. Didn’t Russell not make it out of q2? And he started p4 for the spring? Is the grid order for sprint based on something else, which I completely missed? Haha
04-29-2023, 03:38 PM | #116 |
Rep 1,038
Comparing a teenager with zero regard for really anything, to a presumably more mature (based on race experience) mid 20 something ‘veteran’ with 2 world titles?
04-29-2023, 03:40 PM | #117 | |
Rep 5,226
if not then they let lap 1 go didn't they? don't look at me i'm not the stewards i'm just pointing it out |
04-29-2023, 03:44 PM | #119 | |
Rep 1,038
I personally think Russell was at fault, but there was no malintent. He went into that corner hot, and understeered right into Max, unfortunately. Racing incident. Sprint format is a f’ing joke. |
04-29-2023, 03:46 PM | #120 |
Rep 1,038
Blindside_1377155.00 |
04-29-2023, 03:50 PM | #121 | ||
#buildnotbought
14303
Rep 5,566
So have I (I think most of us here have), but I don't see how that is a valid argument.
You specifically noted that certain rules don't apply in the 1st lap. So I wonder what specific rule you mean that relates to this incident. Quote:
I guess an incident like this is the result of changing the sprint race. The original setup was an alternate way of qualifying for the race where points could be had, but both increasing the points and separating the qualifying bit makes this another race with including risks as drivers might compete or set their chances on the sprint race instead of the main race.
M5Rick71261.50 ///M Power-Belgium72823.50 |
04-29-2023, 04:02 PM | #122 | |
Rep 5,226
04-29-2023, 04:05 PM | #123 | |
#buildnotbought
14303
Rep 5,566
And appealing for a penalty after the race would never result in something that RB or Max could benefit from as he already overtook and finished in front of RUS. So the believe that rules have been violated and appeal for penalty or not are 2 separate things. If RB believed that no rules had been violated they wouldn't have reported the incident.
///M Power-Belgium72823.50 M5Rick71261.50 |
04-29-2023, 04:27 PM | #124 |
Rep 22,723
Evenin' all.
04-29-2023, 04:37 PM | #125 | |
Rep 5,226
in this case i saw nothing wrong horner generally agrees, nothing wrong in turn 1 and turn 2. turn 3 he thought george should have given a bit more room. so no rules were broken here but if you've seen the FIA picture book, the stewards don't always refer to that in lap 1. unless you're Carlos Sainz last week. |
04-29-2023, 04:37 PM | #126 | |
Rep 22,723
///M Power-Belgium72823.50 DrFerry7207.50 |
04-29-2023, 05:02 PM | #127 |
Rep 22,723
Oh Russel DID push Max into the wall, says he lost grip and Max not too impressed with that but Max got past him anyway a few laps later. Roll on the GP.
04-29-2023, 05:13 PM | #128 |
Rep 22,723
No I got it wrong, Russel's wheel gouged a hole in Max's side pod, ahh a racing incident...or was it.
04-29-2023, 06:10 PM | #130 | |
#buildnotbought
14303
Rep 5,566
Thats different than what you said before.
04-29-2023, 06:54 PM | #132 |
Rep 4,426
Unfortunately for George, VER holds a grudge and doesn't forget. There will be payback sooner or later. Just ask Checo.
