03-29-2018, 11:56 AM | #1321 | ||
Rep 2,962
When I was younger I ate a lot junk, and looking back now I can see the difference. I definitely listen to my body and try to rest more because you just can't recover in your late 40s like you did in your 20s. As far as testosterone, I had a blood test last year with my physical and everything was in the normal range, but I don't remember what exactly my levels were/are. |
03-29-2018, 01:02 PM | #1322 | |
Rep 1,149
SLEEP is also huge! You need that time to repair and recharge! 7-8hrs at minimum. Your mattress is essential to this, if it is 8-10 years old get rid of it! If you are not sleeping right that will seriously compromise your results. Start simple and focus on the basics and listen to your body. And do have your doctor check your T levels and blood work. |
03-29-2018, 01:04 PM | #1323 | |
Rep 4,186
Drives: 330i, 135i
03-29-2018, 02:06 PM | #1324 | |
18539
Rep 9,432
7 really isn't enough hours for me, but it's all my life allows at this point. We recently replaced the Tempur-pedic mattresses because they were a bit over 10, and had indentations where we slept. Wife picked out adjustable beds and mattresses that allowed her to stop snoring, in addition to her CPAP. If I kick the dog off, I get a solid 7 most nights, but I can fall asleep in 5 minutes of inactivity at work. |
03-29-2018, 02:12 PM | #1325 | |
Rep 1,149
I would suggest looking into home workouts or a home gym. It eliminates the “having to go to the gym”. It will give you more time to apply to the actual working out. You’d be amazed what you can do at home in a designated space. Plus you can YouTube and google tons of home workout stuff. I have garage gym, regular gym membership and Crossfit gym....I cover all bases. But I use my garage gym the most. Especially having an 8 month old...lol. Time to make some adjustments my man Last edited by FlaPatsFan; 03-29-2018 at 05:21 PM.. |
03-29-2018, 02:15 PM | #1326 | |
18539
Rep 9,432
03-29-2018, 03:09 PM | #1327 | |
Rep 1,149
Lay off the cheese plates at night in bed!!!! Lol |
03-29-2018, 04:23 PM | #1328 |
18539
Rep 9,432
03-29-2018, 05:31 PM | #1330 |
Rep 960
03-31-2018, 07:35 AM | #1333 |
Rep 960
03-31-2018, 09:25 AM | #1334 |
Rep 1,149
People that walk straight in from the parking lot onto a piece of equipment, then complain about injuries!
Ummmm no shit Sherlock...you don’t stretch or warm up!!!! |
03-31-2018, 10:32 AM | #1335 |
Custom User Title
1139
Rep 675
People that stand in front of the dumbbells and perform exercises without noticing that in trying to walk to my bench carrying I am about to drop
Do your freaking curls for girls behind the row of benches |
lsturbointeg9209.50 |
03-31-2018, 10:39 AM | #1336 | |
Rep 136
I diagnose and treat spine conditions daily, your symptoms are likely due to weak abdominal muscles (especially if you are carrying excessive weight up front). Focus on working on the stabilizing muscles in the abdomen and low back and it will improve. That tight feeling in the low back is due to constant muscle strain/fatigue, the abdominal and low back work synergistically to stabilize the entire upper body, when one is weak the other has to take up the slack and fatigues easily, this is why injuries associated with the spine occur (well, commonly, no exclusively). |
Mingwan1890.50 |
03-31-2018, 10:51 AM | #1337 | |
Rep 208
Post up on a flat bench on a Monday to do an arm workout! Then laugh as the people walk by that need to work on grip strength! |
03-31-2018, 12:44 PM | #1338 | |
Rep 208
Majority of postural imbalances are actually associated with having one segment significantly stronger than the other, especially in the hip flexors. Large root cause of many lower back injuries are the result of underdeveloped hamstrings, and tight glutes and hip flexors! For example a large majority of the lifting population that deadlifts, can pull traditional, yet can't do stiff legs for shit. This is result of the hip flexors, glutes, and quads being the primary compared to a stiff leg deadlift placing emphasis on the hamstrings and erector spinae. Sadly the medical community tends to cookie cut the diagnosis to what you mentioned which is great, but if not addressing root causes will continue to result in muscular contradictions. Same thing goes for rotator cuff, and neglect to scapula mobility aswell as under developed rhomboids and posterior delts, combined with excessively tight anterior delts and pec minor. Last edited by Performancedieselpros; 03-31-2018 at 12:49 PM.. |
Mingwan1890.50 |
03-31-2018, 12:55 PM | #1339 |
Rep 960
03-31-2018, 01:08 PM | #1340 | |
Rep 208
It's often described by said client as "back pain" which in result turns the focus again to the non problematic areas. It's like fibromyalgia.... every doctor wants to sticker slap this on 50+ yr old women instead of saying "yo chick you need to workout so yoir muscles aren't achy all the time! |
03-31-2018, 01:18 PM | #1341 | |
Rep 960
Mr.SugarSkulls2888.50 smoosh2214.50 |
03-31-2018, 01:34 PM | #1342 |
Rep 208
Anytime! I'm too technical, and when professionally I spend everyday building, shaping, and correcting individuals physiques..... boobs are fun, but when you spend countless hours a day making sure a chicks nipples don't poke your eye out as result of the paper thin spandex they make these days you become immune to it Lol.
See how that worked! Now yoir back on track! |
