BIMMERPOST Universal Forums General BMW News and Cars Discussion iPhone 15 Wireless Charging Problems in BMW (can break the iPhone's NFC Chip)
      10-13-2023, 07:44 AM   #133
Tejas1836
Tejas1836's Avatar
1270
Drives: 2023 X5MC Workmaster 75
Samsung LOL
Two is One and One is None
      10-16-2023, 03:33 AM   #134
Condorll
Drives: 2023 BMW X5 xDrive 40i
Originally Posted by Cruise'n View Post
Can cooL a $2 can of coke
Will cooK a $2000 mobile phone.
Not surprised as all.
With a 4 day old X5 M60i after two days I've stopped using the wireless charger for a Samsung S23
Cooked �� �� my phone shut down, crashed ID8.5 and too hot to handle, even though can cool a drink centimetres away in the heated/chilled cup holders.
A big fail.
A fan?
A duct?
A heat exchanger?
Surely something...
I have a 2023 X5 xDrive 40i since early Feb '23. No issues charging a Samsung S8 from February to August then got a Samsung 23+ in August, no issues to date. I use the wireless charger every day. I do have a case on the 23+.
      10-16-2023, 08:47 AM   #135
Cruise'n
Cruise'n's Avatar
Australia
79
Drives: X5 M60i
2024 BMW  [0.00]
With or Without a case.
Drive for 3 hours and can barely touch the phone.
Likely a X5 Lci 2024 issue.
But the can of drink directly next to it is being cooked and is nice and cold
      10-16-2023, 11:21 AM   #136
B58-M340iX
Drives: 2021 M340i xDrive
I know wireless is convenient, but cable charging is much more efficient and charges significantly faster. I've posted this several times, but I do wonder why people want to use wireless charging given the heat, slow charging, etc.
      10-16-2023, 12:46 PM   #137
Tejas1836
Tejas1836's Avatar
1270
I wonder why one needs to charge their phone in the vehicle at all, unless it is an old phone with bad battery life. Mine stays in my pocket and I charge it at the end of the day.
DanG11745.50
      10-16-2023, 08:09 PM   #138
OUGrad05
Drives: 2023 i4, 2022 MDX, Cayman GT4
I've only used my wireless charger on my iPhone 15 pro max, once...that was last night. The phone was hot but functioning when we got to the restaurant. How do I know if I've got this problem? Do I need to try Apple Pay somewhere?
2023 i4 eDrive40
2022 Acura MDX
2021 Cayman GT4
      10-16-2023, 08:57 PM   #139
c1pher
Primo Generalissimo
c1pher's Avatar
Drives: All of them
I go on longer drives so charging is helpful to ensure the phone has enough power to last during the drive since I’m using it for navigation (which uses more juice) and then having enough power left for the rest of the day. While wireless charging isn’t a requirement, it makes things less cluttered since I end up needing to put the phone tethered to the charging cable in the passenger seat.
Tejas18361269.50
      10-16-2023, 11:38 PM   #140
G80indy
Save the Manuals
G80indy's Avatar
Drives: Z3, E46, G80
Bottom line is…. They should never have made wireless charging a feature if it’s not safe and reliable
2023 G80 6MT, CCBs
2002 330i Dinan, 5MT
2000 Z3 Conforti, 5MT
c1pher5216.50
      10-17-2023, 07:36 AM   #141
VirtualGuitars
VirtualGuitars's Avatar
Drives: 2024 BMW XM Label
Originally Posted by rons e92 View Post
Does the digital key still work?
I think you’re referring to the key card which is not the same thing as digital key. The key card will not work if you disconnect the wireless charging tray; however your actual digital keys have nothing to do with it, so they will work just fine.
rons e922473.00
      10-17-2023, 08:54 AM   #142
realdah
Drives: 2024 X5
No need, if something wrong with NFC, you will get some messages saying "Apple Pay is not available" or something else, then digital key plus won't work neither, all credit cards, car digital keys are invalid and you will have to remove them all, however then you can't add any of them back.
I got iphone 15 plus first day, and after few days the issue happened, fortunately it is within return window so I just returned it to apple store.
Right now, I will wait until this issue is 100% resolved before I will order a new one.
BTW, my iphone 12 pro has no issue charging inside my LCI since this May.
      10-17-2023, 12:25 PM   #143
rons e92
60-130 Enthusiast
rons e92's Avatar
Drives: G87 M2
I'm talking about the digital key. The one that's I have on my iPhone. Not the card or the fobs.
      10-17-2023, 12:27 PM   #144
VirtualGuitars
They are not related at all, so you will be fine disconnecting the wireless charging tray.
BTW, just in case you’re not aware, if you use an iPhone you can still unlock and start your vehicle even with a completely dead iPhone battery. The NFC chip will work independently regardless of the battery status. I tested this again last week in my vehicle opened upon approach just like it normally would.
      10-17-2023, 12:57 PM   #145
rons e92
60-130 Enthusiast
rons e92's Avatar
Drives: G87 M2
Thanks. So just to confirm, NFC reader has a different power source from the wireless charger?
      10-17-2023, 01:05 PM   #146
VirtualGuitars
Yes, there is a little reserve leftover for the NFC chip to operate. It doesn’t take much. Think of it like a toll tag in your vehicle. Obviously, it would not be ideal to let your phone go completely dead, but you will still be OK to get home.
      10-18-2023, 01:24 PM   #147
cat3dual
Drives: X5 50e
Just back from the Apple Store for my 3rd warranty replacement for the iPhone 15 Pro Max. I was dubious the wireless charger in my 50e could be damaging the NFC sensor used for digital key and Apple Pay. However, this time, the Apple Genius asked me specifically if I had a BMW and used the wireless charger. They replaced the phone again as they're not doing repairs yet on the 15s. He advised to not use the wireless charger as there is now a confirmed issue. He speculated there may end up being a disagreement between Apple and BMW over who is at fault. If Apple accepts responsibility, then there will be a phone fix. If they successfully blame BMW, not sure what the outcome will be. My iPhone SE 3rd Gen charged beautifully on the 50e wireless charger for two months with no issues. Even the 15 Pro Max charged fine and never got hot. So, it seems to me Apple changed something with the NFC sensor or the device design that made it less robust and vulnerable. I will now not be using the wireless charging pad until the issue is fixed or I get a different phone. I'll miss the compensator as it really helped when in the airport parking garage to maintain signal, but it's not worth the hassle and I doubt Apple will continue to be content replacing my phones every week. Word to the wise, hold off on getting an iPhone 15 series if you want to use the wireless charger in the vehicle and if you already have one, DON'T USE THE WIRELESS CHARGER!
      10-18-2023, 01:42 PM   #148
ramparts
ramparts's Avatar
1186
Drives: M40i
It’s madness really there hasn’t at least been some sort of PSA from at least one , both or joint of them.
At least warning people saying , there may be an issue we don’t know , but from the Time being please refrain from using wireless charging until we can confirm
      10-19-2023, 03:06 PM   #149
G80indy
Save the Manuals
G80indy's Avatar
Both companies, however, love to report their earnings per quarter don’t they
2023 G80 6MT, CCBs
      10-20-2023, 09:22 PM   #150
RichTimpa
Drives: 2021 BMW X5 45e
So does anyone know what specific BMW’s are causing the problem on burning up the nfc chip.
I have a 2021 x5 45e and am wondering if anyone has had a problem with that make an model on a iPhone 15 pro max.
      10-20-2023, 09:33 PM   #151
Joralemon st.
Joralemon st.'s Avatar
Drives: 2021 X3 xDrive30i M Sport
Didn't  release a software update to address this?..
      10-21-2023, 04:16 AM   #152
ramparts
ramparts's Avatar
1186
Drives: M40i
No, that update was to address overheating in certain apps ( that were using private apis that they shouldn’t have had access to ….. )
      10-21-2023, 09:19 AM   #153
Tejas1836
Tejas1836's Avatar
1270
I haven't tried the BMW Qi charger but the Qi charger we have at home has not caused any problems, iirc 10 watts, and I charge every evening with the Magsafe charger at 15 watts- iPhone 15 Pro. I haven't read of any Magsafe or at home Qi charger bricking of phones.
      10-21-2023, 09:52 AM   #154
scottc
scottc's Avatar
742
Drives: Mercedes E350 Cpe
It’s only bmw chargers that seem to be causing the problem. I have not use the bmw charger on my third new phone but have on loads of different wireless chargers and it’s fine.
