05-11-2024, 06:51 PM | #133 | |
Rep 7,241
"Aug. 10, 2023 – Prolonged use of acid reflux medications called proton pump inhibitors could increase the risk of dementia, a new study shows." https://www.webmd.com/alzheimers/new...-dementia-risk |
05-11-2024, 08:38 PM | #134 | |
Rep 4,877
Damned if you do, damned if you don’t.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
05-11-2024, 08:55 PM | #135 |
Rep 7,241
Just letting him know what I read. Seems like everything has a risk or warning or a side effect these days. Do what you gotta do.
05-12-2024, 06:53 AM | #136 |
Rep 798
Had heart failure a couple of years back. Had a progressive build up of fluid around the body and lungs. Was gaining 1.5 to 2 lbs a day. Thought I had a flu of some kind initially and the local GP office operating under COVID lockdown did take a week or so trying to determine issue. Ended up going to ED. Turns out my mitral valve had torn. Got stabilised on fluid reduction and had open heart surgery. Got one of the newer mechanical valves so hopefully last 20 - 30 years. It’s a bit noisy, I can be heard ticking away in a quiet room.
Had some complications shortly after with third dose of the COVID-19 vaccine, heart reacted so ended up with a resetting heart rate of around 110- 120 bpm and heart inflammation ( myocarditis ) . Had an interesting month after, but a combo of gout meds and beta blockers started to sort it over next 6 months. Two years on I have a new normal. But have an excellent rehab gym that has got me moving and fitter than before this started. Very thankful to the surgeon and team , apparently the op was close to 6 hours. Get to hang out with a bunch of post heart surgery guys and girls. It’s quite amazing how hard we can push ourselves post surgery. |
05-12-2024, 08:22 AM | #137 | |
Rep 1,744
I read with my left eye and relied on my right eye for distance. But I decided to go with distance correction in both eyes and rely upon reading glasses for well, reading. |
05-12-2024, 08:56 AM | #138 | |
Rep 1,744
Became increasingly harder to swallow. And painful. Went to several doctors -- including a ENT specialist -- and got no where. Was so bad I was down to eating soup and drinking coffee and water. Lost 15lbs. Saw another ENT specialist and after a few minutes asking me questions he sprayed some anesthetic into a nostril and then scoped the nostril. He reported seeing blisters at the back of my nasal passage and down in my throat around the larynx and beyond. He said looked like pemphigus. Said the only way to be sure was to obtain a sample of tissue and send it to a lab. There the tissue sample is examined to look for signs the mucous membranes are separating. So he took a sample of tissue from the roof of my mouth. (No pain he numbed that area up real good.) Results came back in a day or two and it was pemphigus. Started me on a round of steroids (pills) and directed me to a dermatologist. Seems the mouth/throat/nasal passages at least in this case are the domain of a dermatologist. The steroids helped in the meantime. At the dermatologist I was prescribed Dexamethasone rinse/spit medicine. Twice a day at first but after some time once a day proved to be sufficient to keep the condition under control. Oh, years later, in Dec. 2020 in the ER for lower GI bleeding. Short version is diverticulitis was diagnosed. A colonoscopy didn't find this I was given some radioactive isotope (half life 6 days...) and while it took two times under the imaging machine the 2nd time blood was seen leaking into the large intestine. (Diet changes have proved to be -- so far -- adequate to keep diverticulosis/diverticulitis under control.) But while I was under for the colonoscopy the doctor did an upper GI endoscopy. Went all the way to the stomach and a bit beyond. Doctor reported seeing esophagus erosion due to acid reflux. I had been using OTC anti-acids for some time prior to this exam. I was given an IV of antibiotics for ulcers. And was prescribed Pantoprazole Sodium 40mg for the acid reflux. Have been taking this ever since and with some changes to my diet -- avoiding carbonated drinks (which I didn't drink all that often to begin with) and oranges, orange juice and other citrus fruits/juices, avoiding eating raw tomatoes, eating late in the evening -- no more acid reflux. Have not bought an OTC (or prescribed) anti-acid medicine since. |
Llarry22231.50 tturedraider5748.00 |
05-13-2024, 08:34 AM | #139 |
Rep 2,092
Drives: 2022 X6///M Comp
Oldgixxer Good luck! Hang in there.
I thought I was a good person but the way I react when people drive slowly in the left lane would suggest otherwise
Esteban56122.00 |
05-13-2024, 07:32 PM | #141 | |
Rep 798
05-16-2024, 09:55 PM | #142 |
Comfortably Numb
913
Rep 656
Drives: '18 x1/'13 X3/'06 330i
Well, got the second cataract surgery today and again went well. Everything went off on schedule. During prep, the anesthesiologist made mention that I might be a bit more aware of my surroundings during the procedure. He was right, again could see shadows of everything going on, hear all the sounds and voices and actually moved my lips enough to moisten them as they got rather dry. Did hear music playing in the background as they had a radio playing, no Pink Floyd but some Lynyrd Skynyrd was playing.
Vision has improved, actually sitting here this evening and can watch TV without glasses. Using readers for reading and banging away at the keyboard on my phone as I write this. Have worn glasses the last 40 years and need them for all aspects of seeing in my life. Looking forward to getting a eye exam and seeing how much my vision has changed. I'll report back once this portion of this procedure is finalized.
06 e90 330i/Alpine White/Terra Dakota
13 F25 X3 xDrive 35i/Black Sapphire Metallic/Oyster Nevada 18 F48 X1 xDrive 28i/Black Sapphire Metallic/Black SensaTec |
05-16-2024, 11:57 PM | #143 | |
Rep 275
Drives: BMW Z4C 3.0si 3 pedal
08-29-2024, 01:43 PM | #145 |
Rep 112
Mine is more about a healthcare rant.
I broke my left leg while sparring in a BJJ gym, soon ambulance arrived: - Dude, which hospital are we going to? - No idea, I'm not local just take me somewhere. - Do you have insurance? - Yeah I do, it's in my car, I'll get everything to you, let's drive, I'm kind of in pain. - What's your SSN, DOB, mailing address etc.? - My man, let's go, it hurts you know? - I know, but I can't start driving without getting your info. - Okkkk here is my SSN etc. Finally, we started driving. - Can I get some painkillers? - Nah, better to get them in a hospital, ours are not that strong. - Sounds good, I guess I have no choice. We arrive in an emergency. - Hey guys, I need painkillers. - Sure, but first we need to register you - Proceed with questions about insurance bla bla bla. It took about 30 minutes for them to finally give me a shot. Even though I'm very tolerant to pain, this one was painful, I broke my leg in 2 places. I'm not even going to describe the procedure of casting my leg. It was a joke... The most interesting fact for me was that I had to wait a week and a half for the surgery. I pay an almost $2k family premium with a $10k deductible, which is the best I could get as a self-employed person. The total cost of the surgery and everything else was about $70k + $8k I had to pay out of my own pocket. For that amount of money somewhere in Turkey, they not only were to fix my leg, but also would make me a BJJ world champion for a cashback |
08-30-2024, 07:08 AM | #146 |
Curently BMWless
22232
Rep 751
An old friend of mine from the Navy is undergoing radiation therapy for prostate cancer. Apparently, 15 or so "seeds" are injected into the perineum and then radiated. Sounds like an ordeal. And he has to do it again in a week or two.
I remember reading that a relatively large percentage of elderly men are found to have (slow growing) prostate cancer upon post-mortem examination after death from other causes. Just to add a bit to my cancer anxiety, my own prostate-specific antigen (PSA) numbers are on the rise, although still within the normal range. Oh, the joys of growing old!
'25 M850ix GC (Ordered)
BMW CCA 30 years Last edited by Llarry; 08-30-2024 at 07:54 AM.. |
KRS_SN14906.00 |
09-04-2024, 08:43 PM | #150 | |
Rep 4,877
First procedure is to seal the vein shut using heat (upper leg). For the lower leg, he uses some type of foam to redirect bloodflow to other veins. Lower leg would be done 2-3 weeks after upper. After that, we'll look into the other leg. Will need to see him annually thereafter for an ultrasound to monitor remaining veins as this is apparently genetic and it could occur in other veins as I get older. Options are to wait or do it now. I am told that eventually I will have worse skin issues on my leg that could be difficult to heal. I have no pain or issues other than swelling and periodic skin irritation, but scheduled a procedure for November since it isn't something that will cure itself and will likely need to be addressed at some point. Sounds common and pretty minor / quick with minimal recovery so might as well get it done. The only reason I was considering waiting further is my primary care doctor left the medical practice and I wanted to talk it over with him. Can't contact him now and finding a new primary care doctor is a little challenging in terms of a near-term appointment. So, I was just wondering if anyone else has done this and, if so, how it went. Any complications or is the procedure and recovery as simple as it sounds? Any questions I might want to ask?
09-05-2024, 06:07 AM | #151 | |
Rep 5,635
A related chart on PSA screening in asymptomatic men |
09-05-2024, 08:35 AM | #152 | |
Rep 2,982
RickFLM411922.00 |
09-07-2024, 10:38 AM | #153 |
Rep 4,877
Got Paxlovid/COVID rebound a couple of days ago. First round was pretty minor, like a mild cold, and cleared up very quickly. Tested negative Monday and Tuesday. Then I woke up congested on Thursday and took a test around lunchtime. So this is day 3 of the rebound and it is now clearly worse than the initial round. No fever or serious issues, but more like a severe cold than a mild cold this time. Weird, because from what I've read rebound case are typically milder and don't last all that long. Might do telehealth again this afternoon but not sure there is much to be done other than fluids, rest and OTC cold remedies to treat symptoms. I do have a little more of a cough and have taken benzonatate in the past for other coughs so maybe that's something worth asking about.
I took all the vaccines and boosters through 2023 (all Pfizer) and managed to avoid it for 4 years. But it got me twice in the last 2 weeks. Better now than early on I suppose.
