07-02-2009, 12:53 PM | #133 | |
![]() 838
Rep 4,643
http://www.cnn.com/2009/WORLD/americ...ort/index.html
07-02-2009, 01:12 PM | #134 |
Supreme Allied Commander
![]() ![]() 2063
Rep 61,781
Drives: A BBS WHORE
After one month of the accident and the FDR and CVR hasn't been recovered yet...
07-02-2009, 02:16 PM | #135 |
![]() 838
Rep 4,643
yea, it's a lost cause. this looks like it will be an unsolved mystery as it appears the plane did indeed hit the water intact. i just can't seem to understand how this accident happens if it wasn't a mid-air breakup. i mean, what would cause it to just simply fall out of the sky without a critical flight surface being disrupted? i guess we'll never know what airspeed it was really traveling either without the FDR.
07-02-2009, 05:54 PM | #136 | |
![]() ![]() 2063
Rep 61,781
Drives: A BBS WHORE
This doesn't mean to eliminate the current black boxes...but as a secondary incase signals got distrupted.... but airlines have to invest lots of money on recording servers and satellite subscription....especially with large airlines with thousands of flights everyday....
07-04-2009, 12:44 AM | #137 |
Rep 5,945
I still think airlines should deploy parachutes if any of the sensors fail or altitude+velocity reach a certain threshold...like a manual release of some sort...
07-05-2009, 03:19 AM | #138 | |
![]() ![]() 2063
Rep 61,781
Drives: A BBS WHORE
That's already an existing technology, the Cirrus SR22 single engine prop is equipped with parachute incase of engine failure. However, the theory behind the use of a parachute is to let the pilot drop the plane "gently" on the ground insteash of glide and crash. These things are not "uncommon" on single engine props, which engine failure without backups. In regular commercial flights, the chances of both engine fails are RARE. There was only three cases: Air Canada's Glimli Glider Boeing 767-200, Air Transat A330 (wat's up with the Canadians? ![]() The Air Canada's case, the refueler's calculations was incorrect due to factor of fuel density (Imperial Unit vs Metric Unit) was not correct with fuel weight to volume calculation. In Air Transat's case, the maintenance mechnaic used an improper part in the engine caused the fuel line leaked during flight, and was not detected by the system but only showed unbalanced fuel. So the pilots opened the cross-feed valve as standard procedure. Error in both the mechanic and the pilot crew, which did not closed the cross feed valve when one of the engine was flamed out. Tuninter ATR, the maintenance mechanic installed the WRONG model of fuel quantity gauge on the aircraft, which showed "more" fuel than the fuel tank has; and the pilot ignored the refueling slip when he "thought" the aircraft was refuelled since the fuel quantity increased from previous log. http://en.wikipedia.org/wiki/Gimli_Glider http://en.wikipedia.org/wiki/Air_Transat_Flight_236 http://en.wikipedia.org/wiki/Tuninter_Flight_1153
