08-25-2014, 05:50 PM | #135 | |
Autobahn Addict
23
Rep 173
Drives: '11 E92 N55 6MT Msport
What exactly is the car doing?
defi boost gauge in custom 3d printed pod, jb4, bms cdv/cs, er cp, vrsf 7" ic, m3/poly diff/tranny mounts, st coilovers, cyba 3.8 tips
08-25-2014, 05:53 PM | #136 |
Rep 1,516
Starting to stall a lot but what scares me the most is on the freeway, the engine will start stuttering and cut power. It's doing it every couple of days now and its to the point where I can't even drive while it's doing it.
08-25-2014, 06:05 PM | #137 |
Autobahn Addict
23
Rep 173
I would def call the dealer and bring it in, or at least have the codes checked asap. Could be the fuel pump too come to think of it.
08-26-2014, 05:16 PM | #138 |
Rep 1,516
08-26-2014, 06:35 PM | #139 | |
Autobahn Addict
23
Rep 173
Afaik on our platform it's the high pressure fuel pump that has problems. You need to have the codes read.
08-26-2014, 11:23 PM | #140 |
Libertarian
133
Rep 1,577
Long starts is also a symptom of the hpfp failing...
2011 335xi Coupe BSM (e92/N55/ZPP/ZCW, Alpina B3 Flash)
Bought 08/09/2013@53,340mi Current 3/13/2019@206,283mi Fail(s): tstat hous/water pump 89k, Chargepipe 106k, coolant tank 114k, FRM3 114k Maint: Walnut blast 101k, Trans/T-case Fluid 103k, OFHG 195k |
09-24-2014, 05:25 PM | #141 |
Rep 29
Drives: 2012 135i Blue/Tan Nav/M/HK
Mine is at the bmw dealer currently getting fixed, but the parts appear to be delayed (Southern California).
Anyone out there that has actually had the VANOS recall done? |
09-24-2014, 07:09 PM | #142 | |
Autobahn Addict
23
Rep 173
Did you receive the letter to come in or did you go yourself?
09-24-2014, 10:33 PM | #143 |
Rep 29
I took it in to the dealer for service and they said they could take care of the recall as well. Just heard it will be ready tomorrow and getting the engine timed as well since it has to do with the valves.
09-25-2014, 12:11 PM | #144 |
Rep 29
WOW just got my car after the recall, with the engine re-time, the engine feels brand new, less turbo lag, super smooth, haven't taken it for a "real" ride yet, but so far, big smile
09-25-2014, 12:35 PM | #145 | |
Autobahn Addict
23
Rep 173
Which dealer did you go to?
