BIMMERPOST Universal Forums General BMW News and Cars Discussion Future BMW model information (Response Archive)
Closed Thread
      12-23-2017, 08:06 PM   #1541
M-Pilot
M-Pilot's Avatar
Drives: 981 Cayman GTS
Originally Posted by dmboone25 View Post
Originally Posted by Dinh335 View Post
With all due respect I think the whole "can't put power to ground on daily basis on f80" is way over exaggerated. I suppose if you are just mashing throttle. But using proper string theory goes a long way into making the f80 very engaging fast and fun.
I just see a lot of traction control intervention, even in moderate throttle applications. And if I’m getting onto a highway, I would think I could push the accelerator most of the way down and have the car get going quickly.
I’m not mashing the throttle - but the car wiggles and hesitates, with the traction control light blinking, between 1-2 and 2-3 gears, at least it does for me.
DSC intervention doesn't necessarily mean the car can't put the power down. I agree with the other member above that it's overly exaggerated. DSC is way too restrictive in F80/F82 even in Euro MDM! I used to drive in MDM (for the first 6mos of ownership) then switched to DSC off. It's night and day difference. I have PSS 295s in the back and they slip only in in 1st gear if I straight out floor it instead of gradually increase the throttle. If I floor in 2nd and 3rd it just grips with no drama ( dsc fully off and on a straight line). Never experienced difficulty of putting the power down at the track either. In fact, my lap times are 2sec faster with DSC fully off than in MDM at Laguna Seca. I think a lot of people floor it when DSC or MDM is on and complain about power delivery. F8x doesn't grip like an AWD car but it's not nearly as bad as described here either.
jmg19428.50
Dinh335720.50
      12-23-2017, 10:15 PM   #1542
M3 Number 86
Drives: black m3
I just see a lot of traction control intervention, even in moderate throttle applications. And if IÂ’m getting onto a highway, I would think I could push the accelerator most of the way down and have the car get going quickly.
IÂ’m not mashing the throttle - but the car wiggles and hesitates, with the traction control light blinking, between 1-2 and 2-3 gears, at least it does for me.
Dsc is overly sensitive I have found, kicking in too early and too aggressively leaving you a feeling that you are not in control. Using M dynamic on the track iv noticed less of that feeling. 0-100mph runs absolutely MASHING the peddle from a dead stop in M dynamic launches the car with a little wheel spin but it quickly gains composure and bites down. Very little tail way if at all.
Mdm on track? That's still useless. Kicks in way too much.
      12-23-2017, 10:17 PM   #1543
M3 Number 86
Drives: black m3
I think randy pobst did a 1:39 bone stock m4. How does yours compare? It gets trickier as you get faster obviously.
      12-23-2017, 10:32 PM   #1544
M-Pilot
M-Pilot's Avatar
He did 1:39 on DCT Non-ZCP. My PB is 1:41.8 with DSC off, NT01s and RS29s on my 6MT ZCP. My best time with MDM was 1:44.
      12-23-2017, 11:27 PM   #1545
M3 Adjuster
Albania
7914
Drives: 1M, X1 M Sport, E46 325ic
That’s the thing - I Drive in MDM mode 100% of the time. I can’t imagine how frustrating it is if you’ve got a non ZCP.
Try Euro mdm and you will see how much it still comes on. And " a little wheelspin" pretty much everywhere adds up in lost time quickly especially on track.
I Autocross and track with both 275/35 18 and also 285/30/18 all around on my 1M. When I borrowed a friend's 10.5" rear wheels with 315/30/18 at the back that's when I realized Wow my car is finally actually getting all the power down!
I've got a Measly 335hp and just 365! Ft lbs .. :
      12-23-2017, 11:34 PM   #1546
jmg
jmg's Avatar
19429
Drives: G82 M4C X-Drive
I'm still a beginner.
2022 G82///M4 Competition X-Drive - KW-HAS, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing
Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3
Ordered • 2025 ///M2
      12-24-2017, 08:59 AM   #1547
M3 Adjuster
Albania
7914
In my car with 285s out back I was like YES! this is way better.
If you can manage to fit 315s out back , yours won't slip any more at all in first. . I'm also confident you will *then* realize that you aren't actually getting all the power down currently. Ask me how I know.
Lap times with DSC off should definitely be quicker than MDM as the latter mode employs braking of the rear wheels , along with reducing the power of the motor to maintain traction at the rear. A person that drives very smoothly can avoid the car using the brakes at the rear but usually the power being backed off is still an issue. For example at Barber Motorsports park, for me coming out of the esses onto the back straight you absolutely need 100 percent power but the car will never let you get full throttle in MDM mode because one needs to accelerate from the apex to track out and the car is at an angle still. It's one of those places where more power actually helps you as a driver, and the car is still backing out of the throttle. I would imagine coming out of the corkscrew at lacuna would be similar.
M-Pilot4894.50
      12-24-2017, 09:07 AM   #1548
Falafel Combo
Drives: X5 xDrive50i
So 475 target bhp on the S58 will pretty much dyno 502-510 bhp. Wow. Because the S55 M3 already had no problem putting the power down to the wheels.
Can’t wait for the “2019 M3 leaving cars and coffee” videos!!!
SoCali E361099.50
ChrisK4476.50
      12-24-2017, 09:17 AM   #1549
Falafel Combo
Originally Posted by mkoesel View Post
Oh, ok - I didn't realize that. In that case, 500hp will very likely be available in the competition package.
Originally Posted by goj View Post
I spy a 500hp comp pack M3. Next car for sure
We know the S58 “475” bhp will almost certainly dyno at 500+ out of the box. What’s in a number.
      12-24-2017, 10:55 AM   #1550
jmg
jmg's Avatar
19429
Personal skill aside, the faster driver will be going through that turn without the DSC even engaging because they will be at the perfect speed and angle to take the turn with maximum grip and no loss of traction as opposed to the driver who is correcting with the throttle. The second driver might be faster with DSC off compared to their times with DSC on, but he would be even faster if he didn't engage DSC at all, even if it was on. In theory anyway.
      12-24-2017, 11:15 AM   #1551
M3 Adjuster
Albania
7914
I would agree that's all in theory.
In practice, I've seen drivers be smooth and fast and some drivers are tail out , appear to be overdriving but actually are in full control.
Ever seen Pierre kleinubing driving a Real Time Acura or any Honda inspired FWD product ? Contrast that with co driver /team owner Peter
Cunningham or a driver like BMWs own Bill Auberlen who are fast and smooth lap after lap.
Any form of stability control will affect one of those drivers more than the other because of driving style.
      12-24-2017, 11:34 AM   #1552
eRiggs5
eRiggs5's Avatar
310
Drives: 18 M3 CS
I wonder how the S58 will sound...?
-> 2018 M3 CS <- follow IG: eriggs05_m3cs
2020 Grand Cherokee Summit: Wife's
2016 BMW M3: Gone
2008 Lexus IS: Gone
FSociety3877.50
      12-24-2017, 01:51 PM   #1553
Whatever the power output, I hope they put more time and effort into getting the power to the ground. It’s something you notice on a daily basis with the F80 - which makes it hard to really enjoy what the car has to offer from a performance standpoint.
Also try Michelin PS4S (see here) or Michelin PS2 Cup tires.
      12-24-2017, 08:31 PM   #1554
M3GymNut
Drives: 2021 M3Comp
I hope it sounds nice, that's one of my main concerns with the G80
FSociety3877.50
      12-25-2017, 11:48 AM   #1555
ChrisK
ChrisK's Avatar
Drives: '19 M2C
All that power and I will still be unhappy....
Because BMW will make the 3 series bigger yet.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange)
JustChris17695.00
FSociety3877.50
      12-25-2017, 12:30 PM   #1556
Falafel Combo
Don’t hold your breath. The S58 is merely a repackaged S55. I’d Hate to be a grinch here, but ... it will most likely sound something like this
jaehshim496.50
      12-25-2017, 04:45 PM   #1557
jaehshim
jaehshim's Avatar
Drives: E90
exactly...
nothing but a "tuned" S55.
The F8X gen sounded terrible, M4 GTS sounds terrible.
I probably heard 5 quality aftermarket exhaust including M performance on F8X, there's no difference . It's the same "noise", just got louder and hence unpleasant. and this is at idle. This engine sounds terrible at driving too...
      12-25-2017, 06:45 PM   #1558
guarnibl
Drives: Depends on the day.
exactly...
Yep. Exactly why I sold my M. It was a good vehicle but there were too many things about it that bothered me... sound and lack of steering feel mainly. I still love the brand, don't get me wrong.
2019 Jeep Wrangler | 2018 BMW 320i | 2016 Porsche Boxster Spyder | 2009 Jeep Wrangler
gone: 2015 M4, 2015 335i, 2012 Turbo S, 2008 M3, 2004 M3, 2003 330xi
Penguino1661.00
      12-25-2017, 08:44 PM   #1559
Blubaron79
Blubaron79's Avatar
Drives: 2021 M340i xDrive
People love the way the B58 sounds.. I would not make predictions just yet.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive
ando2295.50
kozzi970.50
      12-25-2017, 10:52 PM   #1560
phoenixbmwlife
phoenixbmwlife's Avatar
Drives: M235i & G30 540i
2014 BMW/M235i  [0.00]
The M2 is the new M3. Get that one if you want a smaller size.
Lack of money is not the problem. It is merely a symptom of what's going on inside of you! - T Harv Eker
Follow me on Insta
https://www.instagram.com/bmwm_life_/
https://www.instagram.com/autogiftua/
https://www.instagram.com/phoenixbmwlife/
      12-26-2017, 07:58 AM   #1561
PackPride85
Drives: M2
So did the N55.....
      12-26-2017, 08:44 AM   #1562
ChrisK
ChrisK's Avatar
Drives: '19 M2C
I have one. Went from an e92 M3 to the M2. Reminds me of my e46 M3.
Closed Thread
