11-03-2016, 08:14 PM | #155 | |
Rep 926
Drives: 2024 BMW 230i xDrive
11-03-2016, 09:28 PM | #156 | ||
Rep 2,329
11-04-2016, 06:16 PM | #157 |
Rep 814
Anyone with "analog out" stereo coding and an aftermarket amp have the combox retrofit done?
I have the above and I'm trying to figure out what I'm in for. I saw one post an owner with an amp was told the factory amp had to go back in for the retrofit which would be a pain. |
11-04-2016, 10:19 PM | #158 |
Rep 420
I just bought a '13 M5 CPO. It was sold in 08/13 but I believe manufactured 01/13.
It has BMW assist until 08/17 according to my login on BMW ConnectedDrive. I called BMW assist and the guy said "sorry sir, your car will stop working with BMW assist at the end of december, you have to talk to BMW NA to get a retrofit if you want to continue it" He forwarded my call to BMW NA who said "BMW Assist is wrong, the car does not have the 2G combox, it has the newer technology and there is nothing you need to do" I called BMW Assist guys again and (pretended) asked if I could extend my services or buy concierge service. They said nope, the car won't work anyways. Can I check the hardware myself? The combox unit is somewhere in the trunk right? Edit: Vin Decode says Prod. date 2012-10-11 |
11-04-2016, 10:48 PM | #159 |
Rep 288
You can just plug in the last 7 of the VIN
http://www.bmwusa.com/Standard/Conte...t/default.aspx https://www.bmwassistoffer.com/sunset/vin.htm BMW ConnectedDrive provides you with a suite of safety, convenience and infotainment services that add peace of mind and confidence throughout your day. BMW ConnectedDrive intelligently integrates the driver, the vehicle and the environment. Included within ConnectedDrive is BMW Assist™, which uses advanced technology to bring the focused attention of a response specialist to your aid whenever needed. Combining an integrated wireless phone for communication and a Global Positioning System (GPS) satellite receiver to determine your vehicle's location, the BMW Assist™ system conveniently helps to deliver both occupant security and peace of mind. On suitably equipped 2007 through 2013 models and 2014 X6 Sports Activity Coupe, the BMW Assist™ Safety Plan is part of BMW ConnectedDrive, included at no cost for four years from your BMW's in-service date. SPECIAL NOTE: After December 31, 2016, the on-board cellular technology used for delivering numerous BMW ConnectedDrive / BMW Assist features will no longer be supported on most 2013 and earlier vehicles, 2014 X6, 2015 and earlier X1, and 2016 and earlier Z4 vehicles. Affected customers whose BMW Assist or ConnectedDrive contract is active past this date will be contacted by BMW. If you believe your vehicle may be affected, please visit www.BMWAssistOffer.com and enter the last 7 characters of your VIN. If you are affected, you will be guided through selecting your preferred offer. |
11-05-2016, 03:04 AM | #160 |
Rep 420
Thanks -- I tried a few times but I just get:
"You have entered an invalid VIN. Please re-enter for validation." Does that mean I'm in good shape? |
11-05-2016, 09:44 AM | #161 |
Rep 288
Could be. Otherwise, you would be brought to a screen to choose one of the 3 options.
I have a build date after yours (June 2013) and was impacted by this. I got the retrofit done and when I did a search for my VIN, I get a message that my selection was completed, which is true. |
11-05-2016, 01:21 PM | #162 | |
Rep 1,244
Drives: 2013 F10 M5
The 2013 M5 has the NBT navigation system and a 3G-based TCB (Telematic Control Box). NBT systems do not have a Combox at all (the Combox was integrated into the NBT head unit for media and the TCB was added for Telematics). Your system will continue to work after Jan 1, 2017. I know this personally because I have a 2013 M5 with services booked until 2018. |
11-05-2016, 01:59 PM | #163 |
Rep 258
how much is retrofit worth to us/ cost to BMW vs $300 accessory or $200 gc?
are there any cable sticking out anywhere? if so, can someone post a picture? TIA |
11-05-2016, 03:07 PM | #164 | |
Rep 3,363
And no, there's nothing extra sticking out. |
11-05-2016, 04:40 PM | #165 | |
Rep 420
I thought NBT = the new bigger idrive knob with touch capability. Will have to read up on the system in my car. |
11-05-2016, 04:43 PM | #166 |
Rep 44,711
Drives: 2018 Alpina B6 650ix GC
NBT has old ZBE iDrive Controller in first year of F10 Production. The following year, ZBE touch was added.
2018 F06 Alpina B6 650ix GC; Space Grey; Vermillion Red Nappa Leather; Executive; B&O; Driving Assistant 2017 F15 X5 xDrive50i MSport; Glacier Silver Metallic; Black Dakota Leather; Executive; B&O; Driving Assistant; RSE |
11-06-2016, 03:09 PM | #167 | |
Rep 1,244
Drives: 2013 F10 M5
Touch controls came in MY2014 for the 5-series and some other models, all other models got in it MY2015. |
11-09-2016, 01:57 PM | #168 |
Rep 63
Just a follow up: I took the time to disconnect my retrofit NBT and reconnect the combox before bringing in my car for the retrofit. Took about 40 mins total all they really did was disconnect the combox and ... put a black sticker over the SOS button. I expected a new plate to replace bring button or a new cover etc.
I asked what the procedure was for an upgrade and the guy said they just replace compbox. |
11-11-2016, 08:57 AM | #169 | |
Rep 3,721
11-11-2016, 12:15 PM | #170 | ||
Rep 942
Drives: 2012 328i Modern Line
:wave:
11-11-2016, 01:26 PM | #171 |
Rep 3
*Just wanted to provide an update here.
Did the recall this week. Took two days, got a loaner car. I told SA that i coded car a bit, the SA said it did not need to reprogram the system. When i was picking up the car, they said they found a faulty code on my gear shifter when upgrading the combox. When i was coding the car, I did change the standard auto to sporty auto, not sure if that was the reason. So they did reprogram the car and updated my gear selector as well (from standard plastic bottom one to the sporty one). I guess it was worth it. |
11-11-2016, 02:02 PM | #172 |
Rep 37
Took mine in yesterday since it was due for 20k service. I have only coded my bluetooth audio and it's still working so... all good on my end.
Picked the VISA gift card |
11-11-2016, 03:14 PM | #173 | |
OCXG30
42
Rep 77
Drives: BMW 540i M sport
11-11-2016, 04:03 PM | #174 |
Rep 135
Anyone know if the $300 gift card could be used to towards the BMW CF rear spoiler? My dealer couldn't give me a clear answer and said it would be $480 out the door without the gift card. Is there a dealership online that would honor it for that part?
11-12-2016, 11:10 AM | #175 |
Rep 269
I spoke with BMW NA about having to buy parts locally or not. She told me that I could either call directly any BMW dealer and order, or have my dealership call and facilitate the sale. I clarified that I might want to order from an out of state dealer because their prices would be so much better. Just make sure everyone is aware of the promo code (or whatever) while you're doing it and you can order from wherever you like. It just has to be from BMW directly for them to be satisfied.
I forgot to ask if it would only be toward Lifestyle stuff, or if it would also apply toward vehicle accessories and M Performance parts. |
11-15-2016, 07:09 PM | #176 |
Rep 2,973
I bought a 2013 X5 in July.
I opted for the retrofit. My car was within the 4 years, 50K miles. Sent my dealer the information last week. Car went in today for the retrofit. They estimate done by Thursday. Zero cost (except for subscription) made it a no-brainer. My wife drives the X5 most of the time.
Arctic Metallic\CF Splitters, Spoiler, Mirror Covers\LED Tails\LSD\Tinted\Coded\Apex Square SM10-19"\LED Angel Eyes\Gloss Black Grill\Integrated V1 & Galaxy Tab\M-Performance Brakes\Cobb Tuned\xHP Flash\Resonator Removed and -> is your friend.
