10-29-2022, 03:57 PM | #155 |
Rep 778
Turns out my idle issues were me being dumb. I didn't have the intake manifold situated quite correctly nor were the intake manifold bolts tightened down to spec.
I definitely had some vacuum leaks going on so when I cranked it all down nicely onto the gaskets the idle evened right out and drives super well. I'm seeing about 19-20psi on the 3.25" pulley and it's an absolute on/off switch of torque. So much fun.
Mosselman-powered M4 - 698/714 | 2.9 Whipple 2004 Cobra - 690/645 | Instagram
swanson801.00 |
11-05-2022, 12:57 PM | #157 |
Rep 778
Yeah honestly I was expecting the wheels to be a shade or two darker based on pictures. I may end up powder coating them darker at some point, but I'm just ready to call this thing done for a bit haha
11-06-2022, 08:58 AM | #159 |
Rep 778
Yeah I really thought hard about doing brushed as well. The color decision was pretty hard on these but the i've been really impressed with the quality for the price point.
11-14-2022, 08:44 AM | #160 |
Rep 778
It's been a LONG week.
I went to get some exhaust work done and have a new tailpipe made so I can fit my wheels/tires. The car ended up roasting the fuel rail pressure sensor, and when they FAIL fail they end up pressurizing the vacuum line to the intake manifold with fuel. Sure enough, after troubleshooting the non-starting for a while the motor was entirely flooded. I finally tracked down the issue, but was just too slow on it and there was no CEL or anything to help trace it. I pulled all the plugs, pumped fuel out of the cylinders with a transfer pump and then cranked it with the injectors disabled until it would run on the fuel in the motor itself. Took a few cycles of 20-30s hits on the starter to get it going, but it finally turned over. Drained all the oil to find at least a gallon of fuel in the engine oil. Such a fucking mess. Fresh oil, swapped out the absolutely trashed spark plugs and it's all back alive and running. Swapped out my coilover springs from 10" -> 8" and adjusted some clearance issues with the top hats so i'll be ready to mount the wheels/tires when I pick them up today at least. Also looks like I'm JUST about set for my tuning appointment on Friday. It's been stressful as hell, but i'm glad the car is back together and running well. If it makes at least 650whp i'll be happy.
11-14-2022, 08:54 PM | #162 |
Rep 778
Little teaser because there's just no sunlight anymore. I need to drop it just a touch more to be totally content, maybe .5 in the rear and .25 up front. I can't slam it like I want to because the longtubes and exhaust hang so low.
And one little goofy addition. I can't let the car be too too serious now. Nervous, but same. Just a few more days and still need to gap/swap some fresh TR6, fresh oil change and burp the coolant system one last time.
11-18-2022, 08:22 PM | #164 |
Rep 778
Long but good day here! Made it over to Lee Blankenship tuning this morning and got some things dialed in on his mustang dyno. It's supposed to be calibrated to be pretty close to a DJ and i'm pretty happy with the numbers.
With smoothing I made: 629/601 on 93 690/645 on E85! I also ended up making just over 21psi on a 3.25" even with longtubes too. Air density was SUPER high so I expect that it'll be more like 19-20 in more normal conditions. We talked about throwing the 3" on and cranking up the base fuel pressure, but I wanted to keep it so I could flip between 93/E85 easily. Without the smoothing I hit 697whp on E85 and I believe it was 639whp on 93. Car absolutely rips now and honestly faster than I had expected. E85 dyno: https://www.youtube.com/shorts/ZJkG98AEpwg 93 dyno: https://www.youtube.com/shorts/6HcDCdUec9E
swanson801.00 |
11-18-2022, 10:25 PM | #167 |
Rep 778
Good good question. Mostly because I had two 2007 GT500's in the past. Really cool cars but I've always been so nostalgic for the 03-04 models despite not being great cars honestly. The cable clutch sucks to drive and they ride pretty terribly but the analog driving experience is just SO fun.
GT500 made for a great touring car. Super comfortable, easy to drive, made great power but they just never felt that special to me.
GERMAN M34253.00 |
11-18-2022, 10:40 PM | #169 |
Rep 778
yeah it's honestly more than I was expecting and it's a handful for sure, even with some sticky 315's in the rear. I set out to hit somewhere in the 650whp range on 93 but that extra almost 50whp and associated torque took it to another level. Having a garage of a combined 1400whp "daily drivers" has gotten a little out of control. I need another daily for my daily cars.
DocL2133.00 |
11-19-2022, 08:26 AM | #170 |
Rep 3,235
Great numbers! How does it feel on the road once those tires warmup.
Current Mods:
2004 E46 M3cs JB/CSL 2010 E70 X5M AW/BLACK 2011 VW Golf R DSG White/Black IG: @060Motorsports |
11-19-2022, 10:43 AM | #171 | |
Rep 778
3rd gear is fast fast but traction on a hard hit is non-existent. I see why a lot of people run around with street slicks and various drag radials on the rears now
11-19-2022, 02:22 PM | #172 |
Rep 778
I do sometimes miss them a little bit. Both of them were white too lol. One I only had a few months because it was a lemon, but I kept the other for several years and had a great time with it.
GERMAN M34253.00 |
12-06-2022, 04:26 PM | #173 |
Rep 778
I must be getting old but my Borla exhaust is just too damn loud with the long tubes so i'm going to try this Magnaflow street setup that I got for cheap as an "open box" for $400.
swanson801.00 0-60Motorsports896.50 |
12-07-2022, 08:57 AM | #174 |
Rep 778
Allllll business mode lol
I obviously need to crank up the coilovers, roll the fenders, but they look MEAN. Also waiting for my MM rear brake lines so they'll actually fit correctly. They're pretty cool though for something to roll around with sometimes.
Red Bread4459.00 |
01-03-2023, 12:53 PM | #175 |
Rep 778
Little updates here:
- Driver header is leaking out of the front port, I apparently blew out part of the gasket that I knew I should have gone OEM on. - Swapping the front k-member to a lightweight tubular BMR because I have to drop the whole k-member again to do the header gasket :/ - Magnaflow exhaust is too quiet lol, so I'm swapping to a MBRP next to try it out. Got a really good deal on it so it's worth trying. Other than that list, the car is absolute rocket. The torque comes on instantly and just liquidates tires. Fun thing about a built-SRA is the car wants to stay super straight almost all the time. It's definitely no corner carver, especially once I change the k-member out and lose my front lower brace.
swanson801.00 |
02-25-2023, 08:32 PM | #176 |
Rep 778
About time for some updates!
Got my header gasket swapped out with an OEM piece, a BMR tubular K-member installed to drop some more weight off the front of the car (roughly 30lbs) and changed up the catback to a MBRP brushed black exhaust. Sounds about perfect to me, has a nice throaty tone and isn't insanely loud until you're really deep in the throttle. Next on the list is swapping out for a fresh set of spark plugs, some new Ford COP to hopefully address a little stumble i'm feeling at higher-RPM under load. Also picked up a 0 gauge wire grounding kit for the "the big 3" to help with the higher amperage alternator. Otherwise, I need to swap out the rear brake lines for some braided lines with a smaller banjo fitting so I can drive around with the 15x10's. They should hook really well so i'm pretty excited. In other news, I did manage to get this heavy pig to a sub-7 60-130 too. I kinda thought it would be a little faster, but it weights about a jillion lbs. I'll see if maybe the fresh plugs and coils will help pick up some lost power. The T56 is SO notchy, but I'll learn how to really rip that 3-4 shift and hopefully pick up a tenth or two.
