F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Factory OEM F30 Wheels Offsets (18, 19, 20 inch) and Brake Sizes
GetBMWParts
      10-30-2013, 08:51 AM   #45
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Originally Posted by moreno1 View Post
Thanks for your answer! So he will be able to use those new winter tires (225/35/19) on his 401 wheels without any serious issues!!
I tried to use the calculator on E90 side and the difference seems to be -3.15%. The dealer told him that one should never go more than a difference of +/- 0.5%. Is this true or they are just trying to get him to buy a new set of winter tires for his new car??
Yes that's correct, they will be 3% shorter than 225/40-19.
On xDrive it's important to keep the difference in front and rear diameter within 0.5% on a staggered setup! But since we discuss a square setup it doesn't matter.
To me it just sounds like the dealer trying to sell a new set of winter tires.
I checked OEM 16" (205/60-16) and OEM 20" (225/35-20) tires, the difference in overall diameter is above 2%.
      12-02-2013, 06:29 AM   #46
435iaffair
Drives: 435i, Z4M, M157 E63
2014 435i  [9.00]
Anybody know the specs for F32?
      12-02-2013, 07:42 AM   #47
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
F32 use the same offsets as for F30 listed in the first post.
      12-02-2013, 07:50 AM   #48
435iaffair
2014 435i  [9.00]
Thank you!
      12-02-2013, 12:55 PM   #49
cjack
cjack's Avatar
Drives: 435X, EBII, 6MT, PPK + 2019 X5
Would like to install on an F32 M-sport:
Front: 20x9 ET:35. Tire: 225/35
Rear: 20x10 ET:45. Tire: 255/30
Any issues I should look out for?
Thank you for your help.
Colin
      12-02-2013, 01:40 PM   #50
AweSam8
Super Spectacular Awesome Dude
AweSam8's Avatar
Drives: 2010 E70 X5M, 2014 F30 335i M
So my MY14 m sport 400m wheels come stock staggered? I thought they were all the same size.
      12-02-2013, 02:23 PM   #51
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
Colin
Sounds like a great setup, shouldn't be any clearance issues!
      12-03-2013, 11:02 AM   #52
cjack
cjack's Avatar
Colin
Thank you!
      02-09-2014, 11:00 AM   #53
klerk
Drives: 2014 F32
want to install on my new F32 M sport:
19" M5 345 style wheel
345 Specs:
Front: 19x9" ET32. tires ______?
Rear: 19x10" ET34. tires_______?
what tire size should i run for best fitment?
possible? (fingers crossed).
      02-14-2014, 09:02 PM   #54
sledhead1
Drives: 2014 335i M-Perf laguna seca
Anyone know what size winter tires and wheel i need on a 2014 335i m-performance car? Stock are the staggered 20" Can i get non-staggered 17" on it or 18"???
      03-08-2014, 05:06 PM   #55
stephenwillis
stephenwillis's Avatar
Drives: X3 M40d
Would like to fit 20" style 361 on my F32 435d xDrive with the M Sport brakes
Front: 8Jx20 ET:36 225/35R20 (vs current 8Jx18 ET:34 225/45R18)
Rear: 8.5Jx20 ET:47 255/30R20 (vs current 8.5Jx18 ET:47 255/40R18)
Any issues I should look out for e.g. front spacers required / clearance / xDrive issues?
bimmerposts wheel offset calculator says the new rears will have “the same clearance on the strut side, and the outside edge of the wheel will extend to the same point as the stock wheel” but the new fronts will have “2mm less clearance on the strut side, and the outside edge of the wheel will retract 2mm”
Thanks in advance,
Stephen
      03-09-2014, 12:49 PM   #56
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
No problem, almost identical offsets and overall diameter.
      03-11-2014, 07:44 AM   #57
stephenwillis
Drives: X3 M40d
Thank you
      03-20-2014, 03:13 PM   #58
stephenwillis
Drives: X3 M40d
Fit perfectly. Thanks ss0803
      04-02-2014, 12:17 PM   #59
dlrooney
Drives: 335i
Hi,
does anyone know what size and offset are for the F30 M-Sport 19" Star-Spoke 403M wheels?
thanks,
Dan
      04-02-2014, 12:39 PM   #60
PabloK
PabloK's Avatar
Drives: F30
Originally Posted by dlrooney View Post
Hi,
thanks,
Dan
19x8" ET36 225/40/R19 front / 19x8.5" ET47 255/35/R19 rear
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is
2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3
2017 Alpina B6
22 Ram Trx / 22 M5 CS
      04-02-2014, 09:38 PM   #61
dlrooney
Drives: 335i
Many thanks!!
      04-15-2014, 12:10 PM   #62
Polo08816
Drives: 2014 335i M Sport
Originally Posted by E90Fleet View Post
Standard factory wheels offsets:
  • 18" Double Spoke Style 400M (M Sport wheels) - 18x8" ET34 225/45-18 front / 18x8.5" ET47 255/40-18 rear
  • 18" Double Spoke Style 397 (Sport Line wheels) - 18x8" ET34
  • 19" Double Spoke Style 401 - 19x8" ET36 225/40/R19 front / 19x8.5" ET47 255/35/R19 rear
  • 20" Cross Spoke Style 404 - 20x8" ET36 225/35/R20 front / 20x8.5" ET47 255/30/R20 rear
  • 20" M Double Spoke Style 405 - 20x8" ET36 225/35/R20 front / 20x8.5" ET47 255/30/R20 rear
Brake sizes:
328i front brakes: 12.3" / rear - 11.8".
328i M sport brakes - front: 13.4" / rear: 13.6"
335i front brakes: 13.4"
335i M sport brakes - front: 14.6" front / rear: 13.6" rear
What's the most cost effective square setup solution (winter + summer setups) for a F30 328i M Sport with M Sport Brake?
I'm thinking to buy another staggered OEM 400M setup and use:
- (4) 18x8 all around for 225/45/18 winter tires
- (4) 18x8.5 all around for (245 or 255)/x/18 summer tires
The stance may look a bit weird, but hopefully some wheel spacers can correct it?
      06-05-2014, 08:49 AM   #63
stewie
Drives: E90 335i
Looking for 18" winter rims for a 335i Msport.
Found a nice set of used M3 rims that measure as follows:
Front Wheels: 18" x 8" -- Bolt Pattern = 5x120mm. Offset = ET47
Rear Wheels: 18" x 9" -- Bolt Pattern = 5x120mm. Offset = ET26
Does anyone have a quick idea if these would fit, and what the best tire size would be?
Thanks.
      08-04-2014, 09:34 AM   #64
strig1
Drives: 2014 328i
I am planning on buying AG M359 19x9 et35 (front) and 19x10 et 38 (rear) with PSS 235/35/19 and 265/30/19. I currently have the stock 17 in wheels, will this work for me?
      08-08-2014, 02:45 AM   #65
xshadowwolfx
Drives: 328i <- soon
Hey guys will the style 313 wheels from a E90 fit my F30? Im also not too sure about the lugs and bore.
19x8 ET35 / 225/40R19 Fronts
19x9 ET39 / 255/35R19 Rears
Its basically the same except that the rears are 15mm farther out. Thanks.
      08-09-2014, 07:19 AM   #66
.BMW.
.BMW.'s Avatar
Sweden
1863
Drives: BMW F11/F31
The wheels will fit!
Maybe add some front spacers to complete the look.
You will need to use bolts from F30, since F30 use M14x1.25 (E90 had M12x1.5).
Tags
f30 3 series wheel offset, f30 3 series wheel offsets, f30 328i wheel offset, f30 328i wheels offset, f30 328i wheels offsets, f30 335i wheel offset, f30 335i wheels offset, f30 335i wheels offsets, f30 offets, f30 offset, f30 wheel offset, f30 wheel offsets, f30 wheels offset, f30 wheels offsets, wheel offset f30, wheels offset f30, wheels offsets f30
f30post
