Microphone wiring when retrofitting NBT Evo ID6 to F22/F30 w/ ENTRYNAV + TCB |
03-22-2023, 06:14 AM | #1 |
Rep 79
Hi all!
I have one more doubt that kind of bugs me. I see multiple videos on YouTube of people retrofitting an NBT Evo unit + VIN-matched ATM to an F30 (2012-2013) with a factory CIC unit. The CIC unit also connects to a so-called "Combobox" (not sure whether this is the same as a TCB unit). These retrofits pose following challenges: 1) both emergency and normal microphones are connected to the Combobox, which in turn connects to CIC HU, which means that in order to successfully retrofit the NBT+ATM, the mic needs to be wired to the ATM instead of the Combobox, which creates a lot of retrofitting problems. 2) in order to use the same wiring the stock F30 came with, many cables need to rewired/extended e.b., 20-pin connector from Combobox to ATM wiring, quad-lock from CIC to NBT wiring. Now, I'm planning to retrofit an NBT Evo ID6 WITHOUT an ATM module to my 2015 F22, which comes with an ENTRYNAV (hardware equivalent to NBT NON-Evo) + TCB_NAV. 1) will the mic already be wired to the NBT Evo head unit without having to pass through the ATM module (which I'm not planning on getting)? Is this achieved with a regular quad lock retrofit harness? 2) do I even need a quad lock retrofit harness for connecting the NBT Evo to the car like the ENTRYNAV? Thanks a lot! |
05-10-2023, 04:47 PM | #2 |
Rep 79
This issue was resolved.
About the two microphones (emergency and main), I found out the following:
Point 2. was at least my case, but for me it was fine losing the emergency microphone, as I came to terms with not having connectivity (which in my ENTRYNAV HU was used only for Real-Time Traffic, which is a paid service, and for the pretty useless Teleservices, which are used to send email notifications about due service). As far as I'm concerned this subject is resolved! Last edited by boldorider4; 05-11-2023 at 01:21 AM.. |
shadowfax1289.00 |
01-07-2024, 06:37 AM | #4 |
Rep 79
No, I have not, simply because I chose to retrofit an NBTevo without an ATM module, thus losing connectivity and emergency mic.
The wiring however is supposed to end up in a connector that is already present at the backend of the car. Basically this connector (which plugs into the TCB i.e. the legacy connectivity module) needs to be repinned into a new connector (connector retrofit kits are widely available or at least schematics are for an easy DIY) that will plug into the ATM-module. I suspect that the emergency mic is wired to that connector. So you will have to tear down the LH driver side of the car to wire the ATM to the NBTevo, but not for the purpose of rewiring the emergency mic, because such a mic is already wired to the backend. You'll do that to connect the ATM to the NBTevo through an OABR connector (which will also carry the mic data). This OABR is not present at all on the pre-LCI ENTRYNAV or older NBT units. Don't take my word for it though, there are plenty of tutorials of people retrofitting an NBTevo+ATM successfully to a pre-LCI vehicle with ENTRYNAV/NBT+TCB. They will also sort out the emergency mic issue. This video I think covers it all. It's an F30 but the wiring and units involved are the same as F22. |
01-07-2024, 08:55 AM | #5 | |
Rep 499
I ended up just purchasing a plug and play harness from an eBay vendor since I retrofitted ATM as well. By coding in the enhanced bluetooth, I am missing microphone #2 which throws a silent error only visible in ISTA, but nevertheless I do plan to wire that up. It appears as though it goes to pins 18 and 19 on quadlock harness.
Performance Mods: Eibach Pro Kit Springs, Eibach Sway Bars, KONI SA Dampers, M Perf Rear Brakes, Dinan Free Flow Exhaust, MHD Stage 2
Retrofit: Reversing Camera, Rear PDC, Front PDC, NBT Evo |
02-05-2024, 06:13 PM | #6 |
Rep 3
Drives: 2008 335i coupe
I to have an issue with the mic on my car, just can't get it to work is there anyone out there that can give me an idea how to make this work. I have the ID6 NBT Evo retrofitted on my 335i-e92 2008 it works fine but the Mic just does not work. According to the instruction I had to reroute the wire for the Mic directedly to the back of the unit it does not work. I have sent this to techs and tested this unit on other card and apparently the Mic work on the unit just not my car. I have also tested different wires. ANYHELP?
