10-08-2015, 05:47 PM | #1 |
Rep 297
Question: Is there a way to turn your tail lights into a decorative light at home?
I have my stock 135 tail lights for my car chilling in my house, and I was thinking it might be cool to buy a wiring harness for it and somehow get it connected to an AC plug so I can turn them on with the flick of a switch.
Has anyone heard of this being done? Or have an idea where to begin? The idea of turning these into a little lamp or something has been on my mind for awhile now. Thanks!
2021 M2 Comp | STEK Stealth Wrapped | PSM V2 Trunk Spoiler
2022 X3 M Comp | (SOLD) 2016 M3 | AWE Switchpath Diamond Black 102mm (SOLD) |
10-08-2015, 05:51 PM | #2 |
Rep 1,818
you could probably do it with a computer power supply, they convert 110AC into 12vdc just like your car uses, and I'm sure the wattage is well within most power supply's range
10-08-2015, 07:29 PM | #3 |
is probably out riding.
6057
Rep 2,292
just get a AC to DC 12v converter. Plug it into a switch operated outlet, wire it to the lights.
"There is no greater tyranny than that which is perpetrated under the shield of the law and in the name of justice. -Charles de Secondat"
10-10-2015, 12:16 AM | #5 |
Warrant Officer
376
Rep 1,340
Just because the car has a 12v battery doesn't mean the lights are operated by 12v. Figure out what voltage and amps each light bulb requires to run.
I believe I found the circuitry behind the light housing: https://www.ecstuning.com/BMW-E82-13...ghts/ES207350/ This should give a good understanding on what is required to get this done. It's a simple concept to do but you don't want to take any shortcuts or cheesedick anything when it comes to power.
Deleted, ATM I/C and tuned by B.R.R.
10-26-2015, 12:54 PM | #6 | |
Rep 297
Might swing by a dealership and just ask the parts department.
Tags |
135, lamps, tail lights |
