2010 2011 BMW 5 Series Forum F10 F10 Technical Topics Navigation, iDrive, Audio, Video, Bluetooth, Phone, Coding Can bimmercode code out adaptive headlight malfunction
      02-26-2023, 10:08 AM   #1
528ixparts
Drives: BMW 528IX
I have had the adaptive headlight malfunction coded out before remotely but just had to swap out an engine and ecu so the warning is back along with TPMS warning.
Can bimmercode code these out? If so is it through expert mode?
Thanks any help is appreciated
      03-02-2023, 06:38 AM   #2
TheNine90
Drives: bmw
LaMaster1 3073 > C_AFS_ENA = F010_disable (01)
LaMaster1 3073 > C_BLC_ENA = F010_disable (01)
LaMaster1 3073 > C_CLC_ENA = F010_disable (01)
LaMaster1 3073 > C_HBA_ENA = F010_enable (00)
Try this. This isnt the full code since the other depends on your light package.
If you have ENET cable i can code out adaptive headlights remotely.
      03-02-2023, 04:04 PM   #3
r2dmax
r2dmax's Avatar
Drives: E46 330ci; F10 535i M Sport
Which cable? I will need the same coding soon. Changing my leaky adaptive lights for a nice aftermarket option
E46 330ci
F10 535i M Sport
      03-02-2023, 11:51 PM   #4
TheNine90
Drives: bmw
You can use ENET cable or bluetooth dongle for bimmercode. Esys also uses ENET cable
      03-03-2023, 08:17 AM   #5
528ixparts
Drives: BMW 528IX
dm sent
      03-26-2023, 09:33 AM   #6
Krueger84
Drives: 2011 535i
I need the same. Let me know if you can
      03-26-2023, 10:08 AM   #7
TheNine90
Drives: bmw
Which headlight do you have LED,Xenon, adaptive?
      03-26-2023, 10:09 AM   #8
TheNine90
Drives: bmw
If you have enet cable it can be done
      12-02-2023, 02:12 PM   #9
Thesilverm3
Drives: Bmw m3
Check your inbox!
      12-03-2023, 01:31 AM   #10
TheNine90
Drives: bmw
Originally Posted by Thesilverm3 View Post
Check your inbox!
Replied
      04-22-2024, 07:10 PM   #11
EternalTez
Drives: 2014 528xi
Originally Posted by thenine90 View Post
lamaster1 3073 > c_afs_ena = f010_disable (01)
lamaster1 3073 > c_blc_ena = f010_disable (01)
lamaster1 3073 > c_clc_ena = f010_disable (01)
lamaster1 3073 > c_hba_ena = f010_enable (00)
try this. This isnt the full code since the other depends on your light package.
If you have enet cable i can code out adaptive headlights remotely.
thanks so much for this.
If you want to delete adaptive headlight code on 11-17 f10 use this on bimmercode
      04-26-2024, 12:27 AM   #12
Kritos
Drives: 1992 540i ; 2013 528i xDrive
I know this is a realatively old thread but may I ask what brand you went with for headlights? I just purchased a clean 2013 528xi and my left headlight has a moisture problem. I've read that it might just be faulty seals installed in the factory..or cracked lenses but i failed to find cracks upon inspecting them, so i suspect the seals.
5post
