09-04-2008, 08:09 PM | #1 |
Rep 7,308
Drives: see above.
Anyone overclock?
I just pushed an Athlon x2 4200 from 2100 upto 2500 and its stable with a mild voltage increase.
How far should I push before I'm hitting its limits?
09-04-2008, 10:10 PM | #2 |
Rep 3,288
I'm not a big overclocker. While I've done it alittle bit, I just personally don't really enjoy the slight benefits that it gives. I prefer stability and longevity instead.
Plus, at the moment I'm not really running anything on my computer that would really benefit all that much from overclocking.
09-04-2008, 11:00 PM | #3 |
Rep 1,548
do you have a good cooling system? i used to OC my dual core from 3gh to 3.7gh but i have a water cooling system, it consumed too much power so i defaulted back to regular speed
________ Frying food ________ Ocean View Condominium Prathumnak ________ ZOLOFT LAWSUITES Last edited by ontopofm; 09-19-2011 at 11:23 PM.. |
09-04-2008, 11:50 PM | #5 |
Rep 3,288
You can still over clock a decent amount on today's hardware with air cooled systems. Intel has been building their chips for overclocking for a little while now.
You just won't get crazy gains. But you can easily OC a intel chip to +~800mhz. Maybe 1ghz if your lucky, all on air cooled heatsinks.
09-05-2008, 12:01 AM | #6 | |
Rep 171
Drives: BMW F31 330D MSport
http://www.legitreviews.com/article/374/1/ Don't be a wuss, go for thermal death
09-05-2008, 12:08 AM | #7 | |
Rep 7,308
Drives: see above.
09-05-2008, 08:14 AM | #9 |
Rep 3,288
If it's 50 at idle, yeah thats running alittle hot. Typical idling temperatures should be in the mid low-mid 40s. Did you check your temp right after running a big application? CPU temps under load can be around 65ish and not be a concern.
09-09-2008, 02:27 PM | #11 |
Rep 5,319
Not since 2001...
09-09-2008, 03:19 PM | #13 | |
Rep 1,548
________ Weed ________ Child paxil ________ Novana Residence Condo Last edited by ontopofm; 09-19-2011 at 11:24 PM.. |
09-11-2008, 05:39 PM | #14 |
Rep 133
The old single core XP AMD's ran a little hot - nowhere near as bad as the Intel P4's - the X2's however got warm aswell.
I wouldn't push voltage much past 1.5v and temps more than 65-70C are a concern. Again - this is some pretty old tech that you're using mate. AMD lost the performance battle when Intel released the Core architecture - the Core 2 stuff has just blown AMD completely off the map. IF you were looking to upgrade (which depending on your purpose and budget - now could be a good time to do so) you'd be insane to go anything but intel. There are new Intel chips due in November, a new socket, DDR3 ram - basically means you'll need a whole new PC (new Motherboard, new RAM etc) if you want a new CPU - so the OLD stuff will be REAL cheap (it's already really cheap as it is!). The catch is that the NEW chips apparently only excel at server type functions - so if you're a gamer or use your PC for media based functions, you're best of getting the high end of the CURRENT CPU's when the new ones come out - as these high end chips will get REAL cheap - even though they're great for your purpose. You would also be NUTS not to overclock - these chips are just MADE for it. Rule of thumb - if you game - go a dual core CPU - if you do multi-tasking/media then go quad. Also - when you overclock anything over 3.4 ghz you simply won't notice too much. And as always - if you're going to overclock - make sure you get AFTERMARKET COOLING - I'd suggest the Thermalright TRUE or Tuniq Tower heat sinks with a really nice 120mm med/high cfm fan. A nice case with several 120mm's is also recomended (Antec 900 is a beauty). Best bang for buck chips right now: Gamer - E8400 - $139 at Fry's and EASILY clocks to 4.0 Video - Q6600 - $149 at Fry's and clocks like a champ. |
09-12-2008, 01:41 PM | #17 | |
Rep 7,308
Drives: see above.
Its the media centre PC anyway so doesn't get used for much gaming - too much TV!!!
09-12-2008, 01:45 PM | #18 |
Rep 3,288
Interesting. I feel like they mounted the motherboard in relation to the fans in wrong though.
The fans should be blowing air over the PCI cards and past them. Not just directly on top of them. Having the cards sideways in there like that is horrible for air flow.
09-12-2008, 02:33 PM | #19 |
Rep 133
That full system is watercooled - you'd have sinks on the ram/gpu etc on any PCI card - most likely sinks on the RAM too - all actively cooled by the water that itself is cooled by the radiator.
Basically - so long as that radiator is cooled correctly, he could have bugger all fans in that rig and he'd still be golden. |
09-13-2008, 06:57 PM | #21 | |
Rep 117
There is a ton of air moving through it. So like right now it's 31 degrees and the gpu is 37. After a couple hours of OCCT stress testing, I've seen it get up to 57 degrees... temps aren't a problem; getting the gigabyte mobo with the x38 chipset stable is another story |
09-14-2008, 12:03 AM | #22 | |
Rep 3,288
