01-02-2010, 09:42 PM | #1 |
Rep 779
$29 Windows 7 upgrade
...if you have a .edu email address. Its doesn't have to be yours, it can be your kids, your kids friends, your neighbors, watever. As long as its .edu address.
www.win741.com |
01-02-2010, 09:45 PM | #2 |
Rep 4,649
01-03-2010, 04:03 AM | #3 | |
Rep 779
Have you tried this yourself? thinking about downloading this for my laptop |
01-03-2010, 12:34 PM | #6 | |
Rep 4,649
i've been running torrent win 7 since 0-day. i haven't had a single problem with it and nod32 hasn't found anything. in fact, all OS's i've ran for years have been torrents with great results. also, i've found some bad torrents on piratebay, although most are legit, but i've never found a bad torrent on demonoid. Last edited by Blake; 01-03-2010 at 01:24 PM.. |
01-04-2010, 04:00 AM | #7 |
Rep 15,818
what if you have a mac and want windows 7 too lol
I don't feel like installing Vista again on my new MacBook Pro...
01-04-2010, 04:07 AM | #8 |
Rep 15,818
wait, so is this just an upgrade, meaning you must already have windows installed??
Can I install Vista, then install Windows 7 through this? Can I just buy this and install Windows 7?? Thanks in advance...
01-04-2010, 06:17 AM | #9 | |
Rep 779
What I ended up doing was, I still bought the legit copy for $29 because I was scared Then I upgraded my desktop from vista to 7 wit legit key and file that I bought and downloaded thru win741. For my notebook with XP (which was ridden with like a billion kinds of viruses, spyware, trojans from 4 years of downloading porn). I used the same install folder (the 1 I bought so I know its safe) burn onto a disc, so I did a disc install on the laptop. But because you can't do an upgrade install from XP to 7 (I wouldn't want to anyway with all that spyware on there) I just did a custom install which deleted everything and did a clean install, which is fucking sweet. set it up without product key and windows will give you 30 days to get a key. For the key. Click on Blake's link and download that torrent. BUT, don't download everything, you don't need to download those 2 actual windows iso (1 32bit and 1 64bit) they are both 2.XX gb each so shouldn't be hard to miss. uncheck those and download the rest which should be really really fast. Once done look for this folder called Windows 7 Loader 1.6.9 by Daz inside execute the program called windows 7 loader, follow onscreen directions and you will have a genuine set of windows 7 in no time. Of course, you can always download the actual windows program from Blake's link if you don't want to buy, but just know that you can't upgrade from 32 bit vista to 64bit 7, unless you are running 64bit vista already, you have to do a custom install if you want 64bit 7 (means you will have to back up your data as it will erase everything). I just did the 32bit 7, not worth the trouble for me. Good luck, post here if you have questions. |
01-04-2010, 06:18 AM | #10 |
Rep 779
01-04-2010, 11:59 AM | #11 |
Rep 4,649
01-04-2010, 11:19 PM | #13 | |
Rep 779
I am sure most are fine esp with alot of positive comments but my understanding is that root back doors that are custom built into an OS install file is really hard to detect by antivirus. So in the end, I think $29 is worth it for me for a piece of mind I guess. |
01-05-2010, 02:23 AM | #14 |
Rep 15,818
I got the 64 bit woot lol
just need to find time to not be lazy and install..
01-05-2010, 03:27 AM | #15 | |
you know he kills little girls like you
390
Rep 892
Code:
osx ~ % cat .zshrc HISTFILE=~/.histfile SAVEHIST=8192 fpath+=~/zfunctions typeset -U fpath autoload ~/zfunctions/*(:t) prompt="%m %c %# " watch=all logcheck=8 autoload -U compinit compinit zmodload -i zsh/complist zstyle ':completion:*' menu select setopt append_history setopt auto_cd setopt correct setopt extended_glob setopt extended_history setopt list_packed setopt no_beep setopt no_clobber setopt no_hup setopt print_exit_value unsetopt bg_nice bindkey -v zle -N insert-sudo-prefix bindkey '' insert-sudo-prefix So here is a message to all Windows users that mock Mac users on the grounds that they are "n00bs". Do yourself a favor and STFU until you know what you are talking about. |
