BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Suspension | Brakes | Chassis
European Auto Source (EAS)
      01-01-2010, 10:38 PM   #1
rzm3
rzm3's Avatar
675
Drives: E92 M3
Arrow Master List of E9x Coilover Kits
Work in progress. Please reply to add/edit information to the list.
Discussion regarding each kit should be posted in their relevent threads. Information in this thread are subject to error and modification. Please use at your own risks.
Notes:
  • Spring rates (lb per inch) are approximate and are based on information from various threads and manufacturer's available data
  • Front motion ratio is approximated to be 0.96
  • Rear motion ratio is approximated to be 0.58
  • Wheel Rate = Spring Rate * (Motion Ratio)^2
  • OE Spring Rates: 160F/550R
  • OE Wheel Rates: 147F/185R
      01-01-2010, 10:48 PM   #2
rzm3
rzm3's Avatar
675
Drives: E92 M3
Arrow Bilstein
Bilstein PSS10
www.bilsteinus.com
MSRP $2,495
  • Height Adjustable: 0.4"-1.4"F/0.8"-1.4"R
  • Spring Rates: 515F/570R
  • Wheel Rates: 473F/192R
  • Compression and Rebound Jointly Adjustable: 10 levels total, via knobs
http://www.m3post.com/forums/showthread.php?t=272825
http://www.m3post.com/forums/showthread.php?t=330458
      01-01-2010, 10:48 PM   #3
rzm3
rzm3's Avatar
675
Drives: E92 M3
Arrow KW
KW Competition
www.m-world.us/products_kw.html
MSRP $4,295
  • Height Adjustable: Custom
  • Spring Rates: Custom
  • Wheel Rates: Custom
  • Compression and Rebound Individually Adjustable: 18 levels/12 levels, via knobs
http://www.m3post.com/forums/showthread.php?t=536863
http://www.m3post.com/forums/showthread.php?t=439800
      01-01-2010, 10:49 PM   #4
rzm3
rzm3's Avatar
675
Drives: E92 M3
Arrow Moton
Moton Street Sport
www.motonsuspension.com
MSRP $4,700
  • Spring Rates: 360F/620R
  • Wheel Rates: 332F/209R
  • Compression and Rebound Individually Adjustable: 7 levels/7 levels, via knobs
http://www.m3post.com/forums/showthread.php?t=331500
http://www.m3post.com/forums/showthread.php?t=324486
http://www.m3post.com/forums/showthread.php?t=226424
      01-01-2010, 10:50 PM   #5
rzm3
rzm3's Avatar
675
Drives: E92 M3
Arrow KW
KW V3
www.kw-suspension.com
MSRP $2,695
  • Height Adjustable: 0.4"-1.4"(1.5"EDC)F/0.2"-1.4"R
  • Spring Rates: ProgressiveF/630R
  • Wheel Rates: ProgressiveF/212R
  • Compression and Rebound Individually Adjustable: 7 levels/18 levels, via special tools
http://www.m3post.com/forums/showthread.php?t=146467
http://www.m3post.com/forums/showthread.php?t=257381
http://www.m3post.com/forums/showthread.php?t=491523
KW Club Sport
MSRP $3,595
  • Height Adjustable: 0.4"-1.5"F/0.2"-1.4"R
  • Spring Rates: 514F/800R
  • Wheel Rates: 474F/269R
  • Compression and Rebound Individually Adjustable: 9 levels/18 levels, via special tools
http://www.m3post.com/forums/showthread.php?t=231678
http://www.m3post.com/forums/showthr...=1#post6047702
      01-01-2010, 10:50 PM   #6
rzm3
rzm3's Avatar
675
Drives: E92 M3
Arrow AC Schnitzer/Sachs
AC Schnitzer Racing Suspension
www.ac-schnitzer.de/en/
MSRP $4,280
  • Spring Rates: ?F/?R
  • Wheel Rates: ?F/?R
  • Compression and Rebound Jointly Adjustable: 20 positions, via knob on bottom
http://www.m3post.com/forums/showthread.php?t=229026
http://www.m3post.com/forums/showthread.php?t=331177
      01-01-2010, 10:51 PM   #7
rzm3
rzm3's Avatar
675
Drives: E92 M3
Arrow Racing Dynamics
RD Sport/Racing Dynamics Chassis Kit
www.racdyn.com
MSRP $2,490.00 ($3,210 w/ sway bars)
  • Height Preset: 1.0"F/0.75"R
  • Compression and Rebound Preset
http://www.m3post.com/forums/showthread.php?t=265123
      01-01-2010, 10:51 PM   #8
rzm3
rzm3's Avatar
675
Drives: E92 M3
Arrow AST
AST 4200
http://www.ast-suspension.com/index.asp
  • Height Adjustable: 0.5"-2.0"F/0.0"-2.0"R
  • Rebound Adjustable: 12 clicks
  • Compression Adjustable: 12 clicks
http://www.m3post.com/forums/showthread.php?t=489312
      01-01-2010, 10:52 PM   #9
rzm3
rzm3's Avatar
675
Drives: E92 M3
Arrow Ohlins
Ohlins Custom by PSi
http://www.performancespeedtech.com/
  • Height Adjustable
  • Compression and Rebound Individually Adjustable: 40+ levels/40+ levels, via hex knobs. Solid piston front and rear. Through rod front.
http://www.m3post.com/forums/showthread.php?t=447554
      01-01-2010, 10:54 PM   #10
rzm3
rzm3's Avatar
675
Drives: E92 M3
Arrow Macht Schnell
Macht Schnell - Electronic Dampening Control (EDC) Emulation Module
http://www.europeanautosource.com/pr...oducts_id=2425
Manufacturer's link: http://www.machtschnell.com/2009/11/...lation-module/
      01-01-2010, 10:55 PM   #11
consolidated
consolidated's Avatar
207
Drives: F80 M3
Thanks, your posts add a lot to the knowledge of the forum. Do you have enough information to list standard spring rates for each coilover?
      01-01-2010, 10:56 PM   #12
rzm3
rzm3's Avatar
675
Drives: E92 M3
TC Kline Racing
TC Kline Racing Suspension Adjustable Sleeve kit
  • Camber/Caster plates
  • 4 Springs
  • 2 Coilover sleeves
  • 2 Spring hats
  • 2 Sway bar link clamps
  • 2 Rear ride height adjusters
http://www.m3post.com/forums/showthread.php?t=645901
      01-01-2010, 11:14 PM   #13
rzm3
rzm3's Avatar
675
Drives: E92 M3
Reserved 5
      01-02-2010, 01:06 AM   #14
michaeldorian
Drives: M2 CS
www.racdyn.com
MSRP $?
  • Height Preset
The MSRP for this is $2,490.00. The full chassis kit including sways (ANTI SWAY-BAR KIT HOLLOW 30.2/25.5mm ADJUSTABLE E9x M3) is $3210.00.
Sways by themselves have an MSRP of $720.00
      01-02-2010, 12:32 PM   #15
Radiation Joe
Veni Vidi Vici
Radiation Joe's Avatar
Drives: '11 JB/BBe-6sp-e90
2011 e90 M3-Sold  [8.50]
2003 RS6 - Sold  [0.00]
2009 e90 M3 - Gone  [0.00]
2003 M3 SOLD  [0.00]
old 2002  [10.00]
Nice job. Thanks for the efforts.
      01-03-2010, 06:01 AM   #16
MrHarris
yodog
MrHarris's Avatar
Drives: '86 Corolla
2009 BMW  [10.00]
Any info on Eibach springs?
2009 E92 M3 | Alpine White | Black Extended | Advan RS | Turner Test Pipes | Dinan Axle-Back | OETuning | Eibach Springs | UUC SSK | VRS Front Lip | VRS Type I Diffuser | Matte Black | RPi Scoops | MS Filter | Yokohama AD08 | F1 Pinnacle
Special Thanks: Gintani | OETuning | eAs
      01-03-2010, 03:08 PM   #17
FrankieP
FrankieP's Avatar
Drives: E92 M3 AW/BLK
ACS racing suspension
Compression and rebound jointly adjustable, 20 positions via nob on bottom.
      01-04-2010, 02:01 AM   #18
Robwe46m3
Drives: 2010 E92 Ruby Blk M3 Individua
Frank @ CEC. Can you please give us specs and info about the ACS Suspension Kit? BTW I've sent you PM about buying the kit but you have not responded...
      02-08-2010, 04:31 PM   #19
MentholGuy
MentholGuy's Avatar
Drives: 11 E90 M3
www.racdyn.com
  • Height Preset: 1.2"F/1.0"R
Based on their website,
The RDSport Chassis Kit includes uprated struts and springs providing an 18% increase in stiffness while lowering the vehicle 1" in the front and 0.75" in the rear.
      05-01-2010, 08:01 PM   #20
graider
graider's Avatar
35
Drives: py/kiwi e46 m3
why do most coilover allow more drop on the front than the rear. wouldn't it better for handling to drop like 1" all around than say 1.5 front/1rear?
      05-02-2010, 12:30 AM   #21
rzm3
rzm3's Avatar
675
Drives: E92 M3
Most kits have adjustable heights, so you can fine tune it to your own liking...
      05-15-2010, 05:18 PM   #22
Prit@Euro Autowerx
Drives: E46 M3
Thanks for sharing!
m3post
